wull
Has thanked: 969 times
Been thanked: 1843 times
Post by wull »
I’m sure there is a recall for the water/oil pump built between certain dates, mine is outwith these dates but I had a look anyway. You start to see oil at the weep hole if it is leaking. I’m guessing his is the 2019-2022 model and not the 2023 bike that’s just came out. They still refer to the 2023 bike a the K67.
Roads are too busy, it’s still dark in the morning and cold so can’t have fun on the way there which is usually when I can as it’s quiet, but coming home is a pain in the fart box.
Been thanked: 14167 times
wull wrote: Thu Apr 20, 2023 6:18 pm I’m sure there is a recall for the water/oil pump built between certain dates, mine is outwith these dates but I had a look anyway. You start to see oil at the weep hole if it is leaking. I’m guessing his is the 2019-2022 model and not the 2023 bike that’s just came out. They still refer to the 2023 bike a the K67.
The bike is a brand new 2023 model,so maybe just fat fingers on the assembly line.
wull
Post by wull »
Recall probably covers the 2023 bike as well but I struggle at times to find the information, there’s so much conflicting information especially with regards to build dates that are affected. I keep seeing something and thinking ffs but so far it always turns out mine is either built before or after bikes that are affected by the recall.
Has thanked: 4071 times
Been thanked: 2509 times
I've just been out for a spin on the Street Triple,I was reading online that you can lose up to 20mm of seat height by slackening off all the linkage & shock bolts,then retightening them with the weight of the bike loading the suspension.Fron what I've read Triumph build the bikes up with the bike suspended.I should have been a bit more scientific,but I reckon the seat height's dropped by approx 8mm.
Nice evening for a gentle spin :thumbup:
Has thanked: 2908 times
Been thanked: 1676 times
Bustaspoke wrote: Thu Apr 20, 2023 7:57 pm I've just been out for a spin on the Street Triple,I was reading online that you can lose up to 20mm of seat height by slackening off all the linkage & shock bolts,then retightening them with the weight of the bike loading the suspension.Fron what I've read Triumph build the bikes up with the bike suspended.I should have been a bit more scientific,but I reckon the seat height's dropped by approx 8mm.
Nice photo top!
That's a bit alarming about the seat height dropping. Surely all the bolts should be snug fits in the links?
The Spin Doctor wrote: Fri Apr 21, 2023 9:34 pm That's a bit alarming about the seat height dropping. Surely all the bolts should be snug fits in the links?
It came as a surprise to me.Not being an engineer all I can think is that with the bike being suspended all the weight pulls the various components to their maximum tolerance in one direction,resulting in a maximum seat height & by slackening the bolts & compressing the suspension before tightening the bolts up again you reach their maximum tolerance in the opposite direction resulting in a lower seat height.The bike definitely feels like it's sitting a few mm lower.According to my tape it's sitting 6-8 mm lower,but that's just me measuring it.Ideally you would hold it in some kind of jig & measure with a ruler or laser.I've already taken all the preload out of the rear shock.
Here's what it said in the link I found
Common modifications: lowering your Triumph Street Triple 675
Lowering kits are popular but according to specialist Clive Wood, they’re not the way to go: "I see a lot of bikes and people have bought a kit from eBay, lowered it 40mm and ruined the handling. You don’t need to change the dog bones, it’s easy to lower the bike enough for most people. With the wheels on the floor, loosen all the bolts in the rear suspension linkages. There’ll be a ‘clunk’ as all the joints settle. Then take a couple of rings of preload off the rear spring. That’ll lower the rear by about 25mm. Now move the forks up through the yokes by about 15mm to restore the balance." And it’s free!
Mine never made a 'Clunk'.
Has thanked: 2222 times
Been thanked: 2596 times
Some cnut tried to spoil my day...
Has thanked: 353 times
Been thanked: 912 times
Is he reversing out of your way? Or is that your rear view camera?
He's in a PT Cruiser - his day was spoiled too.
Wossname wrote: Mon Apr 24, 2023 4:20 pm Is he reversing out of your way? Or is that your rear view camera?
Front cam, he was doing a U Turn over the double yellows as I came around the corner. Air horn got a work-out.
Trinity765
Has thanked: 3112 times
Been thanked: 3170 times
Post by Trinity765 »
To work this morning. Not gonna lie - it was cold, especially as I refuse to wear winter gear in late April. I'm only riding in as I received a car parking ban for late cancelling my car parking space - that's the price of freedom here. So if I want to go into the office for the next month, I will have to take my bike. I hope it warms up a little.
Check out the cheap pannier bags I bought to hide the ugly pannier rails - one of them fell onto the exhaust and practically disintegrated so down to one already which is secured with a cable tie.
Has thanked: 624 times
Been thanked: 9378 times
I went over this bridge. I've been meaning to go over it for quite some time. The road up to it was actually pretty good.
Has thanked: 2804 times
Been thanked: 3462 times
Trinity765 wrote: Tue Apr 25, 2023 8:05 am To work this morning. Not gonna lie - it was cold, especially as I refuse to wear winter gear in late April. I'm only riding in as I received a car parking ban for late cancelling my car parking space - that's the price of freedom here. So if I want to go into the office for the next month, I will have to take my bike. I hope it warms up a little.
If its a decent size pillion seat, you'll get a decent size tail bag strapped to it. 👍
Trinity765
Dodgy69 wrote: Tue Apr 25, 2023 5:46 pm
Not a great picture, I have adapted my SW Motech panniers and I have a 20L Kreiga tail pack on there with my rucksack slung on top and helmet in the way. If I ever needed more (for maybe camping) I have a 40L Lomo dry bag which would replace the tail pack. I think once you get that far, you can just keep adding if you have the right straps and bungies :lol:
Has thanked: 6081 times
Been thanked: 15398 times
it's not the prettiest picture, but it shows you're out there riding which is more than most on this here place :D
Bigyin
Has thanked: 1436 times
Been thanked: 2738 times
Post by Bigyin »
weeksy wrote: Wed Apr 26, 2023 6:59 am it's not the prettiest picture, but it shows you're out there riding which is more than most on this here place :D
If you want a photo every time i ride one of the bikes this thread is going to spammed almost daily :mrgreen:
Trinity765 wrote: Tue Apr 25, 2023 8:05 am Check out the cheap pannier bags I bought to hide the ugly pannier rails - one of them fell onto the exhaust and practically disintegrated so down to one already which is secured with a cable tie.
I thought that was your handbag...
Trinity765
ZRX61 wrote: Wed Apr 26, 2023 4:10 pm
It is :D
Flux
Has thanked: 232 times
Been thanked: 306 times
Post by Flux »
Portimao last weekend..
Flux wrote: Thu Apr 27, 2023 8:16 am Portimao last weekend..
I'm sat here looking at heavy rain,likely for the next week at least,so those pics didn't make me jealous at all.
Nope,not even slightly. :(
