The journey from small guy to teenager...
- Has thanked: 304 times
- Been thanked: 1007 times
Re: The journey from small guy to teenager...
But the fact is the application and duty cycle of roller/ball cartridge bearings used in MTB rear suspension is about as bad as you can get for a bearing.
Limited arc of movement, significant variation in loading, no possibility of race procession to move the loaded zone around, too small for the application, challenging operating environment etc.
Best you can do is postpone the inevitable....
- Has thanked: 2248 times
- Been thanked: 1242 times
Takes me back to my times of GM/RT2030 Levels 1&2 with Deryck Shead.millemille wrote: ↑Wed Oct 18, 2023 9:11 am I use Fuchs Renolit MP3 (now called GP3).
In a previous role as a consultant I specialised in tribology and spent a fair bit of time at both SKF and Timken looking at the condition of used train axle bearings to determine whether they could be allowed to run to higher mileages before overhaul/replacement.
Anyway, I was at Timken's place in Northampton looking at my bearings when a pallet of used bearings was delivered for overhaul and these things looked they'd been dug out of a peat bog after being buried for centuries.
"What are they off?" I asked.
"The trans Siberian express"
"Why on earth are they bothering to send them back, they've got to be fucked?"
Nope, absolutely immaculate inside. The grease Timken used at build was the Fuchs Renolit MP3 and that was as good a recommendation as I needed....
- Has thanked: 6381 times
- Been thanked: 4761 times
Slight railway lubricant diversion...I worked one summer holiday at a v large sewage processing place in Yorkshire (it was big enough to have it's own steam loco, 'Nellie'). They used to extract lanolin grease from the sewage (from the wool industry), it was the thickest, gunkiest grease I'd ever had the misfortune to get smeared on a pair of jeans.millemille wrote: ↑Wed Oct 18, 2023 9:11 am I use Fuchs Renolit MP3 (now called GP3).
They sold the stuff to BR for greasing rolling stock - but the trade died out with the wool industry.
I'll see your lanolin and raise you Crater grease.Count Steer wrote: ↑Wed Oct 18, 2023 9:37 amSlight railway lubricant diversion...I worked one summer holiday at a v large sewage processing place in Yorkshire (it was big enough to have it's own steam loco, 'Nellie'). They used to extract lanolin grease from the sewage (from the wool industry), it was the thickest, gunkiest grease I'd ever had the misfortune to get smeared on a pair of jeans.millemille wrote: ↑Wed Oct 18, 2023 9:11 am I use Fuchs Renolit MP3 (now called GP3).
Anyone who has ever had the misfortune to come into contact with crater still wakes up screaming in the middle of the night....
- Has thanked: 5451 times
- Been thanked: 13092 times
It's not cheap either!millemille wrote: ↑Wed Oct 18, 2023 9:52 amI'll see your lanolin and raise you Crater grease.Count Steer wrote: ↑Wed Oct 18, 2023 9:37 amSlight railway lubricant diversion...I worked one summer holiday at a v large sewage processing place in Yorkshire (it was big enough to have it's own steam loco, 'Nellie'). They used to extract lanolin grease from the sewage (from the wool industry), it was the thickest, gunkiest grease I'd ever had the misfortune to get smeared on a pair of jeans.millemille wrote: ↑Wed Oct 18, 2023 9:11 am I use Fuchs Renolit MP3 (now called GP3).
NBD....
After a long-ongoing debate with sponsor we've ordered this.
dmrCYAN by Steve Weeks, on Flickr
sect2 by Steve Weeks, on Flickr
One of the aims/goals for winter is for the boy to work on skills in terms of jumping, pumping, cornering, tabling (look it up ) , basically skills/technique training over winter. So with that in mind, things like the local pump track, skate park, then places like Adrenaline Alley (indoor skate/jump park) will give us the chance to get both a good bit of a workout as well as working on the skills side of things when the trails are a mud-slop-mess.
- MingtheMerciless
- Has thanked: 2944 times
- Been thanked: 1883 times
@millemille , purchased, I'll see how that lasts on the Trek's BB.
- Mr Moofo
- Has thanked: 1829 times
- Been thanked: 1469 times
No idea matey, that's Katy's job to deal with. But I'm pretty sure DMR are onboard for next year again. Hence getting their DJ bike.
- Has thanked: 9833 times
- Been thanked: 10147 times
Chest/back/knees. It's what the cool kids do. Well, so they tell me
- Mr Moofo
Let me tell him about how much it hurts to factor the ball joint of the humerus
Wear shoulder stuff !
( BTW breaking you elbow really , really hurts as well)
Playtime, that stuff.
Uplift/race full armour.
It may change back now as a lot of it was down to the heat factor from full armour, which is likely to be more welcomed now. But the full jacket really is very warm in summer
IMG-20231019-WA0003 by Steve Weeks, on Flickr
IMG-20231019-WA0002 by Steve Weeks, on Flickr
IMG-20231019-WA0004 by Steve Weeks, on Flickr
IMG-20231019-WA0001 by Steve Weeks, on Flickr
How to turn a horrific job into an absolutely effortless job.
I'm not sure exactly where this piece of alu came from but it's the absolutely perfect diameter for the job. So trimmed 2 lengths
IMG_20231019_152317 by Steve Weeks, on Flickr
IMG_20231019_151134 by Steve Weeks, on Flickr
IMG_20231019_151123 by Steve Weeks, on Flickr
Presses both sides in at the same time, really smoothly and nice..
The bearings in there were the cheaper Blue Seal type rather than the Enduro bearings which have now gone in there. But they'll get stripped and re-packed and kept as spares for now. I'm sure Trek make a tool for this job, but i can't see how it'll be any better at the job than my home-made version.
