Did ya buy it?Bustaspoke wrote: ↑Sun Nov 26, 2023 4:25 pm I called in at Wigan Yamaha earlier & this was parked next to the door
It looked lovely
- Has thanked: 9674 times
- Been thanked: 9698 times
- Has thanked: 3132 times
- Been thanked: 1624 times
No,I would have been seriously interested if it was available at the time I ended up buying my 675R Street Triple,but I didn't like the looks of the MT09's then.
Now that I'm an old fart I'm more interested in a Tracer 7,my 675R Street Triple is fast enough for me
- Tricky
- Has thanked: 2537 times
- Been thanked: 2540 times
- Has thanked: 1445 times
- Been thanked: 1329 times
This:
What's so interesting about a Yamaha Venture you might be asking...
well this is the accompanying blurb (in reply to a post about a Vmax with nitrous...):
Fun engines but the carbs are a nightmare on mine.
Might be because I've slipped a vmax engine into a Venture though.
Seem like I can either get it to run well or get decent fuel mpg. Have never been able to marry the two up. Shouldn't be too surprised though as even the stock venture wasn't exactly what I would call "good on gas". Best I ever managed was 35 mpg. With the Vmax engine it's 25-30 mpg on a good day with light throttle. It's usually down around 22mpg when I'm "having fun"....definitely no longer a long distance touring bike. Tank is bigger than the vmax, but not that much bigger.
It's a full vmax setup, from the crank right up to the airbox. Carb work is a PITA though because the frame isn't "kicked up" the same amount over the carbs like the vmax frame. Getting them out is a major effort involving much cursing and tool throwing. Jetting the thing was a major pain because of that and something I care not to get into again.
I use an Ignitech with programmable servo control to run everything. Vboost is functional and completely programmable. So is the ignition curve. Took a while to get all the programmable parts dialed in, but runs like heck once sorted. It's also running a Vmax rear diff, but I slipped a complete royal star gearset into the cases. Combined with the rear diff, it gives me nice low "digger gears" until 3rd (great for handling the extra heft over a stock vmax), then a deep overdrive in 5th. 4th is pretty much the same as a stock venture. This was also in the years when they had the second gear/washer issue and the shift sector issues, so swapping the newer transmission dealt with all those early issues in one swoop.
The bike itself is actually an 83, I've just swapped on the 86+ rear bags.
Fun bike, even with the extra weight. Funny as heck when a kid on a 600cc hyperbike pulls up at the stop lights, he gives it a couple hard revs and you leave him sucking tire smoke at the green and wondering WTF just happened......it's a perfect stop light sleeper. I just wish I could get wider rubber on the back. Was working on a custom rear rim for a 180 tire, but haven't touched that project in a couple years now. Kinda lost interest when I saw how much I would have to do the rear arm/driveshaft area to get that much rubber in there.
Gotta be upright and pointed where you want to go if you grab a handful of throttle though or it will leave big black snakes and toss you into the ditch.
Great fun.
The giggle gas you have on yours would be too much for this bike though. It would just make it dangerous on anything but a straightaway....
I wonder did the thought process at work here involve the use of industrial scale pharmaceuticals?
- Has thanked: 15601 times
- Been thanked: 9847 times
I was thinking is that what northern ireland weather did to your bike!
- Has thanked: 10110 times
- Been thanked: 6649 times
- Has thanked: 532 times
- Been thanked: 7215 times
Stolen off Friendface...
"Boxer engine in the K75S frame from 1986 with Ducati Biposto rearend and Suzuki Hayabusa fork and Kawasaki ZRX1100 frontmask"
I'm not sure why you'd put an R engine in a K frame... unless just because you can?
- 407408632_3673996799551689_8990385589926409168_n.jpg (576.46 KiB) Viewed 598 times
- 407413020_3674002372884465_1405515196796562924_n.jpg (585.81 KiB) Viewed 598 times
- Has thanked: 2318 times
- Been thanked: 3373 times
Looks a tidy job - much better than a lot of the stuff you see.
- Has thanked: 2632 times
- Been thanked: 1498 times
In a weird way I like it... but why is the right question!
- Has thanked: 6261 times
- Been thanked: 4613 times
I quite like it too. I guess the answer is, if you can then why not?
- Has thanked: 626 times
- Been thanked: 4063 times
A frontmask?
I quite like the bike too. Kawa frontmask and all.
- Potter
- Has thanked: 2216 times
- Been thanked: 4610 times
It's a bold look but actually I quite like it.
It's probably ruined by some fat bloke in combat pants riding it though
Mostly old blokes,they're the ones who can afford them!
- Has thanked: 1204 times
- Been thanked: 798 times
That's more than just tidy - it's verging on immaculate.
Is it me or does something not look right looking at it from in front ?mangocrazy wrote: ↑Mon Dec 18, 2023 3:18 pm That's more than just tidy - it's verging on immaculate.
