Waterless Coolant
Trinity765
Has thanked: 2444 times
Been thanked: 2399 times
Waterless Coolant
Post by Trinity765 »
Has anyone tried waterless coolant? Any rumours of it causing damage?
Has thanked: 609 times
Been thanked: 4133 times
Re: Waterless Coolant
What's wrong with water?
Has thanked: 542 times
Been thanked: 7598 times
I run waterless coolant in my Bullet.
Has thanked: 10340 times
Been thanked: 6916 times
If it ain't broken, don't fix it.
Has thanked: 6416 times
Been thanked: 4798 times
Seems a bit of a faff, you have to flush the system with their (Evans I assume) prep fluid which costs more (for 5l) than the coolant does (for 2l) ie £39.95/£29.95...so, £70.
I'd want it to address and fix a specific issue for that money.
Has thanked: 9912 times
Been thanked: 10216 times
I take it you would use the stuff to prevent corrosion,or is there another reason?
Has thanked: 2418 times
Been thanked: 3662 times
First of all, is it actually approved for use on your bike?
roadster
Has thanked: 15 times
Been thanked: 147 times
Post by roadster »
If I was running a racer and wanted to reduce the size of the radiator and header tank I might give it a try. But then I would have more than one sensor gathering and recording temperature data and the engine would be stripped and inspected every few races.
roadster wrote: Sun Sep 03, 2023 10:04 pm If I was running a racer and wanted to reduce the size of the radiator and header tank I might give it a try. But then I would have more than one sensor gathering and recording temperature data and the engine would be stripped and inspected every few races.
In 25 years racing and instructing i never did that.
So maybe nor essential?
Trinity765
The Speed Twin 1200 has a very hot engine and that's to be expected I guess. I was out all day yesterday at around 24c and the fan was on almost continuously. The worst thing is that my knees sit on the fins which is fine when I'm wearing thick motorcycle clothing, though they look a little melted, but when wearing jeans it burns. Reading comments on the Speed Twin forum a lot of people have this issue, burning knees and constant fan, and someone has said that their fan comes on 50% less using waterless coolant. The bike doesn't have an engine temperate gauge, just a warning light which has never come on and I don't believe that there is an issue as they all do it. It's more, I'm guessing, shorter people and where their knees sit.
My concern is that waterless coolant could corrode something that water doesn't and is it worth the faff of changing over. I would be wise to ask Triumph as the bike is still under warranty though I'm sure to get a "no" from them.
I wanted to know more about it as I've never heard of it.
roadster
Post by roadster »
I'm pretty sure you will find youtube stuff related mostly to cars, but some of it might have a sponsorship bias. There was also an episode of the Mike Brewer program where it was used in a classic car with a reputation for overheating. Sorry I can't remember the details.
Interesting. Some bike forums appear to conclude that the top end runs hotter with waterless coolant. It seems for every claim on one aspect there are reports of the opposite ie increased fuel efficiency, reduced running temp. Bit of a minefield if it's down to YouTube and user groups of one sort or another.
I'm sure I vaguely remember something (might have been a car) being claimed to have a 'sealed for life' cooling system but can't find anything.
Trinity765
roadster wrote: Mon Sep 04, 2023 9:01 am I'm pretty sure you will find youtube stuff related mostly to cars, but some of it might have a sponsorship bias. There was also an episode of the Mike Brewer program where it was used in a classic car with a reputation for overheating. Sorry I can't remember the details.
I've done a little Youtubing and yes, it's mostly car related. One vid said that it won't fix a problem but I don't have a problem to fix.
I'd be interested to know if there was a better coolant than the traditional coolant/water mix.
You could probably get the standard radiator re-cored with more rows, or something.
I imagine it's not as cheap as just trying a different coolant.
Trinity765 wrote: Mon Sep 04, 2023 8:48 am The Speed Twin 1200 has a very hot engine and that's to be expected I guess. I was out all day yesterday at around 24c and the fan was on almost continuously. The worst thing is that my knees sit on the fins which is fine when I'm wearing thick motorcycle clothing, though they look a little melted, but when wearing jeans it burns. Reading comments on the Speed Twin forum a lot of people have this issue, burning knees and constant fan, and someone has said that their fan comes on 50% less using waterless coolant. The bike doesn't have an engine temperate gauge, just a warning light which has never come on and I don't believe that there is an issue as they all do it. It's more, I'm guessing, shorter people and where their knees sit.
I was going to say "Time to spread your legs" but decided it was too tasteless, but it does sound like you need to ride the bike with you knees away from the engine.
Trinity765
Le_Fromage_Grande wrote: Mon Sep 04, 2023 9:44 am
I do but it requires effort so when relaxing my knees fall on the fins.
I thinking about getting another Street Triple to be honest. It's becoming an itch that won't go away.
Has thanked: 1027 times
Been thanked: 1797 times
The temp that the engine runs at is determined by the thermostat. No amount of changing coolant, increasing radiator size will change that. You'd just be adding extra cooling capacity, not changing the running temperature.
You might be able to make some aluminium stand offs like the ones made for exhausts to stop luggage melting for the engine fins. You wouldn't need much of a gap to make quite a difference.
I'm probably wrong, but the thermostat only controls when the cooling circuit opens and closes.
Once it's open on a running engine it plays no further role in normal use.
Changing the thermostat will only change how long it takes to get to normal operating temperature.
Unless the cooling system is inefficient (or broken) and just sits at hot all the time then the thermostat will regulate flow to maintain temperature all the time. Thermostats can fail open for example and in that case the engine will over cool.
But how often in normal use will a thermostat actually close?
