Finding a lathe person
BBB
Has thanked: 292 times
Been thanked: 79 times
Post by BBB »
Need to find somewhere that can lathe down a set of caliper spacers, nothing major just removing the shoulder where it meets the fork.
How do I find a machine shop that can do it? Google brings up lots of industrial engineering companies. What do samll scale engineers call themselves?
South Derbyshire /Leicester area
Has thanked: 6378 times
Been thanked: 4755 times
Re: Finding a lathe person
BBB wrote: Thu Mar 23, 2023 3:50 pm Need to find somewhere that can lathe down a set of caliper spacers, nothing major just removing the shoulder where it meets the fork.
I just googled 'machine shop near xyz' and found one that looks like they do one-offs at a reasonable price. Unfortunately not in your area. You could try local historic bike/car groups...chances are they know people who can make things or make things fit.
Has thanked: 2405 times
Been thanked: 3630 times
Normally word of mouth is best bet. Failing that, visit the metal-bashing end of town and ask around. Sorry if that seems a bit flip, but it was how I 'discovered' the various trades I needed. Once you've found a lathe man/engineer, ask them for a recommendation for a welder, or a plater or whatever else you need.
The caveat is that I'm based in Sheffield and it's harder to avoid the various metal bashing trades than it is to find them.
Try Nick Chambers, he's on Facebook
Has thanked: 1508 times
Been thanked: 1413 times
You're looking for a machinist... with a mill or a lathe. We find these miserable buggers in machine shops.
https://www.google.com/search?client=fi ... +leicester
Has thanked: 2551 times
Been thanked: 6247 times
Anyone who's old-boy-in-a-flatcap enough to do what you want ain't gonna have a website. That's your problem really. So it's word of mouth as ya man says! Or randomly mooch about industrial estates?
Even 'small machine shops' are predominantly CNC now, there's not a huge market for manual stuff.
Has thanked: 229 times
Been thanked: 575 times
I’m a bit of a lathe person. I just pronounce it differently.
Has thanked: 1346 times
Been thanked: 1722 times
Wossname wrote: Sat Mar 25, 2023 4:57 pm I’m a bit of a lathe person. I just pronounce it differently.
Mr Turner?
Screwdriver
Has thanked: 256 times
Been thanked: 740 times
Post by Screwdriver »
Post them down to me and I'll do it.
BBB
Post by BBB »
Screwdriver wrote: Sat Mar 25, 2023 11:42 pm Post them down to me and I'll do it.
Thank you, I'll get measured up and arrange postage.
Probably should start a thread in the projects section. Who is best for image hosting these days?
Has thanked: 6193 times
Been thanked: 5087 times
Purthon?
Screwdriver
BBB wrote: Tue Mar 28, 2023 9:59 am
Alrighty. I assume this forum has an "attachment" option.
If you want to post images inline, I use IMGUR. Google photos is also a good one.
Horse wrote: Tue Mar 28, 2023 10:10 am
Purthon?
That thit.
Been thanked: 2617 times
I use flickr, but only through habit and not because I've looked at other options.
PitaNaanRoti
Has thanked: 25 times
Been thanked: 54 times
Post by PitaNaanRoti »
Kieron Sanger In Leicester.
Or the Machine Shop
Has thanked: 836 times
Been thanked: 1239 times
I use postimages.org. I like it because there are no accounts needed, upload the photo, set the size and it gives a URL.
I wouldn't use it for long term storage but for forums it's good.
BBB
Post by BBB »
Giving this a try
BBB
Post by BBB »
If you can see the image it's the shoulder I need machining off to sit flush against the brake mount.
Screwdriver
I can't really see what the part looks like from the picture. I assume it is something like this:
...and you want the little stepped section to be machined off flush.
I guess it is intended to fit into a pocket on the fork leg which your machine doesn't have. Does the caliper have a similar stepped shoulder section which fits into the spacer? You should probably double check the spacer isn't upside down too just in case.
I can knock that little collar off yes. If it is to become flush, you won't need to measure it, just make sure the bolt doesn't bottom out when the spacer is relieved. If it does, send those too and I can turn off the same amount of length.
The inset and the stepped shoulder are to ensure alignment of the caliper to the mounting bracket. Without it, there could be a tiny amount of play equivalent to the clearance of the bolt to the caliper mounting hole. If that becomes an issue, that's on you. :thumbup:
If there is runout in the disk(s), the spacer is designed to hold the caliper firmly in place. Without that fitting, all that stops the caliper from moving to follow runout is the bolt tension against the fork mounting face.
Plato
