Dunnowotyeronabout, I don't know nuffink.
Bike security thread
- Has thanked: 1349 times
- Been thanked: 1726 times
- Been thanked: 7539 times
Re: Bike security thread
Actually, I'm confused.
My KC100 got nicked from the works carpark, the GP100 got stolen from my 'rents garage when the centre lock of the up and over door got punched out. They got my mums TS50X at the same time.
KungFooBob wrote: ↑Wed Aug 02, 2023 8:46 pmActually, I'm confused.
I had to Google KC100, looks a bit like the YB100 I had.
I remember KH 100 and KE100's but couldn't remember the KC100. None of my mates had one.
- Has thanked: 9835 times
- Been thanked: 10149 times
Same with some early Kawasaki strokers. Unplug or cut the black/white wire from the ignition switch and you're away.
- Has thanked: 1750 times
- Been thanked: 2085 times
These same crimes continue, decade after decade. Are we doing something wrong. ?
- Has thanked: 15973 times
- Been thanked: 10251 times
- Has thanked: 599 times
- Been thanked: 2449 times
£5 faraday bag soon stops that, an obvious solution as not keeping your car keys next to the letter boxdemographic wrote: ↑Wed Aug 02, 2023 8:15 pmLots of Landrover owners might disagree.
Fairly well known exploit regarding some types of keyless ignitions.
Although what they end up with might protect you?
It is, or was a designed feature on Triumph alarms / immobilisersTaipan wrote: ↑Wed Aug 02, 2023 9:08 pm You can even buy theYamaha immobiliser bypass units on eBay!
loading screen 6 banner
- Has thanked: 2552 times
- Been thanked: 6259 times
Another obvious one is keys which turn themselves off after lack of movement for a minute or two.MrLongbeard wrote: ↑Wed Aug 02, 2023 9:51 pm£5 faraday bag soon stops that, an obvious solution as not keeping your car keys next to the letter boxdemographic wrote: ↑Wed Aug 02, 2023 8:15 pmLots of Landrover owners might disagree.
Relay theft. I turned keyless access off on my car.demographic wrote: ↑Wed Aug 02, 2023 8:15 pmLots of Landrover owners might disagree.
- Has thanked: 6198 times
- Been thanked: 5089 times
Many cars (including top marques) have canbus connections easily accessible.demographic wrote: ↑Wed Aug 02, 2023 8:15 pmLots of Landrover owners might disagree.
www.autoblog.com/amp/2023/04/18/vehicle ... od-update/
- Has thanked: 1947 times
- Been thanked: 1292 times
DT125's were even easier, reach in behind the headlight, pull the plug for ignition switch and it will start !Yorick wrote: ↑Wed Aug 02, 2023 8:22 pmEarly 80s RD Yams were easy to steal.demographic wrote: ↑Wed Aug 02, 2023 8:15 pmLots of Landrover owners might disagree.
Unscrew the headlight and disconnect the ignition switch connector.
Bike starts
- Cousin Jack
- Has thanked: 2555 times
- Been thanked: 2287 times
Pah! My first bike's 'key' was flat, no grooves, no serrations, nothing. I lost it so just used a screwdriver. BSA does not stand for Bike Secure Accesss.
- Has thanked: 10273 times
- Been thanked: 6891 times
I always thought it was Bits Stuck AlloverCousin Jack wrote: ↑Thu Aug 03, 2023 9:06 pm Pah! My first bike's 'key' was flat, no grooves, no serrations, nothing. I lost it so just used a screwdriver. BSA does not stand for Bike Secure Accesss.
- Cousin Jack
Yebut they weren't stuck that well, bits tended to fall off.
