Chains _ any better than others
Has thanked: 1829 times
Been thanked: 1469 times
I have just had a chain snap on me today - not something I really want to repeat TBH.
Combination of roots and mud pushed my gear cable end into the chain at the top jockey wheel - and seemed to prize the plates apart.
KMC / SRAM/ Shimano all much of a muchness?
If I ran a 10 speed chain on an 11 speed set up, is it less likely to snap?
Thoughts
Taff
Has thanked: 255 times
Been thanked: 885 times
Re: Chains _ any better than others
Post by Taff »
I tend to stick to sram chains after the last kmc chain snapped really quite early in it's life (even considering it's on an ebike).
Has thanked: 5451 times
Been thanked: 13087 times
Mr Moofo wrote: Thu Mar 02, 2023 7:51 pm I have just had a chain snap on me today - not something I really want to repeat TBH.
Thoughts
I'd have thought a 10sp on an 11sp would be likely to not work well
weeksy wrote: Thu Mar 02, 2023 8:51 pm
Thoughts
reading about it, it seems to be plate dimension rather than thickness / strength.
I think it is a KMC that was on today ( will check - as I suspect it was a KMX lite - which was probably not a good choice.
Timmy
Has thanked: 21 times
Been thanked: 54 times
Post by Timmy »
10sp chains are thicker across the plates and won't be a good fit for an 11sp cassette.
Has thanked: 2942 times
Been thanked: 1883 times
Always use posher end SRAM chains as I never seem to have much luck with Shitmano, Wipperman or KMC. Just stay on top of chain wear with a checker.
MingtheMerciless wrote: Fri Mar 03, 2023 9:04 am Always use posher end SRAM chains as I never seem to have much luck with Shitmano, Wipperman or KMC. Just stay on top of chain wear with a checker.
See i'm different, i barely ever consider my chains, i run fairly low end chains and only use GT85, never use the chain checker, never have any issues.
Shimano have broken on me before - so I avoid them. So will look at the up-market SRAM ones - but I don't want lightweight
Mr Moofo wrote: Fri Mar 03, 2023 9:09 am Shimano have broken on me before - so I avoid them. So will look at the up-market SRAM ones - but I don't want lightweight
Maybe look an an e-bike chain if weight isn't a consideration.
MingtheMerciless wrote: Fri Mar 03, 2023 9:24 am
That's one step to close to having an e-bike
