Harley Davidsons
- Has thanked: 65 times
- Been thanked: 1235 times
Harley Davidsons
Was doing a little Spannering on a shovelhead.
Simple job, replace the check valve.
I wonder if whoever designed the engine had any experience in engineering, or was possibly high on drugs.
Enormous amounts of unused space, gaps that you can lose screwdrivers in!
Yet this thing, a slotted screw! Not even a bolt head, and of course the exhaust header/pushrod tubes were in the way, so had to use a stubby with another through the handle for leverage to get the damn thing loose.
Something that could have been a 2 minute took an hour. Grrrrr
- Has thanked: 7818 times
- Been thanked: 2529 times
- Has thanked: 836 times
- Been thanked: 1239 times
Re: Harley Davidsons
They gave some fuzzy felt to primary school kids and asked them what a motorbike should look like.
- Been thanked: 7533 times
- Has thanked: 599 times
- Been thanked: 2445 times
Take heart, it's the same on the new M8 engines, changing the battery is a 30 - 45 minute ordeal, fitting a simple cruise control switch (swapping out the LH switch gear) requires the petrol tank to come off
