Looks like fun...
- Has thanked: 2635 times
- Been thanked: 1523 times
Looks like fun...
- Has thanked: 2405 times
- Been thanked: 3630 times
Re: Looks like fun...
130kg wet weight - now you're talking...
- G.P
- Has thanked: 2029 times
- Been thanked: 1310 times
- Has thanked: 10265 times
- Been thanked: 6886 times
- Cousin Jack
- Has thanked: 2551 times
- Been thanked: 2286 times
Now if only the mainstream manufacturers would produce a roadgoing bike similar to that. Yes, it will be heavier, yes it will be less powerful, but 65bhp and 160kg should be do-able.
May I refer sir to the (now discontinued) KTM Duke 690 spec sheet? 160kg wet weight and 75bhp (actually about 72-73 rwhp)Cousin Jack wrote: ↑Mon Dec 04, 2023 3:13 pm Now if only the mainstream manufacturers would produce a roadgoing bike similar to that. Yes, it will be heavier, yes it will be less powerful, but 65bhp and 160kg should be do-able.
- Cousin Jack
A) Discontinuedmangocrazy wrote: ↑Mon Dec 04, 2023 3:20 pmMay I refer sir to the (now discontinued) KTM Duke 690 spec sheet? 160kg wet weight and 75bhp (actually about 72-73 rwhp)Cousin Jack wrote: ↑Mon Dec 04, 2023 3:13 pm Now if only the mainstream manufacturers would produce a roadgoing bike similar to that. Yes, it will be heavier, yes it will be less powerful, but 65bhp and 160kg should be do-able.
B) KTM.
Need I say more? I want proper Honda-grade reliability.
Based on a very limited sample size (one) I'd say KTM reliability, fit and function is on a par with most other manufactureres, even Honda. Obviously not Honda quality of the earlier VFR era, but in the same postcode as modern Honda. The discontinued part is, I agree, a deal-breaker if you want new.Cousin Jack wrote: ↑Mon Dec 04, 2023 3:38 pmA) Discontinuedmangocrazy wrote: ↑Mon Dec 04, 2023 3:20 pmMay I refer sir to the (now discontinued) KTM Duke 690 spec sheet? 160kg wet weight and 75bhp (actually about 72-73 rwhp)Cousin Jack wrote: ↑Mon Dec 04, 2023 3:13 pm Now if only the mainstream manufacturers would produce a roadgoing bike similar to that. Yes, it will be heavier, yes it will be less powerful, but 65bhp and 160kg should be do-able.
B) KTM.
Unfortunately I don't see anything in Honda's current range that comes close to your requirements...
- Cousin Jack
Nor me. The CB500F (which I have) or the CB750 Hornet are the nearest contenders. Both a bit lardy, and the CB500F is built down to the A2 limit.mangocrazy wrote: ↑Mon Dec 04, 2023 3:48 pmBased on a very limited sample size (one) I'd say KTM reliability, fit and function is on a par with most other manufactureres, even Honda. Obviously not Honda quality of the earlier VFR era, but in the same postcode as modern Honda. The discontinued part is, I agree, a deal-breaker if you want new.Cousin Jack wrote: ↑Mon Dec 04, 2023 3:38 pmA) Discontinuedmangocrazy wrote: ↑Mon Dec 04, 2023 3:20 pm
B) KTM.
- wull
- Has thanked: 880 times
- Been thanked: 1544 times
