I can't go round corners anymore?
Has thanked: 9836 times
Been thanked: 10149 times
Re: I can't go round corners anymore?
Horse wrote: Fri May 26, 2023 4:01 pm
Skub wrote: Fri May 26, 2023 2:20 pm I dropped back to sit at his pace.
All I could think of was,if I had decided to go by the Blade rider and ride at my usual pace,the outcome may have been very different.
Maybe not. There's a possibility that by choosing to ride at his pace, you mentally went into low power mode and didn't do some of the 'what if?' planning that you would have usually done. So your reaction time would have been slower. Also, your braking would have been affected by the presence of the other bike and that you couldn't be sure what he would do.
Yeah,there's a definite element of those things at work. I'd have been horrified to rear end another bike.
Has thanked: 10276 times
Been thanked: 6891 times
Skub wrote: Fri May 26, 2023 4:48 pm
ChrisW wrote: Fri May 26, 2023 4:18 pm
Skub wrote: Fri May 26, 2023 2:20 pm ...at my usual pace,the outcome may have been very different.
Might have got there before the buses snarled up the road? ;)
Cool idea. Necessary faster to beat accidents. :lol:
Less time out in the danger.
Has thanked: 6199 times
Been thanked: 5089 times
Yorick wrote: Fri May 26, 2023 5:19 pm
[/quote]
Trade off is possibly more danger within that time ;)
Horse wrote: Fri May 26, 2023 5:41 pm
[/quote]
Damn your logic hoss. :(
westers151
Has thanked: 459 times
Been thanked: 235 times
Post by westers151 »
Wossname wrote: Thu May 25, 2023 11:51 am
Screwdriver wrote: Thu May 25, 2023 10:02 am
I find that is the best way to describe counter steering without the confusing instruction to "turn right to go left". Just use your shoulder to steer you where you want to go.
I’ve never heard that instruction. It’s always been ‘push right to turn right’, which seems fairly straightforward.
The latest version, and probably lots of earlier ones, of the IAM’s Roadcraft has a diagram showing a bike approaching a right hand bend. The advice in a little box is, at this point, ‘counter steer left’.
Eh?
Makes sense to me. To turn right you push the right hand bar which turns the wheel to the left, hence counter steer to the left.
Has thanked: 229 times
Been thanked: 575 times
It’s the phrase “counter steer left” that’s the problem and will simply >> confusion. They just mean “steer left”.
I can assure that yesterday I spent hours positive steering :)
My arms ached to prove it.
Only time counter steered was on the long fast bends when I had the back end hanging out chucking crap up at the lads behind me :D
Only wish I could slide the back end on tarmac :(
westers151 wrote: Mon May 29, 2023 11:56 am
Screwdriver wrote: Thu May 25, 2023 10:02 am I find that is the best way to describe counter steering without the confusing instruction to "turn right to go left". Just use your shoulder to steer you where you want to go.
the IAM’s Roadcraft has a diagram showing a bike approaching a right hand bend. The advice is, at this point, ‘counter steer left’.
And this why people steer clear (sorry :D ) of SS ...
It really is as simple as:
Press left, go left
Press quickly, lean quickly
Press longer, lean further
Then relax the pressure
Has thanked: 1750 times
Been thanked: 2085 times
I had a go at this "consciously counter steering" malarkey, didn't like it. I'd rather lean into the bend and let the bike do the steering. It's only to get the initial tip. 🤷‍♂️
Whatever you do, never counter steer the whole bend. 😁👍
Horse wrote: Mon May 29, 2023 1:37 pm
Press left, go left
SS?
Wossname wrote: Mon May 29, 2023 5:44 pm
Horse wrote: And this why people steer clear (sorry :D ) of SS ...
Press left, go left
SS?
Sorry, inaccurate typing on the phone: SA - Staying Alive.
Dodgy69 wrote: Mon May 29, 2023 5:31 pm I had a go at this "consciously counter steering" malarkey, didn't like it. I'd rather lean into the bend and let the bike do the steering.
It's still you doing it ;)
Dodgy69 wrote: Mon May 29, 2023 5:31 pm It's only to get the initial tip. 🤷‍♂️
Yup. You lean the bike. When it's over enough, take the pressure off and the front wheel will turn the side it's leaning. Then you're into the corner.
Dodgy69 wrote: Mon May 29, 2023 5:31 pm Whatever you do, never counter steer the whole bend. 😁👍
Sortof ;)
If its a tightening spiral, you'll need to keep leaning further over (unless you slow down and left gravity lean it a bit further). Even on a constant radius, if you accelerate then you'll need to kean further.
