- Has thanked: 2862 times
- Been thanked: 3518 times
Tis a lovely bike that, congrats.
- Has thanked: 20885 times
- Been thanked: 13705 times
Fitted the end can yesterday, which took about 5 minutes.
Downside is the SC Project sticker is partially hidden behind the support strap, which annoys me. I've left it for now rather than remove it but suspect it'll play on me and end up getting removed?
I then took the headlight and cowl out to get to the AIT connector to put the fuel adjuster in line. But I couldn't not get a panel off to get at it. It then started to pour with rain, and is going to rain pretty much all day. So even now I have the answer on how to remove the panel, it doesn't look like I'll get to it today. Lighter evenings are here though...
Well, today was the real litmus test. Today wasn't about riding open b roads, today was riding it in the environment is has to suit and I can safely say what a piece of shit!
I think I can also safely say it has the worse fuelling I've ever experianced on a bike.
Honestly, it is bloody awful. If you're familiar with the old term kangaroo juice, you'll have an idea of what I mean. It jumps about like it has a misfire at certain revs and trying to use the gears to keep it in the smoother spots was hard work!
But, I did find out why they bothered putting urban mode on there! Out of desperation,I pulled over and got it into Urban mode and found the bike is a lot easier to ride around town in Urban than it is in Touring. I think Sport mode must literally be for track use, or empty B roads, or Xaus?
I'm really busy at work or I'd take a half day and get the fuel controller fitted. Might be able to do it on these lighter evenings though. Now I've got it into Urban mode and it's a lot more usable, I suppose it can wait until Friday. I'll see how I get on with it on the ride home?
Ergonomics wise, its pretty much bang on for the sitting position. Suspension is bouncy and soft, which kinda works well over London's pot hole ridden streets, but I think it'd benefit from more preload and less compression on the shock? Forks aren't even adjustable,
so they'll have to do as they are.
Motards are just brilliant for hacking through town on. The exhaust has a nice little growl to it, but is certainly not loud. I suppose if I took the cat out it might be, but i'm not going to do that. I'm not actually sure about the can anyway. It sits at an odd angle? So the Jurys out on that at the moment.
Hopefully, I can sort the fuelling out with the adjuster thing, as that's the only fly in the ointment really. But overall it seems like it may well do the job I got it for.
- Has thanked: 6125 times
- Been thanked: 15510 times
- Has thanked: 2852 times
- Been thanked: 1611 times
Get the scoot back!
Sorry to hear of the problems, horrible when something you want so much proves to disappoint a little
Still got it!v8-powered wrote: Mon Mar 27, 2023 10:22 am Get the scoot back!
Not a problem really as I'd read about them and how bad the fuelling is, hence my buying the fuel adjuster before i'd even got the bike. As is always the case, I ride right where the poor fuelling is at its worse! I could feel the fuelling on saturday but it wasn't so much of an issue on open roads, it's just around town its a pain. I'll sort it though and it hasn't put me off the bike at all!
It might have exacerbated the problem a bit? But they are just notorious for their jerky throttle at low revs.
I've said it a few times. But i think it's honestly you not the bikes, they can't ALL have rubbish fuelling... Hundreds, thousands and tens of thousands of people commute on bikes, in towns, cities and urban environments, but they either accept or ride around issues.Taipan wrote: Mon Mar 27, 2023 10:51 amStill got it!v8-powered wrote: Mon Mar 27, 2023 10:22 am Get the scoot back!
Not a problem really as I'd read about them and how bad the fuelling is, hence my buying the fuel adjuster before i'd even got the bike. As is always the case, I ride right where the poor fuelling is at its worse! I could feel the fuelling on saturday but it wasn't so much of an issue on open roads, it's just around town its a pain. I'll sort it though and it hasn't put me off the bike at all!![]()
IMO there is no way a fuelling controller will turn a bike from complete shit in fuelling to dreamy lovely... It'll be an incremental improvement at best.
- Has thanked: 12620 times
- Been thanked: 8541 times
My GSXR has dodgy fueling despite always using posh Repsol 98 stuff.
A few weeks ago I had to put some BP stuff in. Wow. Amazing difference.
It's not just me, many others complain about it and tuners even advertise a remap as a way to get rid of the low throttle jerkiness. You have to bear in mind, i'm not just out there working my way up and down the box. I'm normally sitting in 2nd or 3rd gear filtering through heavy traffic at around 2-4k revs, which is right where the problem manifests itself.weeksy wrote: Mon Mar 27, 2023 10:54 amI've said it a few times. But i think it's honestly you not the bikes, they can't ALL have rubbish fuelling... Hundreds, thousands and tens of thousands of people commute on bikes, in towns, cities and urban environments, but they either accept or ride around issues.Taipan wrote: Mon Mar 27, 2023 10:51 amStill got it!v8-powered wrote: Mon Mar 27, 2023 10:22 am Get the scoot back!
I'm not expecting the fuel adjuster to cure it, but it certainly helps according to the Ducati forums. It's a temporary set up for me until I settle on an end can and its good enough weather to ride somewhere to get it remapped.
I didn't mean just you in terms of the Ducati... i mean you in terms of 'bikes' and wanting more than appears possible these days. You've had a shit tonne of bikes and are still trying to find one that fuels right...Taipan wrote: Mon Mar 27, 2023 11:15 amIt's not just me, many others complain about it and tuners even advertise a remap as a way to get rid of the low throttle jerkiness. You have to bear in mind, i'm not just out there working my way up and down the box. I'm normally sitting in 2nd or 3rd gear filtering through heavy traffic at around 2-4k revs, which is right where the problem manifests itself.weeksy wrote: Mon Mar 27, 2023 10:54 amI've said it a few times. But i think it's honestly you not the bikes, they can't ALL have rubbish fuelling... Hundreds, thousands and tens of thousands of people commute on bikes, in towns, cities and urban environments, but they either accept or ride around issues.Taipan wrote: Mon Mar 27, 2023 10:51 am
Still got it!
- Has thanked: 602 times
- Been thanked: 4529 times
Stop riding like a poof and thrash the tits out of it
Le_Fromage_Grande wrote: Mon Mar 27, 2023 11:29 am Stop riding like a poof and thrash the tits out of it
That's because I had the F800R remapped and know t can be sorted.weeksy wrote: Mon Mar 27, 2023 11:21 amI didn't mean just you in terms of the Ducati... i mean you in terms of 'bikes' and wanting more than appears possible these days. You've had a shit tonne of bikes and are still trying to find one that fuels right...Taipan wrote: Mon Mar 27, 2023 11:15 amIt's not just me, many others complain about it and tuners even advertise a remap as a way to get rid of the low throttle jerkiness. You have to bear in mind, i'm not just out there working my way up and down the box. I'm normally sitting in 2nd or 3rd gear filtering through heavy traffic at around 2-4k revs, which is right where the problem manifests itself.weeksy wrote: Mon Mar 27, 2023 10:54 am
No point, he'll buy the only one in the world with fuelling problems
- gremlin
- Has thanked: 1102 times
- Been thanked: 5884 times
Mind you, fueling issue or not, I'd dump that OE exhaust on the basis of its fecking looks alone.
- Has thanked: 5970 times
- Been thanked: 3574 times
What you want is a nice GSXS 1000. Pick a gear, any gear will work at about 20mph and it trickles along nicely. It does have an iffy fueling spot but much higher up the rev range but it's perfect in traffic
There's no iffy fueling on the 750, but then again I don't trickle along at low rpm in high gears, or go out of my way to find bad fuelling, I also owned a Husky 610 with a Dell Horrible carb, which fuelled worse than a poorly tuned two stroke, so what I consider good might be what Taipan considers bad.Supermofo wrote: Mon Mar 27, 2023 4:35 pm What you want is a nice GSXS 1000. Pick a gear, any gear will work at about 20mph and it trickles along nicely. It does have an iffy fueling spot but much higher up the rev range but it's perfect in traffic
