Anyone rode/owned a....
Demannu
Has thanked: 65 times
Been thanked: 1235 times
Re: Anyone rode/owned a....
Post by Demannu »
KungFooBob wrote: Thu Nov 30, 2023 7:26 pm
Dodgy69 wrote: Thu Nov 30, 2023 7:22 pm
Demannu wrote: Wed Nov 29, 2023 8:54 pm
Ignition off I guess?
The electric suspenders go full height in off mode
Never knew that. 👍
The ESA on my GS doesn't go full height on when turned off, I'd have thought the XR used a similar system?
It was couchy who told me, blame him if its erroneous!
wull
Has thanked: 880 times
Been thanked: 1545 times
Post by wull »
The Beemers when ignition is off goes full height and relatively solid. When you want to adjust sag you have to do it with the ignition on.
Has thanked: 6381 times
Been thanked: 4761 times
Well, hot dang. I never noticed on my K12 with ESA. I'm pretty sure it didn't go up in the air if I switched it off while I was sat on it though. Maybe I'm not suspension sensitive. :)
Has thanked: 1749 times
Been thanked: 2085 times
I've not noticed this, will check tomorrow. But then, i do start it up before i swing a leg. 🤷🏻‍♂️
Has thanked: 2915 times
Been thanked: 2059 times
So full height when *not* turned on.
Ok.
Been thanked: 7535 times
<Ignoring the ESA argument>
Now MM93 is on a Ducati, I quite fancy a Repsol Fireblade (So I can pretend to be Mick Doohan).
https://www.ebay.co.uk/itm/155794234002
It's just lacking the leccy gizmos, it's peers got.
wull
Post by wull »
Dodgy69 wrote: Thu Nov 30, 2023 8:52 pm I've not noticed this, will check tomorrow. But then, i do start it up before i swing a leg. 🤷🏻‍♂️
You’ll notice it sag when you turn the ignition on, that’s the reason the sag has to be set with it on, that’s how it’s to be done on the s1k’s at least as the electronic valves are only active when it’s on.
Demannu
Post by Demannu »
As an aside, nearly all bikes go 'full height' when you get off them (barring some static sag).
The beemer doesnt compress until you turn on the ignition, unlike normal suspension.
It all makes sense now. I'd get on my bike and turn the key/fire it up and iirc you'd hear the suspension whine and it would 'settle'. Getting off I'd switch off and get off and, obvs, the bike would rise as expected. Up there I thought it was suggesting if you sat on it and turned it off it would rise.
You'd also feel it working if you changed settings.
Just checked mine. Pushed out of garage, ignition still off and it's at my normal riding height. Turn ignition on, no change. Didn't start engine though.
McSatan
Has thanked: 17 times
Been thanked: 247 times
Post by McSatan »
My darling wife has one. It's a bit rapid. She loves it.
Demannu
Post by Demannu »
McSatan wrote: Sat Dec 02, 2023 3:23 pm My darling wife has one. It's a bit rapid. She loves it.
How tall is Mrs McS?
McSatan
Post by McSatan »
Demannu wrote: Sat Dec 02, 2023 4:35 pm
5' 6" She's an ex traffic cop though, and will happily whizz around on bikes that she can't touch the ground on without slipping off the seat, like her KTM 640 motard. And no, I don't try to keep up with her :)
wull
Post by wull »
Dodgy69 wrote: Sat Dec 02, 2023 11:25 am Just checked mine. Pushed out of garage, ignition still off and it's at my normal riding height. Turn ignition on, no change. Didn't start engine though.
On the s1000rr the valves become active when the ignition is on, so if you sit on it with the ignition off and then put it on you feel it sag slightly.
McSatan wrote: Sat Dec 02, 2023 5:17 pm
Hallelujah. Proof that you don't need to be 6ft 9in to ride a tall bike. :thumbup:
Has thanked: 16222 times
Been thanked: 3928 times
Count Steer wrote: Sat Dec 02, 2023 5:39 pm
The only bike I've ever owned that I can put both feet flat is the Monster!! I've been lucky to get tiptoes on both feet down on all the others, some it was just tiptoes of one foot :D
Some stroppy bloke (apparently a bike instructor) at a Blackbird rally was having a go at me when I said I couldn't get both my feet flat on the TLs (I know, but I used to have a BB!!) - pretty much everyone else around the fire took a few steps back over the next few minutes of conversation!
Especially when he boasted that he'd told a woman who turned up for bike training on a bike that she couldn't get both feet flat to go away and buy a bike that 'fitted' her!!
Given that so many of the guys on the campsite that weekend were short and were riding Blackbirds, this guy was seriously on a losing conversation! And being that he was was very opinionated and somewhat chauvinist, I didn't react that well to him :lol: :lol: :lol: :lol: Did cause a lot of amusement to the others tho!! :obscene-drinkingcheers: :obscene-drinkingcheers: :obscene-drinkingcheers: :obscene-drinkingcheers:
It really doesn't matter as long as you know which foot you're going to put down and plan accordingly. People seem to get into a sweat about it. I suspect it's as much about bike control as anything. The chap that ran the Yamaha Off-Road days (Barry) was 'not tall' but the bikes were. It didn't bother him. I couldn't get both feet down on them...it didn't bother me either.
I'm 6'3" with a 34" inside leg. I'm fine with most stuff.
When I put my GS on 'Two Helmets & Luggage' for the preload and then the firmest mode, I can just get both balls of my feet to the ground (I have the seat on the highest setting too).
It must be horrible being a smidget... I often say to my 5'3" wife.
Has thanked: 2552 times
Been thanked: 6257 times
You shouldn't talk down to her like that.
Mr. Dazzle wrote: Sat Dec 02, 2023 7:23 pm You shouldn't talk down to her like that.
It's the only joy I have in marriage.
