Royal Enfield 500 trails.
- Cousin Jack
- Has thanked: 2550 times
- Been thanked: 2285 times
Re: Royal Enfield 500 trails.
Part 2 involves pouring warm water in your crotch, and other scatolgical delights.
- Has thanked: 6375 times
- Been thanked: 4750 times
Actually, thinking about it, that's a bit like riding a motorbike. Earplugs/helmet/visor/gloves + funny boots that make it difficult to walk. Woah! Riding a bike is preparation for getting old! Unfortunately the water in your lap, CJ, tends to be icy cold.Count Steer wrote: ↑Mon Oct 16, 2023 4:49 pmWife read out a bit out of a novel she was reading recently:
'Put cotton wool in your ears, pebbles in your shoes, vaseline on your specs and put on a pair of thick gloves. This is getting old....part 1'.
- Has thanked: 1745 times
- Been thanked: 2085 times
- Tricky
- Has thanked: 2564 times
- Been thanked: 2680 times
- Has thanked: 9819 times
- Been thanked: 10144 times
That because it's speed induced wind noise which is normally the loudest thing.
Now then, I've noticed that putting the key into the ignition is becoming a bit difficult. Goes in so far with ease but the last bit needs some force.
What's best, squirt some WD or similar or not. The mighty REs first sign of distress.
- Has thanked: 7814 times
- Been thanked: 2527 times
- Has thanked: 15949 times
- Been thanked: 10243 times
OK, can give that a go. Tbh, I have squirted gt85 and hasn't made much difference. On new external house doors they do say don't squirt any sprays, just that fine powder stuff. I might imagine, ignitions are slightly different.
Taipan wrote: ↑Sun Nov 12, 2023 11:30 amDeffo not oil, wd40 etc. Get some graphite powder.
https://tinyurl.com/ye26ukut
Too late, if I used the powder now it might be a right mash up.
In the passed I've always used sprays on ignitions and switches, maybe times have changed.
I used to use wd40 it was only when a locksmith pointed out the error of my ways i changed.Dodgy69 wrote: ↑Sun Nov 12, 2023 11:33 amTaipan wrote: ↑Sun Nov 12, 2023 11:30 amDeffo not oil, wd40 etc. Get some graphite powder.
Well the results are in....
Acf50 on key and left in ignition for an hour and it's much better. Reckon it's a bit more slimey than spray. Bit of thick oil might work aswel.
Cheers gents.
Cheers gents.
ACF50 will eat up any corrosion and prevent more forming. (and provide lubrication)
- Been thanked: 7526 times
Looks like you need to grow a beard...
- FB_IMG_1702310534280.jpg (83.46 KiB) Viewed 535 times
There used to be a trick where you scribbled on the key with a graphite pencil but most 'graphite' pencils these days aren't a solid graphite core but powdered graphite mixed with binders.
- Has thanked: 6187 times
- Been thanked: 5087 times
6H-HB-6BCount Steer wrote: ↑Mon Dec 11, 2023 5:14 pm There used to be a trick where you scribbled on the key with a graphite pencil but most 'graphite' pencils these days aren't a solid graphite core but powdered graphite mixed with binders.
Hs = hard, more clay
Bs = soft, more graphite
