Paddock stand and lube
Has thanked: 4360 times
Been thanked: 2850 times
My old paddock stand isn't wide enough for the GSXS and realised I have 3 useless paddock stands in my garage (missing cups) so I'm gonna bin the lot and start again.
Ordered this today, hopefully it'll be OK and wide enough. Probably not the best but I will only use it for chain lube/cleaning so not heavy use so didn't wanna pay loads. It's an Oxford "premium" so hopefully not total junk :D
https://www.sportsbikeshop.co.uk/motorc ... rod/180969
On the subject of lube I need some as running out of my usual Castrol racing lube. But decided to try this XCP stuff as supposed to be much thinner/more oily and was one of the top lubes in the Bennetts bikesocial test. My only gripe with the Castrol is that it's fairly tacky and in summer attracts dust over time which isn't great. It's not terrible by any means but fancied a change. The XCP scored not so well on fling, but reviews suggest a little goes a long way so will try little and often. Used like that apparently there should be little to no fling. However it doesn't attract dust so much so we'll see. Worse case I'll go back to the Castrol.
https://www.sportsbikeshop.co.uk/motorc ... rod/338891
Finally I ordered a new chain cleaning brush as whatever the dealer put on was high fling whilst also resembling tar. So once the stand arrives I'll be cleaning and lubing
Been thanked: 7526 times
Re: Paddock stand and lube
You could have just bought some cups.
They're cheap on t'bay, I converted a fork one to cups for less than a fiver.
Has thanked: 1829 times
Been thanked: 1469 times
Supermofo wrote: Mon Jun 05, 2023 9:43 pm My old paddock stand isn't wide enough for the GSXS and realised I have 3 useless paddock stands in my garage (missing cups) so I'm gonna bin the lot and start again.
I have just sent my one of those back to SBS. The problem with the construction in that when used with cups the uprights twist in ( the bolts have play in them). On mine it wasn’t even - so it meant that the left hand side was lower than the right - making the bike unstable.
It was fine on bobbins - just rubbish on cups
Has thanked: 9825 times
Been thanked: 10144 times
Paddock smaddock.
Abba Skylift and chainsaw oil. :P
What you really need is drive via cardan shaft and a centre stand.
Abba stands work well (but not on a Triumph 1200 scrambler)
KungFooBob wrote: Mon Jun 05, 2023 10:00 pm You could have just bought some cups.
I can find any for less than 15 gbp!
Mr Moofo wrote: Mon Jun 05, 2023 10:07 pm
That doesn't sound great! I'll be using mine with bobbins so fingers crossed. I couldn't use cups even if I wanted as the swingarm is banana one side and flat the other.
1 isn't wide enough, 1 was left outside in my mates garden for a while and not sure I'd trust the bike on it, the last doesn't have wheels and is ancient. So yeah probably not a bad thing to get a new one
I do like SBS. Ordered 4.30pm last night, got a text saying it'll be here 11.30-12.30 today.
No excuse not to clean my chain tonight now :angry-cussingblack: :lol:
Supermofo wrote: Tue Jun 06, 2023 8:58 am I do like SBS. Ordered 4.30pm last night, got a text saying it'll be here 11.30-12.30 today.
And they are good at refunds - I sent mine back after 4 months use yesterday and got refunded just now
Anyone tried one of these
https://www.ghostbikes.com/5066-black-p ... 5066).html
Mr Moofo wrote: Tue Jun 06, 2023 1:05 pm
Absolutely. I had an intermittent issue with my TomTom Rider 450. It went back for repair and still had the issue and SBS pushed TomTom into giving me a new one without me having to push for it. Returns etc have all been done super quick too.
Has thanked: 2903 times
Been thanked: 2052 times
I've got one very similar by Bike Tek & it's ace. SBS sell them.
Has thanked: 1746 times
Been thanked: 2085 times
I prefer bobbins, I've had cups slide on swinger. ☹
Well that might be short lived. Put 1 upright in the main body, fitted the collar and did it up super tight and there is slight play side to side in the upright. Instructions say don't over tighten but that if there is any twist in the upright not to use the stand and contact the dealer. If I can move it with my arms I'm not sure I'd trust it not to be moving with a 212kg motorbike on it. So guess I'm sending it back. Annoying as looks nice.
Might look for one without a 3 piece construction.
Know one of the school dads works for Harris so might enquire what he can get me one for. They are 1 piece
ChrisW wrote: Tue Jun 06, 2023 3:33 pm
https://www.sportsbikeshop.co.uk/motorc ... prod/92414
This one? Thinking of swapping the Oxford for it. Presume no movement in it? I notice someone mentions using on their GSXS 1000 so I know it's wide enough
Supermofo wrote: Tue Jun 06, 2023 7:55 pm
That's the one. If the width's ok then order one without any worries at all.
Just thought - as I'm recommending this do put a mat or something similar under the stand, being ally they can get a bit of wear on bare garage floors.
Dodgy69 wrote: Tue Jun 06, 2023 5:30 pm I prefer bobbins, I've had cups slide on swinger. ☹
I can't think if a way to fit bobbins to a '95 speed triple
ChrisW wrote: Tue Jun 06, 2023 8:06 pm Just thought - as I'm recommending this do put a mat or something similar under the stand, being ally they can get a bit of wear on bare garage floors.
Ta, either that or I have a load of that rubber matting stuff to stop things sliding on bike seats so could wrap some of that around it whilst I sort a mat
