Removing an awkward nut...
So, more stupid questions.
I'm attempting to fit my new Gilles risers. I need to remove the stock ones and to do that I need to undo the nut underneath the top fork yoke (x2). It's specced to 40nm. It's really tight for space. I can just about get my 14mm onto it square, but not much of an angle to turn it. Anyway, my first couple of attempts were futile. I've looked at a breaker bar, but I don't think I have the room to use one due to the chunkiness of the breaker bar end. The headstock and fork legs are very much in the way.
Before spending/wasting more money on this, should I just get a workshop to do it?
I f##kin hate spannering.
Yamaha MT09 SP
- Has thanked: 7858 times
- Been thanked: 2555 times
- Has thanked: 316 times
- Been thanked: 572 times
Re: Removing an awkward nut...
Sounds like you're making it harder by taking the shortcut of not removing the top yoke. If you're not competent or not confident to do that then better bring it to a workshop.
- ChrisW
- Has thanked: 2948 times
- Been thanked: 2078 times
Looks like you'd get in there with a long socket or perhaps a 3/8 bar. Can't imagine there's any need to remove the top yoke.
The still's from here if it helps:
- Screenshot 2023-11-14 at 18.27.51.png (1.11 MiB) Viewed 610 times
- Has thanked: 2418 times
- Been thanked: 3662 times
The area under the top yoke will be pretty crowded, so you might find that a long extension bar means you can get at the nut and the ratchet driver can operate in a much bigger arc. As long as there is line of sight from the ratchet to the nut, it doesn't matter how long the extension bar is. I bought a selection of different sized 'long' extension bars and they have been so useful.
These are the ones I bought:
https://www.ebay.co.uk/itm/403727890331
You need a length of scaffold pole (or similar) to slip over the ratchet handle. Leverage is your friend, as Archimedes might have said...
- ChrisW
Give me a shout if you want to borrow any tools, I'm only in Nantwich.
- Has thanked: 10340 times
- Been thanked: 6916 times
Well I've managed to remove the air scoops from in front of the tank (thanks pop rivets) so that gives me loads more space to undo these nuts. I've also decided to go and get a 6pt socket for this nut as that will give me a better chance of removing these. All the sockets I have are 12 pt and more chance of rounding the nut as it's quite a bit of torque.
Yamaha MT09 SP
I hope I will be fine now. A better socket with a breaker bar should work. Just down to me now.... *gulp*
I know this is trivial to many on here, but it's a big deal that I get this done myself.
Yamaha MT09 SP
- Has thanked: 609 times
- Been thanked: 4133 times
- Has thanked: 5471 times
- Been thanked: 13170 times
I bought these: https://www.gillestooling.com/shop/hand ... -kit?c=185 from Calsport. Must say, they're beautifully made, really high quality, which you'd expect from Gilles. Fully adjustable, up to 24mm lower and roughly the same forward and backwards. Planning on running them as low as possible and a touch more forward.
Yamaha MT09 SP
