Bike bench/platforms
- Has thanked: 10967 times
- Been thanked: 3999 times
Has anyone got any experience with the "scissor" type work ramps?
This sort of thing: https://www.sandblasters.co.uk/800lb-mo ... 1211-p.asp
There's a few on the market at the moment, from that cheap one, to things like 2 grand Sealey products.
I'm considering one because my shed isn't long enough to fit one of the more usual type that go up and down in an arc.
I was initially looking at the SGS one, https://www.sgs-engineering.com/sml450- ... lift-450kg, but they don't have any yet.
- Has thanked: 602 times
- Been thanked: 4529 times
Re: Bike bench/platforms
Abba Skylift.
When they start doing fittings for Norton Featherbed frames, and Puch Magnum X off-roaders I might consider it....
Ah,there's always a catch!Rockburner wrote: Tue May 16, 2023 10:36 amWhen they start doing fittings for Norton Featherbed frames, and Puch Magnum X off-roaders I might consider it....
In the spirit of recommending what you own as the best thing ever,I thought I'd mention the Abba anyway.
I have a regular ABBA bike stand (with Triumph fittings oddly), and did try it on the Featherbed, but there's nothing really for it to latch into that's at the right height.Skub wrote: Tue May 16, 2023 10:39 amAh,there's always a catch!Rockburner wrote: Tue May 16, 2023 10:36 amWhen they start doing fittings for Norton Featherbed frames, and Puch Magnum X off-roaders I might consider it....
In the spirit of recommending what you own as the best thing ever,I thought I'd mention the Abba anyway.![]()
I want the bikes higher up anyway, hence looking for a bench.
- Has thanked: 8046 times
- Been thanked: 5697 times
You might make something like this work or the site might give you some ideas.
https://www.safetyliftingear.com/produ ... pt03325
Doesn't have the front-wheel clamp, or the loading ramp, and is twice the price of the one in the first link.....Count Steer wrote: Tue May 16, 2023 10:52 am You might make something like this work or the site might give you some ideas.
Ah.Rockburner wrote: Tue May 16, 2023 11:02 amDoesn't have the front-wheel clamp, or the loading ramp, and is twice the price of the one in the first link.....Count Steer wrote: Tue May 16, 2023 10:52 am You might make something like this work or the site might give you some ideas.
https://www.safetyliftingear.com/produ ... pt03325![]()
Do you happen to know which one it is?
I suspect most are actually from the same suppliers in Shenzen, just painted to desired colour and with different stickers.
- Has thanked: 2557 times
- Been thanked: 4167 times
I thought similarly about getting fittings for my 350LC, but Abba produce fittings that lock on to the swingarm pivot bolt/nut. I'd have thought that they would be able to do something similar for your Norton (imperially speaking, of course). And if the Puch has a 'conventional' swingarm mounting, they should be able to cater for that as well.Rockburner wrote: Tue May 16, 2023 10:36 amWhen they start doing fittings for Norton Featherbed frames, and Puch Magnum X off-roaders I might consider it....
Have you contacted them about options? What's on their website is just the tip of the iceberg as to what fittings they offer.
No, he's had it longer than I've known him, so over 7 years and uses it a lot, which isn't very helpfulRockburner wrote: Tue May 16, 2023 11:39 amDo you happen to know which one it is?
TBH, The Abba I've got doesn't lift the bike high enough, and I'd rather have a bench.mangocrazy wrote: Tue May 16, 2023 3:26 pmI thought similarly about getting fittings for my 350LC, but Abba produce fittings that lock on to the swingarm pivot bolt/nut. I'd have thought that they would be able to do something similar for your Norton (imperially speaking, of course). And if the Puch has a 'conventional' swingarm mounting, they should be able to cater for that as well.Rockburner wrote: Tue May 16, 2023 10:36 amWhen they start doing fittings for Norton Featherbed frames, and Puch Magnum X off-roaders I might consider it....
Taff
- Has thanked: 334 times
- Been thanked: 1192 times
I have one that looks very similar to the one in the first link on loan, the one I have is actually designed for small bikes and it isn't long enough to support the rear wheel of my tiger, you have to use a centre stand with it which is a nightmare to do when you clamp the front wheel and then try to get it on the centre stand. I landed up jacking the bike up under the bash plate to lower the centre stand.
It's also not wide enough to use my ancient micron paddock stand.
Wouldn't you put it on the centre stand first, then shunt it forwards into the clamp?Taff wrote: Tue May 16, 2023 6:12 pm I have one that looks very similar to the one in the first link on loan, the one I have is actually designed for small bikes and it isn't long enough to support the rear wheel of my tiger, you have to use a centre stand with it which is a nightmare to do when you clamp the front wheel and then try to get it on the centre stand. I landed up jacking the bike up under the bash plate to lower the centre stand.
TBH most of my use would be with a mini-lift under the frame anyway.
Sorry - I was thinking along the lines of a Skylift (which uses the same fittings) - that will get the bike higher than any bench, and it means the bike can be moved around the garage to suit. It is spendy, though.Rockburner wrote: Tue May 16, 2023 4:47 pmTBH, The Abba I've got doesn't lift the bike high enough, and I'd rather have a bench.mangocrazy wrote: Tue May 16, 2023 3:26 pmI thought similarly about getting fittings for my 350LC, but Abba produce fittings that lock on to the swingarm pivot bolt/nut. I'd have thought that they would be able to do something similar for your Norton (imperially speaking, of course). And if the Puch has a 'conventional' swingarm mounting, they should be able to cater for that as well.Rockburner wrote: Tue May 16, 2023 10:36 am
Have you contacted them about options? What's on their website is just the tip of the iceberg as to what fittings they offer.![]()
PitaNaanRoti
- Has thanked: 25 times
- Been thanked: 54 times
Errrr, yes, that's the first link in the first post.PitaNaanRoti wrote: Tue May 16, 2023 8:18 pm Talk to the guys at https://www.sandblasters.co.uk/
PitaNaanRoti
And?Rockburner wrote: Tue May 16, 2023 8:29 pmErrrr, yes, that's the first link in the first post.PitaNaanRoti wrote: Tue May 16, 2023 8:18 pm Talk to the guys at https://www.sandblasters.co.uk/
https://www.sandblasters.co.uk/800lb-mo ... 1211-p.asp![]()
Do you have any experience with it?PitaNaanRoti wrote: Tue May 16, 2023 8:52 pmAnd?Rockburner wrote: Tue May 16, 2023 8:29 pmErrrr, yes, that's the first link in the first post.PitaNaanRoti wrote: Tue May 16, 2023 8:18 pm Talk to the guys at https://www.sandblasters.co.uk/
