Vacuum fuel tap
- Has thanked: 9912 times
- Been thanked: 10216 times
Vacuum fuel tap
A vacuum operated fuel tap should not flow petrol unless the engine is running.
Right?
Right?
Re: Vacuum fuel tap
As I suspected then,the vacuum is borked.
- Has thanked: 609 times
- Been thanked: 4133 times
Re: Vacuum fuel tap
Yep, and fifty year old ones are even more troublesome. I gave up trying to fix the vacuum tap on my GS750 and replaced it with a manual one
- Has thanked: 262 times
- Been thanked: 1278 times
Re: Vacuum fuel tap
I never fancied a vacuum tap on a kickstart-only bike, even when the tap is working properly.
Re: Vacuum fuel tap
Whatever I decide to do,the fuel tap will at least have an off position,at least I'll be reasonably sure the fuel is stopped when it should be. I needed to change the fuel lines today and that was a right twunt when I couldn't turn off the flow.
I might be in danger of smelling like a real motorcyclist today.
- Has thanked: 3292 times
- Been thanked: 1739 times
Re: Vacuum fuel tap
In my eye's Vacuum fuel taps are the work of the devil. It will be the first thing to swap if I ever get a old bike with a Vacuum tap fitted
- Has thanked: 2418 times
- Been thanked: 3662 times
Re: Vacuum fuel tap
Is there not a manual fuel tap available from Kawasakis of the era that you could replace the accursed vac tap with? I know that when fitting YPVS carbs to an LC that the vacuum tap inlet on the carb(s) has to be blanked off, so I guess that might also need to be done on your H1. If you don't the carburation will be all over the shop.
Re: Vacuum fuel tap
And if you're looking for fuel hose, clear Ariete hose (purple, but clear) is the stuff to use. PJME sell it, as do a number of other places. Doesn't crack, sweat or leak and does the job.
Re: Vacuum fuel tap
Why would you put YPVS carbs on an LC, they're the same carbs as an LC apart from the vacuum take off for the tap.mangocrazy wrote: ↑Sat Aug 05, 2023 9:08 pm Is there not a manual fuel tap available from Kawasakis of the era that you could replace the accursed vac tap with? I know that when fitting YPVS carbs to an LC that the vacuum tap inlet on the carb(s) has to be blanked off, so I guess that might also need to be done on your H1. If you don't the carburation will be all over the shop.
Re: Vacuum fuel tap
I was advised by no less than Gerry Pell to use 31K carbs on my 4L0. I didn't argue... After a dyno session on Dave Muttsnuts's dyno, the carburation is pretty much as good as it gets. I know they are supposed to be the same carb, but that's not the opinion of a lot people who know. I'm just very happy that the LC is now running better than it ever has in 43 years...Le_Fromage_Grande wrote: ↑Sun Aug 06, 2023 3:20 amWhy would you put YPVS carbs on an LC, they're the same carbs as an LC apart from the vacuum take off for the tap.mangocrazy wrote: ↑Sat Aug 05, 2023 9:08 pm Is there not a manual fuel tap available from Kawasakis of the era that you could replace the accursed vac tap with? I know that when fitting YPVS carbs to an LC that the vacuum tap inlet on the carb(s) has to be blanked off, so I guess that might also need to be done on your H1. If you don't the carburation will be all over the shop.
Re: Vacuum fuel tap
They're both VM26s, slides and needles are different, and power valves are crisper than LCs, especially pre tie bar 350 LCs.
Re: Vacuum fuel tap
In the late 80s I bought an F1 YPVS off a mate (ostensibly) for my girlfriend to ride. The carburation on that was absolutely perfect, crisp as you like. I often took that to work in preference to my VFR. Should never have sold it...
Re: Vacuum fuel tap
I had an 84 YPVS, it was lovely and crisp, I had a 1980 350 LC that wasn't, the 1981 250 LC I had was also good, the price is race 250 I had was amazing, no idea who tuned it, but it went like stink and was lovely and smooth, it also handled really well, it looked standard, but wasn't.
