Removing an awkward nut...
tricol
Has thanked: 235 times
Been thanked: 471 times
Re: Removing an awkward nut...
Post by tricol »
Obviously.....breaker bar and a 6pt long socket. Was a touch easier than thought! Helped having the air scoops off.
Yamaha MT09 SP
Has thanked: 2418 times
Been thanked: 3662 times
Nice work, Col. Well done you. You can build things up in your mind as being impossible when in fact they're very doable. As you found out! Onwards and upwards :D
tricol
Post by tricol »
Risers installed, what a pain in the arse. When the bars are free, you really need 2 people to then pop the new risers in so you have somewhere to rest the bars again. And of course, I ended up scratching my dashboard. The lightest touch of the bar, and I mean the lightest of touches, and it scratched it. Really really annoyed with myself. Might try some PLast X or something, see if that helps.
But other than that, the risers look great and I can feel a big difference on the bar position just sitting on it in the garage.
Yamaha MT09 SP
Has thanked: 5471 times
Been thanked: 13170 times
tricol wrote: Fri Nov 17, 2023 1:32 pm Risers installed, what a pain in the arse. When the bars are free, you really need 2 people to then pop the new risers in so you have somewhere to rest the bars again. And of course, I ended up scratching my dashboard. The lightest touch of the bar, and I mean the lightest of touches, and it scratched it. Really really annoyed with myself. Might try some PLast X or something, see if that helps.
Mmmmmm i'd be very careful and read up... i'm not sure the screens can be polished up
Has thanked: 6245 times
Been thanked: 5120 times
weeksy wrote: Fri Nov 17, 2023 10:03 am i meant about how you got the nut off :D
Does using 'ignore' work? :?
