- the_priest
- Has thanked: 1874 times
- Been thanked: 2170 times
Several deliveries today. Ikea, table from Amazon, chairs from Etsy and post! My bed building skills are going to be honed just now as I help my son with his first "proper" bed. He has always had old used bedframes. So he was happy to get a brand new bed that he chose!
Built the table, one of the chairs, stuck it in the kitchen. Will do another chair later on.
Boiler technician is here to sort the stuck radiator valves and service the boiler. May add an inhibitor to the system as well.
Wife is working so will fetch her from the station later on, so she does not have the 15 minute walk home, she is feeling frail after the move and her brain tumour is due another MRI which has not happened on schedule, so we are concerned.
- Been thanked: 2618 times
Packed the van ready for the ferry tomorrow. CalMac are running a temporary timetable which means I have an 0400 start.
- Has thanked: 16218 times
- Been thanked: 3926 times
Worked and cooked! But the cooking ended with a blooming lovely tea!!
Fish Pie - and six more for the freezer
- Has thanked: 1508 times
- Been thanked: 1414 times
Had a plumbing blockage (house, not me). Dropped the P trap under the kitchen sink, all clear. Popped the cover off the outside clean-out, then got a hose to stick in the hole. Barely touched the fucking tap by the clean-out & the pipe broke... INSIDE THE WALL!! ARRRGGHH!!
Ran back through the house, grabbed the valve tool as I went through the garage & turned the water off.
Walked back into the kitchen to find a puddle about 1 sq yard. fuckbuggerybollocks.
Started mopping up, good news is there's no more water coming out from under the cabinets along that wall.
Awaiting plumber. Pipe nipple won't pull out the wall, so that means cutting a hole in the stucco. I can do that with a diamond disc on an angle grinder instead of whaling away with a BFH & masonry chisel.
Thinking if I do that now I might be able to sort the problem before the plumber shows up in 2-4 hours time.
- Has thanked: 9830 times
- Been thanked: 10146 times
Some folk have all the fun.ZRX61 wrote: ↑Tue Nov 21, 2023 7:19 pm Had a plumbing blockage (house, not me). Dropped the P trap under the kitchen sink, all clear. Popped the cover off the outside clean-out, then got a hose to stick in the hole. Barely touched the fucking tap by the clean-out & the pipe broke... INSIDE THE WALL!! ARRRGGHH!!
- the_priest
Radiators need to be flushed, system is full of crud after being drained and left for a couple of months. No inhibitor either. So waiting for heating agents to call back. At least this is something I don't need to pay for!
Finish building the bed, then a nice glass of port and bed!
Got the mullared pipe nipple out of the wall. Looks like it was one more sonic boom or minor quake from failing. Thank fuck it happened when I touched it & not in the middle of the night.
- gremlin
- Has thanked: 809 times
- Been thanked: 4804 times
In a fit of enthusiasm I took the plastic loft hatch down, which has yellowed over the years, gave it a rub down, cleaned it up and sprayed it back to white with a rattle can of paint.
Now waiting for it to dry and realising just how bloody cold it is on this landing with a gaping hole up into the loft.
Maybe I should have waited for summer to tackle this job.
- Has thanked: 10266 times
- Been thanked: 6886 times
I'd replace it with an insulated one. Heat just going up wasted.gremlin wrote: ↑Wed Nov 22, 2023 2:58 pm In a fit of enthusiasm I took the plastic loft hatch down, which has yellowed over the years, gave it a rub down, cleaned it up and sprayed it back to white with a rattle can of paint.
- gremlin
It is insulated, you doughnut.Yorick wrote: ↑Wed Nov 22, 2023 3:30 pmI'd replace it with an insulated one. Heat just going up wasted.gremlin wrote: ↑Wed Nov 22, 2023 2:58 pm In a fit of enthusiasm I took the plastic loft hatch down, which has yellowed over the years, gave it a rub down, cleaned it up and sprayed it back to white with a rattle can of paint.
Only the insulation ain't no good when the loft hatch is in the garage waiting for the paint to dry.
- Has thanked: 2551 times
- Been thanked: 6249 times
When we had our HS+L painted/decorated we got the man to fit a new loft hatch with an integrated ladder. This one has a big rubber seal around the edge, you have to push it shut and turn the catch 90° (with your big long loft pole, natch) to shut the door.gremlin wrote: ↑Wed Nov 22, 2023 2:58 pm In a fit of enthusiasm I took the plastic loft hatch down, which has yellowed over the years, gave it a rub down, cleaned it up and sprayed it back to white with a rattle can of paint.
Even thought the old one was also insulated, it makes a noticeable difference! We just didnt' notice the steady trickle of cold air coming down before.
- gremlin
Somewhat annoyingly, some of the foam seal around the hatch stuck to the surround and get ripped off when I took it down. I'll have to figure a way to get the seal tight when I put it back (hopefully this evening, getting a bit nippy now the sun's going down!), probably with a door seal strip from B&Q or such like....Mr. Dazzle wrote: ↑Wed Nov 22, 2023 3:34 pmWhen we had our HS+L painted/decorated we got the man to fit a new loft hatch with an integrated ladder. This one has a big rubber seal around the edge, you have to push it shut and turn the catch 90° (with your big long loft pole, natch) to shut the door.gremlin wrote: ↑Wed Nov 22, 2023 2:58 pm In a fit of enthusiasm I took the plastic loft hatch down, which has yellowed over the years, gave it a rub down, cleaned it up and sprayed it back to white with a rattle can of paint.
Our house is currently being decorated. I can taste dust and smell paint wherever I go in the house....
Please, can someone explain HS&L to me??
- ChrisW
- Has thanked: 2913 times
- Been thanked: 2053 times
- Been thanked: 7532 times
Apply whichever description to the correct poster
Thanx guys!
Thanx guys!
- Has thanked: 484 times
- Been thanked: 1427 times
If you shop around this handy sticky back rubber comes in different sizesgremlin wrote: ↑Wed Nov 22, 2023 3:43 pmSomewhat annoyingly, some of the foam seal around the hatch stuck to the surround and get ripped off when I took it down. I'll have to figure a way to get the seal tight when I put it back (hopefully this evening, getting a bit nippy now the sun's going down!), probably with a door seal strip from B&Q or such like....Mr. Dazzle wrote: ↑Wed Nov 22, 2023 3:34 pmWhen we had our HS+L painted/decorated we got the man to fit a new loft hatch with an integrated ladder. This one has a big rubber seal around the edge, you have to push it shut and turn the catch 90° (with your big long loft pole, natch) to shut the door.gremlin wrote: ↑Wed Nov 22, 2023 2:58 pm In a fit of enthusiasm I took the plastic loft hatch down, which has yellowed over the years, gave it a rub down, cleaned it up and sprayed it back to white with a rattle can of paint.
https://www.ebay.co.uk/itm/403319449154 ... BMsPihkv9i
Dono if they sell it also but seals direct is a handy site for all seals.
https://www.sealsdirect.co.uk/shop/cate ... ubbers-472
Loft hatch makes the landings a bit tricky, but I found a good pilot
- MingtheMerciless
- Has thanked: 2943 times
- Been thanked: 1883 times
Turned off electricity in a planned fashion for large chunks of the railway and then turned it back on again later, then turned off some more electricity (for an unusual event but still planned) after some twit wrote his 21 plate BMW off on one of our bridge walls, ejecting several very heavy blocks of brickwork (several tonnes worth) onto the tracks below! It is a very busy night shift.
- Has thanked: 65 times
- Been thanked: 1235 times
Having to learn new French words today as la voiture failed the CT.
One of the good things about France is you get 2 months driving around time to fix it!
