It was the ceiling of my camperbus.
Wooden wood
- Has thanked: 485 times
- Been thanked: 1428 times
- Has thanked: 2407 times
- Been thanked: 3635 times
Re: Wooden wood
That's a pretty extreme usage for wooden panelling. Extremes of hot and cold, plus condensation.
Re: Wooden wood
I know others what have been fine with the same stuff. I am putting a new ceiling up after the Christmas and new year. Flexible ply covered in expedition carpetmangocrazy wrote: ↑Mon Dec 18, 2023 8:32 pm
- Has thanked: 6198 times
- Been thanked: 5088 times
Re: Wooden wood
Half the story again
Still the same problem and, potentially, the same solution. The wood doesn't know where you're using it
Although, presumably, made worse by cooking and just being in there and breathing. So you need improved ventilation for the living space. And, potentially, between the roof and lining.
Re: Wooden wood
Aling with ventilation, how about insulation between the roof and lining? If the ceiling is warmer you might get less condensation.Felix wrote: ↑Mon Dec 18, 2023 8:35 pmI know others what have been fine with the same stuff. I am putting a new ceiling up after the Christmas and new year. Flexible ply covered in expedition carpetmangocrazy wrote: ↑Mon Dec 18, 2023 8:32 pm
- Has thanked: 1508 times
- Been thanked: 1415 times
- Yambo
- Has thanked: 598 times
- Been thanked: 1647 times
Re: Wooden wood
There's lots of different varieties of wood. Knowing which one is best for any particular application is part of being a good carpenter/woodworker.
Wood butchers like me use what's to hand, or plywood and slap a coat of epoxy on it.
Re: Wooden wood
Would sufficient coats of epoxy render the wood underneath fully waterproof? I'm toying with making a big photographic darkroom sink out of plywood, with loads of coats of epoxy on top. Is this viable?
- Has thanked: 2552 times
- Been thanked: 6257 times
Re: Wooden wood
Glass fibre boat hulls are about half epoxy*! Should provide some reassurance of its water integrity.
*or maybe Polyester
*or maybe Polyester
- Yambo
Re: Wooden wood
mangocrazy wrote: ↑Tue Dec 19, 2023 10:06 amWould sufficient coats of epoxy render the wood underneath fully waterproof? I'm toying with making a big photographic darkroom sink out of plywood, with loads of coats of epoxy on top. Is this viable?
Mmmm, sufficient . . .
I have a rowing boat and two kayaks made out of plywood. The plywood is covered with fibreglass which is bonded to the wood with epoxy. All the seams are bonded with thickened epoxy. On top of the fibreglass is 3 or 4 coats of epoxy but this is mainly to fill the weave of the fibreglass to make a nice smooth finish.
I've recently femoved the fibreglass from the deck of one of the kayaks, it was starting to delamination in a couple of places, and I'm not replacing it, just painting the deck with an epoxy barrier coat - paint basically.
A couple of coats of epoxy will certainly seal the wood but you'd need more coats on end grain and the faces may absorb the epoxy more in some places than others. That was the issue with my kayak deck and I probably neglected to wet the surface with epoxy before applying the fibreglass.
Epoxy is ace stuff, not cheap though and as I said, the wood itself may be the problem and may require more coats to do the job you want. Epoxy is not UV resistant so outside use will require some top surface coating to prevent the epoxy degrading.
Basically though, epoxy, as a coating is brilliant. Sufficient depends on the surface being treated.
Re: Wooden wood
"sufficient" = 'how long is a piece of string'. then...
My intended usage would be inside, in a darkroom, so minimal amounts of UV. Usage would be periodic, but when it was being used it would be for several hours on end, anywhere up to 10-12 hours. Chemicals used are basic photographic chemicals, so a mixture of fairly dilute acids and alkalis, with good likelihood of staining (photographic developer goes orange/red as it ages/oxidises) but contact will only be for hours, not days. The main requirement is to support dishes of photographic chemicals as a succession of prints are made with the prints passing through 3 or 4 dishes as they go through the process. Once the session is over, the whole sink will be thoroughly washed down and rinsed.
It is possible to buy ready made fibreglass or stainless (!) tanks, but they are very spendy (esp. stainless) and I've heard of a lot of people just making a big sink/tray out of plywood and then covering the ply with a) several coats of epoxy or b) fibreglass followed by epoxy. Obviously option b would be more resistant, but it also greatly increases the time, expense and faff-factor. Hence why I'm wondering if multiple coats of epoxy on 18mm ply would suffice...
- Has thanked: 201 times
- Been thanked: 216 times
Re: Wooden wood
Nice idea, but I need something that will take at least 3 (preferably 4) 20" x 16" photographic trays/dishes. That requires a minimum length of 6 feet, and preferably closer to 8 feet.
I can only begin to imagine the weight of a butler/belfast sink of that length...
- Has thanked: 15964 times
- Been thanked: 10249 times
Re: Wooden wood
Have you looked at plastic, farm animal feed trays?mangocrazy wrote: ↑Tue Dec 19, 2023 12:37 pmNice idea, but I need something that will take at least 3 (preferably 4) 20" x 16" photographic trays/dishes. That requires a minimum length of 6 feet, and preferably closer to 8 feet.
Re: Wooden wood
The only ones I can see are not water tight - they're made of steel panels bolted together. I really need a single piece structure (preferably plastic, for manageable weight). I'll keep looking though...Taipan wrote: ↑Tue Dec 19, 2023 12:44 pmHave you looked at plastic, farm animal feed trays?mangocrazy wrote: ↑Tue Dec 19, 2023 12:37 pmNice idea, but I need something that will take at least 3 (preferably 4) 20" x 16" photographic trays/dishes. That requires a minimum length of 6 feet, and preferably closer to 8 feet.
Re: Wooden wood
This is the kind of thing I'd want to replicate. In an ideal world I'd just order the larger of the two sizes, but the cost (£668) is a trifle daunting...
https://www.theimagingwarehouse.com/Pro ... room-Sinks
- Yambo
Re: Wooden wood
mangocrazy wrote: ↑Tue Dec 19, 2023 11:00 am The main requirement is to support dishes of photographic chemicals as a succession of prints are made with the prints passing through 3 or 4 dishes as they go through the process. Once the session is over, the whole sink will be thoroughly washed down and rinsed.
Personally I'd make your long sink thingy out of one sheet of plywood. cut the pieces, put it all together, fillet the inside seams with thickened epoxy then something like 6oz fibreglass on the inside while the filleted seams are still wet. When that's all set up (24 hours or so) another couple of coats of epoxy all over the inside. Tutorials here: https://www.clcboats.com/shoptips/
Epoxy is pretty resilient to a lot of chemicals in my experience (although I haven't tried 'em all ). If you shape the panels right it could double as a small boat.
An easy peasy project, it'll take 4 days maximum (it's best to let the epoxy set up over 24 hours. You could save some money by using polyester resin instead of epoxy. Most shop built fibreglass boats are made with polyester resin. You just have to be careful with the hardener, MEKp as you only need about 2% or 3% hardener to resin ratio (3% will go hard faster) and MEKp is quite a nasty chemical. I measure small quantities with disposable syringes.
Also, have a look at Andy's YouTube videos on Boatworks Today, he's a dab hand at this sort of thing.
Re: Wooden wood
Get that welded up?mangocrazy wrote: ↑Tue Dec 19, 2023 12:58 pm
