shed insulation using polystyrene sheets
formula400
Has thanked: 444 times
Been thanked: 863 times
Re: shed insulation using polystyrene sheets
Post by formula400 »
Something like this ?? https://www.screwfix.com/p/soudal-geniu ... lsrc=aw.ds
What kind of vapour barrier???
Does it go barrier/insulation sheets/OSD? Or insulation sheet/ barrier/OSD
CBR650r :mrgreen:
Has thanked: 1346 times
Been thanked: 1722 times
Inside to outside.
OSB, vapour barrier, then insulation sheets between the studs.
I usually staple the vapour barrier to the studs(as few staples as you can get away with) then the OSB over it. Oh don't forget to tape the joints on the vapour barrier
One place I worked at had what was called Smartply which is OSB thats got a solid plastic surface that acts as a vapour barrier and you just tape the joints up but I've been told it was very expensive, not sure how much I believe that.
Thick enough OSB and you can put a screw in it anywhere for shelves/whatever.
Oh and I always use Gun grade foam, partly because I already have the gun but I use a lot of it pretty regularly so its in my interests to have the gun which can be shut off without wasting the rest of the tin.
I don't take a tin off the gun til I have another one ready to go on, hardly ever need the cleaner.
I never ever leave the gun without a tin of foam on it.
I clean the end of the nozzle by rubbing on timber as it cleans it without unnecessary abrasion that knackers the front valve.
Oh and I never lend them to fucking divvys.
Has thanked: 2550 times
Been thanked: 6244 times
demographic wrote: Sun Nov 19, 2023 11:50 am Oh and I never lend them to fucking divvys.
Well that's me right out.
Mr. Dazzle wrote: Sun Nov 19, 2023 11:52 am
I've lent a few out and theres always some rivet who runs the foam out and leaves it empty, or removes the can and can't find another or just so dense that they remove the old can and bugger off to have their butties so whatever is left in the gun goes off and thats my 20 quid gun knackered.
Oh and the best gun I've had yet is made by Yato and has a PTFE coated valve and the bit the can screws into is PTFE coated as well.
Lasts way better than any other, as long as you follow those rules up there ^.
formula400
Something like this???
https://www.screwfix.com/p/no-nonsense- ... -gun/28483
Never used anything like it before
CBR650r :mrgreen:
formula400
demographic wrote: Sun Nov 19, 2023 11:41 am Inside to outside.
Would this be what I want https://www.screwfix.com/p/capital-vall ... x-4m/59191
CBR650r :mrgreen:
Has thanked: 6376 times
Been thanked: 4751 times
formula400 wrote: Sun Nov 19, 2023 11:14 am Something like this ?? https://www.screwfix.com/p/soudal-geniu ... lsrc=aw.ds
I reckon that'd do. You may need a few. Hardly seems worth buying a gun if you are unlikely to use it again.
PS if you haven't got a staple gun and are likely to be cycling anywhere near the Surrey Hills in the near future you can borrow mine. :thumbup:
formula400
Last question
Timber that I’ll be filling is 60mm, sheets of foil backed insulation is 50mm
Is that gap ok?
CBR650r :mrgreen:
formula400
Count Steer wrote: Sun Nov 19, 2023 12:43 pm
Cheers for the offer, but unsure when I am out that way
CBR650r :mrgreen:
formula400
CBR650r :mrgreen:
formula400 wrote: Sun Nov 19, 2023 1:37 pm
If you're buying one I can recommend the Bosch cordless. It should be man enough for the job and it's not a hulking big thing so it's nice to use if you're doing a fair number of staples. They're about £57 though.
formula400 wrote: Sun Nov 19, 2023 12:22 pm
The black stuff is usually thicker than you actually need for walls as its for floors before the concrete goes down and gets stood on a bit through the process.
Mind, the stuff we often end up with is so thin that it doesn't staple well so the black stuffs better than that.
formula400
Just in B&Q 2.4 x 1.2m is bloody huge
Not sure what I was expecting 😂😂😂😂
Basically going to get a little bit and order the rest on line
CBR650r :mrgreen:
Has thanked: 2402 times
Been thanked: 3625 times
Don't get expanded polystyrene - it's shit. Celotex/Kingspan etc is the stuff to go for.
mangocrazy wrote: Sun Nov 19, 2023 4:37 pm Don't get expanded polystyrene - it's shit. Celotex/Kingspan etc is the stuff to go for.
Agreed. Jablite is polystyrene I believe. :hmmm:
formula400
I got a few small sheets of this to see how I get on.
https://diybuildingsupplies.co.uk/produ ... KIQAvD_BwE
What have I learnt from this small endeavour already 🤔🤔
Don’t use a saw, use a small sharpe knife nicked from the kitchen. Much much cleaner
CBR650r :mrgreen:
formula400 wrote: Sun Nov 19, 2023 7:29 pm I got a few small sheets of this to see how I get on.
Wait until Chef finds out what you've been doing with his /her knives. :D
formula400
2 of 18 roof bits done 🤣🤣🤣🤣🤣
Where should I be stapling the vapour barrier
CBR650r :mrgreen:
Through the vapour barrier onto the studs. So they hold the vapour barrier holds on til yer fixing the OSB on.
Oh and make sure theres something to fix the OSB to, especially on corners.
