Just Another Brick
Has thanked: 9835 times
Been thanked: 10148 times
Just Another Brick
Been thanked: 7537 times
Re: Just Another Brick
Top Bricks facts No. 254
The 1000cc K100 was a four cylinder and had a square exhaust can, four sides of a square denoting the four cylinders.
The 750cc K75 was a triple and had... you guessed it, a triangular shaped exhaust can!
Has thanked: 7820 times
Been thanked: 2530 times
I quite like that - it's nice and clean.
Has thanked: 15973 times
Been thanked: 10251 times
Not bad at all...
The custom boyos seem to love them and make a decent job of improving the dull looks of the original.
Demannu
Has thanked: 65 times
Been thanked: 1235 times
Post by Demannu »
That looks a proper job!
Has thanked: 1817 times
Been thanked: 1167 times
The K75 is probably more boring to ride than the CX500, it looks OK'ish but what a dull motorcycle to use as a base bike. On the plus side, a well maintained motor will go sailing past 250k miles with ease.
Has thanked: 2915 times
Been thanked: 2060 times
That's a good looking thing. Don't like the 'silencer' for some reason I'm not quite sure about...but other than that :thumbup:
Has thanked: 6198 times
Been thanked: 5089 times
Pirahna wrote: Wed Jul 26, 2023 4:49 pm The K75 is probably more boring to ride than the CX500, it looks OK'ish but what a dull motorcycle to
For me, it was 20+ years between the CX and K75 (and that was 20 years ago) so I couldn't compare the two.
However, the K needed revs - it changes character over 4k. And sounds better.
Has thanked: 2552 times
Been thanked: 6257 times
Really like that :thumbup: I could even ride it without being in pain!
Bigjawa
Has thanked: 221 times
Been thanked: 878 times
Post by Bigjawa »
Skub wrote: Wed Jul 26, 2023 3:19 pm The custom boyos seem to love them and make a decent job of improving the dull looks of the original.
K75S is a lovely wee thing. Absolutely gorgeous.
The problem with custom bricks is that the swinger is too long, its even worse on the 100 and the later ones.
Has thanked: 2636 times
Been thanked: 1523 times
Horrible wrist-aching angle on the handlebars. Otherwise, far from the worst I've seen.
DefTrap
Has thanked: 2267 times
Been thanked: 2193 times
Post by DefTrap »
Better than the original but, for me, the overall impression is just slightly dull and boring. It's like whoever designed it added those nasty red highlights as an afterthought so that it didn't blend in with his effing garage doors ffs.
Whysub
Has thanked: 1055 times
Been thanked: 861 times
Post by Whysub »
The head from a K100 is fairly easy to convert to fit on a Mini engine.
Isn't the K100 DOHC and the Mini ummm...not?
I gets that's why you'd do it, but it doesn't sound like it's the head you need to worry about modifying :D
Mr. Dazzle wrote: Tue Aug 01, 2023 8:41 pm Isn't the K100 DOHC and the Mini ummm...not?
K100 is only 8v iirc, the K1100 is 16v
Has thanked: 6382 times
Been thanked: 4763 times
Whysub wrote: Tue Aug 01, 2023 8:39 pm The head from a K100 is fairly easy to convert to fit on a Mini engine.
I wonder who was first to notice that? (Not to mention why :D ).
