A_morti wrote: ↑Sun Oct 08, 2023 7:39 pm
Yes. You want ps11 rather than ps13.
However you still haven't fully eliminated the caliper as the problem yet.
Rear brakes aren't a big system or hard to understand. A handful of bolts and you can take the whole lot off the bike to the bench and start pulling it apart.
Time to stop being scared and dig into it?
Indeed. I have to go to Chambery on Tuesday, but after work on Weds, Thursday, Friday (one or all!!) I will have another look at it all and see if I can be sure what is what.
I just kinda wanted to find a reasonably priced part in case I need it and the one in the photo is actually quite a bit cheaper than any recon ones I've found (cheaper postage as well as lots seem to come from the UK!
The description of the one in the photo is -
Brembo Rear Brake Master Cylinder PS 11 C Ø 11mm, color Black, fixing holes 40 mm, Top outlet, Ducati Monster Type
I've checked the info and it says it is the right type for my year of Monster, so it is at least an option if I can work out that this is the issue!!
Been told to look for a 12mm as it would be better for the 'two' pistons (caliper is not a single piston one), so will have a look for that too in case I can find one with the same fixing hole distance.
Extra wary really as now I've had a bit of transport, I do not want to fuck it up and not be able to use it at all! But since I'm riding without a rear brake (and so won't ride down in the rain) I guess it can only be a positive or samesame result!! Hopefully
