1968 Egli-Vincent 1330 by Godet
- Has thanked: 2407 times
- Been thanked: 3636 times
I vaguely remember hearing about Egli-framed Vincents in my yoof, and at the time regarded them as the unattainable ultimate - not quite sure why. Stumbling around on the web I found this - I'm pretty sure my teenage self would have been suitably impressed:
It seems that Fritz Egli, before his death, handed over the rights to produce the frames to Patrick Godet, and this is one of his creations.
Loads more photos and a fair bit of info can be found here:
https://silodrome.com/egli-vincent/
- Has thanked: 1509 times
- Been thanked: 1415 times
- Has thanked: 261 times
- Been thanked: 1266 times
Re: 1968 Egli-Vincent 1330 by Godet
That’s a BSA Gold Star “track silencer” copy.
According to legend, the first version of it was made to sneak a megaphone into a race formula that required a silencer. the front tapered section was a megaphone, with a concealed reverse cone where it met the parallel section.
Within the parallel section was a perforated centre tube, surrounded by glass wool packing, to do a little bit of silencing.
- rodbargee
- Has thanked: 353 times
- Been thanked: 980 times
Seen one in the flesh and was surprised how the Tail pipe really sticks out at an uncomfortable angle, not shaped and in line with the frame.
- Has thanked: 2636 times
- Been thanked: 1523 times
Rather like a Micron system I had on my 92 Gixxer... that never looked right from behind.
- Has thanked: 9835 times
- Been thanked: 10149 times
Ogri bike.
Yes, take your point - it's very obvious from the rear on view. You do wonder how the builder could miss such a glaring error. I suspect they wanted to keep the arc of the pipes as seen from the side and had to flare the pipe/silencer out to avoid missing the suspension units. If they'd gone with a lower exit exhaust they could have tucked it in a fair bit more.
They could have put a bash in the side of the silencer and bring it in closer.
Ogri would have done that.
Although Ogri was on a Norvin, which wouldn’t have cost him all that much to make.
