I remember it on the telly, Honda sold a shed load of VFRs in the UK thanks to that, big Mac was on an FZ750 that was supposed to be the one Eddie Lawson used to win Daytona.KungFooBob wrote: ↑Thu Aug 17, 2023 7:12 pm I didn't want to start a thread, but here's an interesting story about a very uninteresting bike, the VFR750.
https://www.classicmechanics.com/haslam-stocker-vfr/
- Has thanked: 626 times
- Been thanked: 4063 times
- Screwdriver
- Has thanked: 275 times
- Been thanked: 696 times
Damn that is a sweetie.
Plato
Plato
Aaargh! So much irrational want !
I thought these were the coolest 125, before they started restricting 125s for learners.
Can you imagine trying to get spares for one of these now. Thank heaven its an old listing !
https://www.bonhams.com/auction/19285/l ... no-020196/
It may have a Rotax engine (it looks Rotax) if it has engine spares will be okay to find, but expensive.Ian wrote: ↑Fri Aug 18, 2023 1:39 pm Aaargh! So much irrational want !
I don't know if I like it or not, most of it is good,but some of it is "tarts handbag"
- Has thanked: 1445 times
- Been thanked: 1329 times
- Has thanked: 1707 times
- Been thanked: 2010 times
I've put my name down, can't go wrong for 45 quid.
https://varnicevs.life/product_details/108324779.html
- Has thanked: 852 times
- Been thanked: 1225 times
What have you paid £45 for? It looks like part of an Ogri cartoon.Dodgy69 wrote: ↑Sat Aug 19, 2023 3:02 pm I've put my name down, can't go wrong for 45 quid.
- Has thanked: 2632 times
- Been thanked: 1498 times
Still had the horn on it...KungFooBob wrote: ↑Thu Aug 17, 2023 7:12 pm I didn't want to start a thread, but here's an interesting story about a very uninteresting bike, the VFR750.
- Has thanked: 223 times
- Been thanked: 842 times
I remember Bruce Anstey racing a GSXR1000 at the 2001 UGP and he was beeping at people. Pretty sure it still had the brake light too.The Spin Doctor wrote: ↑Sun Aug 20, 2023 6:45 pmStill had the horn on it...KungFooBob wrote: ↑Thu Aug 17, 2023 7:12 pm I didn't want to start a thread, but here's an interesting story about a very uninteresting bike, the VFR750.
- Has thanked: 264 times
- Been thanked: 1241 times
Very strange. Looks like they sawed the Trident gearbox off and used a 1958-63 Triumph box.
- Tricky
- Has thanked: 2537 times
- Been thanked: 2540 times
At a Cadwell 2-dayer trackday I did last week
What is it, you may ask, or at least that's what I did as I watched it going around in one of the other groups, so I found the owner, who was also the builder of it, and ended up having a really interesting chat with him about it.
Basically it's a home-made RGV500 , constructed by welding 2 x RGV250 motors together, Alan Millyard style, and plonking the lump into a GSXR400 frame, with an R6 rad, and various other bits that he could make do the job by the sound of it.
He was over the moon as this event was only the third time the motor has run, the first two times had resulted in bottom-end seizures within a couple of miles due to crank manufacture / joining issues , and although he definitely wasn't breaking any speed records, had a big smile on his face as he's solved his seizing problem as he was in and out leaving a stinky blue haze around Cadwell
Some quite novel solutions to issues he's encountered, and interesting use of bits from other bikes - my favorite was the lubrication one- as apparently due mainly to his current failure to find a suitable alternative oil pump with sufficient capacity to servve the whole motor, but also due to where the standard oil pump is driven on the RGV, he is currently running two oil pumps- one exactly as standard RGV250, and the other electrically driven.
As initially installed it was apparently massively over-oiling with the gearing he was able to give it, and he currently hasn't worked out a way of regulating the amount of oil that pump provides with throttle position, ( as of course the standard pump does), he has installed a simple speed-control pot as may be seen by the LHS of the tank in the pic below.
Aparantley the paint dot at 9 o'clock is for ticking over/warming up in the assembly area, 12 o'clock is once he's underway on most of the circuit, and as he comes onto the straights he flicks it to 3 o'clock with his left glove, before flicking back to 12 o'clock at the end of the straights just before he tips in
- Has thanked: 15601 times
- Been thanked: 9847 times
I wonder why the bloke with the double engined RGV didn't use pre mix for lubrication, it'd be a lot easier and every race two stroke uses premix
- Tricky
Yup was my first thought too, that, and his explanation of why he didn't made no sense to me eitherLe_Fromage_Grande wrote: ↑Fri Aug 25, 2023 10:59 am I wonder why the bloke with the double engined RGV didn't use pre mix for lubrication, it'd be a lot easier and every race two stroke uses premix
Fair enough.Tricky wrote: ↑Fri Aug 25, 2023 11:36 amYup was my first thought too, that, and his explanation of why he didn't made no sense to me eitherLe_Fromage_Grande wrote: ↑Fri Aug 25, 2023 10:59 am I wonder why the bloke with the double engined RGV didn't use pre mix for lubrication, it'd be a lot easier and every race two stroke uses premix
