Has thanked: 12639 times
Been thanked: 8555 times
Le_Fromage_Grande wrote: Fri Aug 25, 2023 3:03 pm https://ridermagazine.com/2023/06/28/su ... 24-lineup/
Yanks get the Suzukis I like
£13,000 is good price.
Tricky
Has thanked: 3045 times
Been thanked: 3309 times
Post by Tricky »
Yorick wrote: Fri Aug 25, 2023 1:54 pm
Le_Fromage_Grande wrote: Fri Aug 25, 2023 1:52 pm If you make the mistake of going on any two stroke forums or (worse still) Facebook groups, they're are quite a lot of vociferous people who will tell you how an oil pump is massively better than premix, you can point out as many times as you like that MX bikes and GP bikes use premix and they will retort with some closed throttle theory
On race bikes I'd always go premix. But very happy with the oil pump on the GasGas :)
Agree that the oil pump on the post-2018 KTM/Husky/GasGas smokers is undoubtedly a good system - it's ECU controlled and very good at what it does, evidenced by how well and clean they run, and how oil-efficient it makes them- I've calculated it on my TE300i to be approx 1500 miles per litre so far which I find quite astonishing as if I ran 40:1 premix and got the same MPG then it would work to be ~450 miles/litre, i.e. I'd use more than 3 x as much oil running 40:1, as it does using the pump :o
Having said that, I would use pre-mix on race - the pump is just a tiny little electrical thing, that looks like what you'd have on a small fish tank, and I dunno why but I feel slightly less comfortable with that than if it were a mechanical one, despite it's efficiency, but it is considered to be a service item by KTM with a given service life of 80hrs, and something I will actually replace rather than "sweat the value " on- just in case, like ;)
Has thanked: 2908 times
Been thanked: 1678 times
Tricky wrote: Fri Aug 25, 2023 3:51 pm Agree that the oil pump on the post-2018 KTM/Husky/GasGas smokers is undoubtedly a good system - it's ECU controlled and very good at what it does, evidenced by how well and clean they run, and how oil-efficient it makes them- I've calculated it on my TE300i to be approx 1500 miles per litre so far which I find quite astonishing as if I ran 40:1 premix and got the same MPG then it would work to be ~450 miles/litre, i.e. I'd use more than 3 x as much oil running 40:1, as it does using the pump :o
We had some horrible DT50s at the school in Kent for doing sixteener CBTs on, and the boss got a special deal on a drum of two stroke. It might have been cheap but when we started to use it the bikes smoked horribly out on the road, after spending a morning at walking pace in the training yard. As they got up to speed and heated the exhaust properly, it was like a smoke screen for a few minutes. In the course of the two hour road ride, I'd have a splitting headache from the fumes after an hour of following one of them.
I turned the oil pump down to the minimum setting. Huge improvement in breathing behind them!
After a couple of months, Dave the senior instructor commented "that new oil's really good stuff - we've hardly used any"
Amazingly, the bikes were still running perfectly a couple of years later when I left.
rodbargee
Has thanked: 398 times
Been thanked: 1115 times
Post by rodbargee »
Image Noooooooo
And
Has thanked: 19676 times
Been thanked: 4975 times
:cry: :cry: :thumbdown: :thumbdown:
Wouldn't mind this parked in my garage :)
Just saw this on another forum. Never liked the black ones when I had one.
Buy this one looks well :)
Been thanked: 789 times
Yorick wrote: Sat Aug 26, 2023 5:53 pm Just saw this on another forum. Never liked the black ones when I had one.
I could see Yozzer in a Bond Bug......
David wrote: Sat Aug 26, 2023 7:20 pm
I shall gi' thee a slap :(
Has thanked: 2867 times
Been thanked: 3536 times
Yorick wrote: Sat Aug 26, 2023 7:22 pm
Waaay!!!!!! a Yorkie gi"in summat away........
Been thanked: 1230 times
Not even persistent drizzle could stop the big bike rideout.
JackyJoll wrote: Wed Aug 30, 2023 11:46 am Not even persistent drizzle could stop the big bike rideout.
MARS ATTACKS!!
Has thanked: 4088 times
You always get interesting bike's over at the Classic TT meeting & this year was no exception.I posted those Lc's yesterday.For me,this was the most interesting bike on Douglas prom Sunday night.
It took me a couple of minute's to realise what I was looking at
The styling's not to my taste but judging by the curious onlookers it's 'interesting' alright
Has thanked: 11015 times
Been thanked: 4049 times
TL-Thou or SV650 shaftie?
It's a SV650 with the motor turned 90 degrees & a shaft drive fitted.I don't know what chassis it sits in
Bustaspoke wrote: Fri Sep 01, 2023 12:19 pm It's a SV650 with the motor turned 90 degrees & a shaft drive fitted.I don't know what chassis it sits in
The shaft drive is BMW (mid-90s period by the looks of it). Presumably running off the output shaft of the Suzuki gearbox.
Chassis looks home-made.
Has thanked: 2858 times
Been thanked: 1613 times
Now, that R1100S I have in my garage......
https://motoridersuniverse.com/news/1 ... ms.html
Been thanked: 9519 times
Yeah, it's ANOTHER blingy Elsie, I was just tickled by the accessory bolted to the grab rail.
