Taipan wrote: ↑Sat Jul 29, 2023 12:34 pm
gremlin wrote: ↑Fri Jul 28, 2023 9:34 am
Woke up around 3am with really bad chest pains. Still got them now. My initial thought was that I was about to shuffle off my mortal coil,
Ring 111 and they should fast track you to ambulatory services at your local hospital. If it is indigestion, I can assure you they won't think you've wasted their time as I'm sure @Horse will confirm! Worse case scenario, you'll be in the right place and that can literally be difference between life and death.
I trust that you you did the sensible thing and googled it?
As said, whatever they think privately (if you fart at them), it would be considered very seriously.
An ambo crew would ask about other symptoms*, and stick you on a monitor, and could probably see whether there is anything ongoing. If they take you in to A&E (or 'ED' now), a blood test could show if you'd had a heart attack.
And being really cheery:
“Most heart attacks hit during the early morning hours from 4 – 10 am when blood platelets are stickier, and there is increased adrenaline released from the adrenal glands that can trigger rupture of plaques in coronary arteries,”
https://www.google.com/amp/s/mygrandstr ... 3famp=true
Hope you're ok.
* At which point you say: "pull my finger!"
