A picture without knowing the scale makes this a puzzler. First thought spoke spanner or maybe some sort of go/no-go gauge. But the numbers seem to be in inverse relationship to the size. Do spokes have some sort of grading where 1 is the biggest?
Tool purchases
Re: Tool purchases
- Has thanked: 1295 times
- Been thanked: 872 times
Re: Tool purchases
Yes spoke spanner about 10cm long.
Also got this recently to break a tyre bead, that showed it who’s boss
- ChrisW
- Has thanked: 2920 times
- Been thanked: 2061 times
Re: Tool purchases
Not a tool purchase, more a tool I'd quite like to have - an electrician I bumped into earlier was using this in-line torque adjustable insulated driver.
Want one.
Want one.
- Has thanked: 146 times
- Been thanked: 498 times
Re: Tool purchases
My understanding is they are a requirement for any work carried in a consumer unit / distribution board. All connections must be tightened to manufacturer specified torque setting which should be printed on the case for busbars / earth and neutral bars and on individual mcb / rcb / rcbo / rccb etc.
I suspect insurance companies will insist these are checked in the event of an electrical fire with liability resting on the spark who last did any work on the system / householder for DIY work.
Sadly / thankfully they can be readily picked up from toolstation / screw fix et al. Not cheap though.
Re: Tool purchases
For electrical connections, it is definitely about tightening up to spec as loose wires, even if they appear to be tight can start to arc, heat up and cause fires, hence the introduction of metal clad consumer units in iirc 18th edition.
For other types of connection, it may be about protecting the fixing from damage.
Wera offer a non-insulated range at 0.3 to 2Nm and a VDE insulated option at 0.3 to 3.5Nm, which kinda proves the point covered by my posts and the OP looking at an insulted driver…
- Has thanked: 255 times
- Been thanked: 143 times
Re: Tool purchases
What's illegal? In the UK?
I know there's some auxiliary fuel tanks they sell for adventure riding which they have to label as not for fuel legally.
Re: Tool purchases
To be fair it is both, yes there are terminals which loosen or haven't been tightened up correctly, but there are just as many which have been butchered too tight,Silly Car wrote: ↑Mon Aug 21, 2023 11:53 pm For electrical connections, it is definitely about tightening up to spec as loose wires, even if they appear to be tight can start to arc, heat up and cause fires, hence the introduction of metal clad consumer units in iirc 18th edition.
- Has thanked: 486 times
- Been thanked: 1430 times
- Has thanked: 1947 times
- Been thanked: 1292 times
Re: Tool purchases
Special tool for tightening the nuts that hold taps on.
I struggled for years with a snap on 1/4 set. This specific tool is head and shoulders better.
€13 for a tool I hardly use. I made the company pay, so I'm OK with it.
- Has thanked: 65 times
- Been thanked: 1235 times
- Has thanked: 1509 times
- Been thanked: 1415 times
Re: Tool purchases
porter_jamie wrote: ↑Tue Aug 22, 2023 7:16 am What's illegal? In the UK?
California...They've also outlawed all petrol powered yard tools including mowers & generators up to 26hp. & they just outlawed gas furnaces. This has lead to a run on them at the plumbing stores so people have one spare with pre-ban dates on the tag. Friend has 4 in his hangar.
Re: Tool purchases
Garage Journal forum got me again. Someone posted yesterday that the corded band files at Horrible Fright were on sale for $25 instead of $50...
well fuck, can't pass up that bargain. Now I just need to find bands that don't instantly fall apart at the seam or fling abrasive all over the place as it cracks off the bands.
This:
https://www.harborfreight.com/53-amp-12 ... 58155.html
Don't care how long it lasts for $25, if it craps out I'll spring for a better one, probably pneumatic.
This:
- Has thanked: 600 times
- Been thanked: 2451 times
- Has thanked: 7821 times
- Been thanked: 2532 times
Re: Tool purchases
At the risk of sounding like a fool - what ARE those things? I think I've got one somewhere but never found a use for it....
- Has thanked: 6382 times
- Been thanked: 4765 times
Re: Tool purchases
Looks a bit like a deburring tool for trimming edges of stuff?Rockburner wrote: ↑Mon Oct 02, 2023 12:17 pmAt the risk of sounding like a fool - what ARE those things? I think I've got one somewhere but never found a use for it....
Like this
Re: Tool purchases
What he said.
I need to drill and install some grommets on my air filter backing plate, and these work super quickly, I mean I could file all the burs off but a couple of passes with a deburring tool is so much quicker
- Has thanked: 2408 times
- Been thanked: 3638 times
Re: Tool purchases
Another vote for the deburring tool. They do the job quicker and better than anything else I've tried. Can't think why but I've never tried one on copper pipes I've cut; I imagine it would clean them up dead quick.
Re: Tool purchases
My brain has stopped working.
A) I knew that.
b) I could have used one over the weekend....
ffs.
A) I knew that.
ffs.
- dern
- Has thanked: 1017 times
- Been thanked: 1782 times
Re: Tool purchases
Jiggle (joggle?) hose for the win when draining tanks. Never had one before but a brilliant thing.
