Prepping a bike to live outside
Has thanked: 1946 times
Been thanked: 1292 times
Post by Jody »
I'll be picking up a drz400 sm tomorrow and it's going to spending some time living outside.
I'm wanting something to protect it, people used to talk about ACF50 (I think). Is this right for what I need, if not, what do you recommend.
TIA
Has thanked: 5434 times
Been thanked: 13025 times
Re: Prepping a bike to live outside
Jody wrote: Tue Nov 03, 2020 8:17 am I'll be picking up a drz400 sm tomorrow and it's going to spending some time living outside.
TIA
ACF50 is still great, each and every single piece of metal, all of them, from engine bolts to swingarm pivots, to fork clamp bolts and everything inbetween. Should see it right.
I've had bikes outside for 12-18 months without any issues, but i did take the cover off on dry days to let the bike air a bit.
Post by Jody »
Perfect, thanks
quart bottle and spray dispensing bottle ordered :)
Been thanked: 4116 times
Don't ride a DRZ400 anywhere near road salt, my one looked like it had been 20 years under the sea after a single winters commuting, apart from that buy a bike cover.
Has thanked: 1741 times
Been thanked: 2065 times
Jody wrote: Tue Nov 03, 2020 8:26 am Perfect, thanks
and put bottle in hottish water for a minute or two to thin it. Sprays better. 👍
Has thanked: 4320 times
Been thanked: 2826 times
I've heard ACF goes everywhere when sprayed and is very thick and whilst that's a benefit in some places, is it better to spray onto a sponge/cloth and wipe it on?
Bikesocial did a big corrosion spray test and Techcote and XCP rust blocker were best. They out performed ACF by a margin. See the chart at the bottom of this. ACF lasted 5 weeks vs 19 for techcote and 25 for XCP. There is a youtube vid as well of the test which was fairly extreme.
https://www.bennetts.co.uk/bikesocial/r ... ant-review
Has thanked: 2545 times
Been thanked: 6202 times
Just go the whole hog and waxoil it. :D
Has thanked: 2634 times
Been thanked: 1523 times
I just give it a decent clean then spray it with Mr Sheen. Both bikes look pretty good considering one's a 52 plate and the other's a 59.
The Spin Doctor wrote: Tue Nov 03, 2020 2:48 pm I just give it a decent clean then spray it with Mr Sheen. Both bikes look pretty good considering one's a 52 plate and the other's a 59.
Practically brand new
Has thanked: 2928 times
Been thanked: 1875 times
ACF-50 and Bilt Hamber light underseal spray for the underside of the engine.
Bigyin
Has thanked: 1409 times
Been thanked: 2661 times
Post by Bigyin »
Before using ACF50 get a bucket of very warm water and lob the can into it to warm up the solution. It will spray on finer and less gloopy. Also cover your brakes and discs. For the hard to reach bits spray into the lid of the can and use a small paintbrush to paint it on
My 1st Multistrada in its prepped for ACF application ;)
I rode it through 3 winters commuting all year round on heavily salted roads and even for a Ducati it didnt melt
Beancounter
Has thanked: 2838 times
Been thanked: 551 times
Post by Beancounter »
If you've access to a compressor it's a lot easier to spray on to your bike, the ACF goes on a lot finer and you get less wastage. I've even used a battery-powered airbrush before with good results (though it's a bit slower mind).
Beancounter
Supermofo wrote: Tue Nov 03, 2020 11:42 am I've heard ACF goes everywhere when sprayed and is very thick and whilst that's a benefit in some places, is it better to spray onto a sponge/cloth and wipe it on?
RiDE did a similar test where XCP won with ACF-50 in second place. I've used XCP, it's a lot thicker so stays in place a lot better. It stinks and is a bit of a bastard to wash off after a while because it's quite tacky. I think XCP is better for spray-and-forget-until-Spring.
Beancounter wrote: Wed Nov 04, 2020 2:26 pm
Yes from what I've read/youtube'd I think ACF or even I think FS364 is best for me. My bike sits in the garage and doesn't turn a wheel in the winter so reckon XCP sounds like more hassle than it's worth. Considering that, FS365 has been my go to. Spray it on and leave till spring, not like I have to worry about it getting washed off, it's just to help against the damp.
This year though I was thinking of some ACF as have a couple of bits of rust in the engine bay of my car I was going to do just to stop it getting worse.
Whysub
Has thanked: 1044 times
Been thanked: 854 times
Post by Whysub »
I just have a decent covers on my bikes, both of which live outside now. The covers are there to protect them from the sun rather than wet weather.
I think the salt and crap they chuck on the roads does for the finish now. When I was commuting into work, there was a hose pipe in the parking area that I used to spray the bike down with each day. It seemed to keep the bike free from the worst damage the stuff they sprayed on the road could inflict. Prevention is better than cure.
