Been thanked: 2618 times
Some small Hondas in the 1980s had cable discs, upto 250cc maybe, certainly some of the 125s
Has thanked: 6196 times
Been thanked: 5088 times
Count Steer wrote: Thu May 25, 2023 6:24 am
Horse wrote: Wed May 24, 2023 9:36 pm
Count Steer wrote: Wed May 24, 2023 9:04 pm
How's that clutch lever work?
Could be as on many vintage bikes, where the lever pivots at the bar end and the cable runs through the bars.
From an engineering pov, your strongest fingers are at the end of the lever where they can have most effect.
Could be that for the clutch Hoss but I can't see a brake lever (there's something welded/brazed into the bar above the right hand but it doesn't look like a pivot) and they're discs...has there ever been a cable operated disc?
RH side? Dunno, I gave up at that point :D
Honda did a cable disc, CB200 IIRC
Has thanked: 2552 times
Been thanked: 6256 times
Cable discs are a thing on push irons too.
KH125s had cable operated discs in 1985
Has thanked: 2636 times
Been thanked: 1523 times
Count Steer wrote: Thu May 25, 2023 6:24 am Could be that for the clutch Hoss but I can't see a brake lever (there's something welded/brazed into the bar above the right hand but it doesn't look like a pivot) and they're discs...has there ever been a cable operated disc?
Linked brakes, innit?
Presumably both operated by the foot. Wouldn't be legal in most countries, but hey, when has that ever bothered a custom bike designer? :)
Guessing bikes are required to have two independent circuits, just like cars?
In the Honda system and the like the two systems are still independent even though they use the same calliper, aren't they? A leak in one doesn't kill both?
Has thanked: 6381 times
Been thanked: 4761 times
The Spin Doctor wrote: Thu May 25, 2023 8:36 am
I guess. I don't know how many custom designers have the technical knowledge to do a proper job of it though...unless Guzzis (I'm only assuming that's what it is/was) of an era with solid discs had it to start with? Then it wouldn't be too difficult.
Front suspension doesn't make much sense to me either.
I've trawled Google but can't find it. The irritating thing is I think I've seen it before.
Starting to think it's AI! :lol:
On Guzzis with linked brakes, the handlebar lever did one front disc and the foot pedal did the other and the rear disc.
Count Steer wrote: Thu May 25, 2023 8:55 am I don't know how many custom designers have the technical knowledge to do a proper job of it though...
I'm not sure that's a requirement :D
Mr. Dazzle wrote: Thu May 25, 2023 8:59 am
True! :D
Has thanked: 1947 times
Been thanked: 1292 times
Post by Jody »
I appreciate its a readily available bike, but I'd never seen one before..
Been thanked: 7535 times
Jody wrote: Thu May 25, 2023 9:07 am I appreciate its a readily available bike, but I'd never seen one before..
I've seen plenty of the 500's, but never a 1100 like that, looks like it's a dct one too.
Has thanked: 10269 times
Been thanked: 6887 times
That leather bag is perfect for the beard trimming accessories :)
ogri
Has thanked: 1036 times
Been thanked: 224 times
Post by ogri »
They do an 1100cc one with auto gear-box :P
Ignorance is bliss
Has thanked: 810 times
Been thanked: 4805 times
And let's hope we never have to see one again....
Has thanked: 15962 times
Been thanked: 10248 times
I've never seen one and not keen to see one again, but out of interest, what is it?
Looks better with someone on it I suppose, but still... :thumbdown:
Has thanked: 2248 times
Been thanked: 1242 times
v8-powered wrote: Thu May 25, 2023 8:49 pm Screenshot_20230525_204847_Instagram.jpg
That popped up on Instagram (Return of the Café Racers iirc). There's some very nice detail to it...and it's a very patriotic colour :thumbup: (It's from Queensland). Might be the best CX custom I've seen.
