Probably something to do with the wing design, angle of attack, use of flaps/ailerons. Stuff like that I suspect.
- Has thanked: 251 times
- Been thanked: 323 times
Re: Great bike pictures!
- Has thanked: 2632 times
- Been thanked: 1498 times
Badly.
AFAIK the aerofoil of your average plane wing is designed to produce optimum lift right way up, so you can't simply turn it upside down and expect it to fly. However, there are control surfaces which disrupt or enhance lift.
Stunt planes have - and I'm sure someone will correct me - aerofoil surfaces which are closer to symmetrical.
- Has thanked: 10113 times
- Been thanked: 6649 times
Photoshop
This is what happens when a B52 banks too steeply.
Photoshop?The Spin Doctor wrote: ↑Tue Nov 28, 2023 5:22 pmPhotoshop
No. YorickPhoneShop
- Has thanked: 5944 times
- Been thanked: 4926 times
Badly.
One theory about the origin of the expression 'going pear shaped' was pilots trying to fly a loop but having the top flatten.
Now you tell us why most helicopters can't do a barrel roll
- Bigyin
- Has thanked: 1418 times
- Been thanked: 2620 times
Partly why Douglas Bader crashed back in the day and lost his legs .....did a slow barrel roll but started it too low while showing off and didnt account for the loss of lift when the wing was crossing over the upside down part of the roll. Ended up in a tangle of wreckageThe Spin Doctor wrote: ↑Tue Nov 28, 2023 3:23 pmBadly.
- Has thanked: 15604 times
- Been thanked: 9848 times
And showing why 'rules are for the
obeyance of fools, and the guidance of wise men' isn't always good advice. They had a rule about the minimum height for certain manoeuvres.
@The Spin Doctor will be along shortly to quote from the subsequent tribunal
As an aside, a mate (LabRat on Visordown) apprenticed as a saddler. He occasionally repaired DB's 'spare legs' bags. Said he was a miserable ... chap.
- Has thanked: 2609 times
- Been thanked: 6012 times
Boeing famously did a barrel roll in an 'airliner', the plane which preceded the 707 as a tech demonstrator. So it can be done. Might want to stow your tray table first though.
- Has thanked: 532 times
- Been thanked: 7217 times
Mr. Dazzle wrote: ↑Wed Nov 29, 2023 7:38 am Boeing famously did a barrel roll in an 'airliner', the plane which preceded the 707 as a tech demonstrator. So it can be done. Might want to stow your tray table first though.
He says it's a "1g manoeuvre" so your drink might be ok.
- Has thanked: 7726 times
- Been thanked: 2401 times
There's a video somewhere of a pilot in a light jet (Lear or similar), flying a nice smooth barrel roll, while pouring water from a jug into a glass. He managed to do it while you can see the horizon rotating through the cockpit glass.Horse wrote: ↑Wed Nov 29, 2023 8:01 amMr. Dazzle wrote: ↑Wed Nov 29, 2023 7:38 am Boeing famously did a barrel roll in an 'airliner', the plane which preceded the 707 as a tech demonstrator. So it can be done. Might want to stow your tray table first though.
Edit : here it is :
- Been thanked: 2499 times
I think I remember reading that Bob Hoover was the test pilots' test pilot.
- ChrisW
- Has thanked: 2727 times
- Been thanked: 1918 times
I've been going through old photos that we've found - Isle of Man, I'm guessing 1977?
Before you make fun of my hair I'll point out my brother's.
Failing that I appear to be armed.
- Screenshot 2023-12-03 at 18.34.32.jpeg (1.03 MiB) Viewed 736 times
- Bigyin
- Has thanked: 626 times
- Been thanked: 4063 times
Is the bike moving in that pic, it looks a bit of a staged static shot.
