New Project(s)
Re: New Project(s)
(i can't seem to get a password reset for my usual account)
- Has thanked: 2402 times
- Been thanked: 3625 times
Re: New Project(s)
I can't remember what it's called (I'll try and find out) but I've used a reddish RTV in the past that's made specifically as a gasket cement for fuel pump to tank interfaces. Maybe some of that? I'd be tempted to fill the nick with JB Weld and then use the RTV to stop petrol getting at the JB Weld...
Personally I'd back JB Weld to stand up to petrol, as long as it's fully cured.
- Has thanked: 6376 times
- Been thanked: 4751 times
Re: New Project(s)
Probably needs a 5* admin to sort that. @weeksy I can't see any issues.RiceBurner wrote: ↑Mon Apr 03, 2023 6:50 pm (i can't seem to get a password reset for my usual account)
- Screwdriver
- Has thanked: 256 times
- Been thanked: 740 times
Re: New Project(s)
If you're very careful, you could solder it.Rockburner wrote: ↑Mon Apr 03, 2023 4:08 pmNot a typo, it's the wall thickness of the float bowl itself, there is no 'flare' to provide a larger mating surface for the cover. (it might be more like 1/2mm, but it's no more than 3/4mm ).
<edit> looking at the picture, surely a thicker gasket would solve the issue. Cut one out of some EPDM.
<edit.2> Scratch that. Looking at Google, not EPDM for petrol...
Plato
Plato
- Has thanked: 5450 times
- Been thanked: 13085 times
Re: New Project(s)
PmRiceBurner wrote: ↑Mon Apr 03, 2023 6:50 pm (i can't seem to get a password reset for my usual account)
Re: New Project(s)
What sir needs is a nice Viton (FKM) gasket.Screwdriver wrote: ↑Mon Apr 03, 2023 7:00 pmIf you're very careful, you could solder it.Rockburner wrote: ↑Mon Apr 03, 2023 4:08 pmNot a typo, it's the wall thickness of the float bowl itself, there is no 'flare' to provide a larger mating surface for the cover. (it might be more like 1/2mm, but it's no more than 3/4mm ).
- Screwdriver
Re: New Project(s)
Back in the day, I'd cut mine out of cardboard. You can use anything petrol resistant that has a bit of flex to it.
Plato
Plato
Re: New Project(s)
I'd have thought proper gasket material (i.e. not paper) would be best. Cardboard will Shirley allow the passage of petrol, wouldn't it?
- Has thanked: 7814 times
- Been thanked: 2527 times
Re: New Project(s)
Thank you mate!weeksy wrote: ↑Mon Apr 03, 2023 7:05 pmPmRiceBurner wrote: ↑Mon Apr 03, 2023 6:50 pm (i can't seem to get a password reset for my usual account)
- Screwdriver
Re: New Project(s)
Wood fibre is a remarkable material, you can soak it in oil to make it swell and remain impervious to fluids. Better off with a more robust modern plastic but cardboard is an excellent material for many engine gasket applications.mangocrazy wrote: ↑Mon Apr 03, 2023 8:02 pm I'd have thought proper gasket material (i.e. not paper) would be best. Cardboard will Shirley allow the passage of petrol, wouldn't it?
Plato
Plato
Re: New Project(s)
To block the passage of oil, perhaps, but petrol is a lot more searching and will leech away any oil over time. For an application like this I'd use a modern plastic-based material, as you say.Screwdriver wrote: ↑Mon Apr 03, 2023 8:07 pmWood fibre is a remarkable material, you can soak it in oil to make it swell and remain impervious to fluids. Better off with a more robust modern plastic but cardboard is an excellent material for many engine gasket applications.mangocrazy wrote: ↑Mon Apr 03, 2023 8:02 pm I'd have thought proper gasket material (i.e. not paper) would be best. Cardboard will Shirley allow the passage of petrol, wouldn't it?
Re: New Project(s)
The gasket that comes from AMAL is a waxed paper.Screwdriver wrote: ↑Mon Apr 03, 2023 7:39 pm Back in the day, I'd cut mine out of cardboard. You can use anything petrol resistant that has a bit of flex to it.
I think a rubber gasket would compress better and allow a greater disparity in the mating surface.
Re: New Project(s)
Ordered up some 1mm viton sheet last night, going to try to make a rubber gasket as a first fix attempt. Might be safer than trying to grind down the float-bowl 'face', at least as a first try and then we'll see how we go.
I"m not actually sure 'why' the bike has a Monobloc in the first place tbh.... Obviously the bike is a 'bitsa' special, but I'd have expected the carb to be something more suitable for a JAP speedway style single.... might ask around on the JAP FB pages to see what other people are using.
It was very likely just something Dad had lying around, or one that a mate had lying around and offered to him. It's bodged onto the head.
- Been thanked: 7526 times
Re: New Project(s)
Get a nice Gardner on it.
I spent 20mins talking to the owner of that bike about how the carb worked, he even gave me photocopies of all the documentation to peruse over night (It was a race weekend at Cadwell and we were parked across the road from him)
- 71799670_2383512058350975_4778063739985330176_n.jpg (463.25 KiB) Viewed 302 times
- Has thanked: 2550 times
- Been thanked: 6244 times
Re: New Project(s)
FWIW, the 1mm Viton didn't seal the leak on the float bowl, but did reduce it to a very minor weep. So i smeared some blue Hylomar on the seal and its worked a treat.
Eventually I'll probably get the float bowl ground down slightly, but for now it seems good.
Re: New Project(s)
The bottom fuel pipe is connected to a tube with the needle on the end. Instead of the needle lifting from the main jet, it lowers... basically when you twist the throttle the needle drops out the bottom on the carb, that's why the pipe has so much free play on it.
Re: New Project(s)
Come to think of it Ricey, I might....might...have some bits of monobloc in the garage. Deffo inherited a bunch of concentric bits, including bowls. Can't remember if I've got a similar stash of monobloc. The 5TA has a monobloc carb on.
I'll have a look and see if I've got a bowl, if nothing else you could have a practice at fixing one?
Re: New Project(s)
That may well prove useful, thanks!Mr. Dazzle wrote: ↑Fri Apr 07, 2023 2:12 pm Come to think of it Ricey, I might....might...have some bits of monobloc in the garage. Deffo inherited a bunch of concentric bits, including bowls. Can't remember if I've got a similar stash of monobloc. The 5TA has a monobloc carb on.
I think on the Monobloc, the bowl and body are all one piece, so only if you're absolutely sure you won't need it yourself!
