What bike/scoot for about 2k?
Has thanked: 2250 times
Been thanked: 1243 times
Re: What bike/scoot for about 2k?
Le_Fromage_Grande wrote: Fri Feb 17, 2023 11:15 am
v8-powered wrote: Thu Feb 16, 2023 9:09 pm
Le_Fromage_Grande wrote: Thu Feb 16, 2023 8:00 pm Aprillia Falco in Colchester, £1600
Where's that advertised?
Faceberk, it's got flat bars and needs a little work, and it's very yellow.
Found it! It's been lowered too which is a shame but I've messaged the guy anyway...
Has thanked: 2410 times
Been thanked: 3647 times
v8-powered wrote: Fri Feb 17, 2023 12:09 pm
That's almost certainly been done by using different triangles/dogbone. Originals are readily available. Could possibly be done by using shorter shock, but unlikely.
mangocrazy wrote: Fri Feb 17, 2023 12:31 pm
Aaahh, yes - forgot that was a trick with them. I may have a look at it but by sounds of it needs a brake rebuild, clutch slave and by looks of it 2 new exhaust cans.
Has thanked: 4376 times
Been thanked: 2864 times
v8-powered wrote: Fri Feb 17, 2023 1:00 pm
You're not selling it to me :lol:
Supermofo wrote: Fri Feb 17, 2023 1:23 pm
Must admit more I think about it, the more it's not for me. Have a house to decorate and can't be arsed repairing a bike!
There are probably better ones about for less money. I'll keep my eyes open on the Falco forums I'm on and see what comes up, if you like?
mangocrazy wrote: Fri Feb 17, 2023 2:23 pm There are probably better ones about for less money. I'll keep my eyes open on the Falco forums I'm on and see what comes up, if you like?
That would be good thanks. Having owned a couple of RSVs I'm quite fond....
Will do. Can you send me a link to the one you looked at? I've changed just about every part of my front brake and clutch systems, so might have spares...
I've just had a quick shufty at ebay and the cheapest Falco on there is £2695, so maybe I was a bit harsh about values. Then again, how many bikes actually sell for the sticker price?
mangocrazy wrote: Fri Feb 17, 2023 2:32 pm Will do. Can you send me a link to the one you looked at? I've changed just about every part of my front brake and clutch systems, so might have spares...
I've dropped you a PM...
Bigyin
Has thanked: 1414 times
Been thanked: 2684 times
Post by Bigyin »
Le_Fromage_Grande wrote: Fri Feb 17, 2023 11:38 am
Probably, I think if I were to go abroad I'd use the Channel Tunnel now, my experiences of ferries weren't great
If you have a bike fully loaded for touring be ready for the bump half way through the tunnel where the 2 sides met ....... i am always ready for it now as first time my bike almost fell over off the sidestand :shock:
Has thanked: 541 times
Been thanked: 7563 times
Bigyin wrote: Fri Feb 17, 2023 7:25 pm
Only done the chunnel once and that was last summer, didn't notice any bumps, was surprised at just how smooth it was!
I usually use the ferry, cos Barnsley is four hours from Dover and the hour on the boat is a nice rest, I used the tunnel last time because it's cheap as chips if you use Clubcard points and I'm tight.
Bigyin
Post by Bigyin »
KungFooBob wrote: Fri Feb 17, 2023 7:29 pm
I havent used a ferry to get to France since the Chunnel opened. Every time i get on a ferry its a shitty choppy puke inducing crossing ...Hull to Rotterdam, Stranraer to Larne, Dover to Calais, Liverpool to Isle of Man ....every single one of them :mrgreen:
The biggest time i noticed the bump was on the crossing en route to eventually get to Norway but the bikes were loaded to the absolute maximum for almost 3 weeks away complete with food and all camping stuff. Other times its barely noticeable but those times the bikes and luggage were lighter
Has thanked: 6388 times
Been thanked: 4787 times
Never noticed a bump either. (If it's where the tunnellers met, it won't be in the middle. We dug more of it than the French :lol: Amazingly, when they did join up the offset was a mere 14.3in...but I think they smoothed out the track. :thumbup: )
Demannu
Has thanked: 65 times
Been thanked: 1235 times
Post by Demannu »
(Olly mode on) deauville is what you want, or a scarver(om/)
Demannu wrote: Fri Feb 17, 2023 8:25 pm (Olly mode on) deauville is what you want, or a scarver(om/)
Are you at this very moment watching Coronation Street?
KungFooBob wrote: Fri Feb 17, 2023 7:29 pm I used the tunnel last time because it's cheap as chips if you use Clubcard points and I'm tight.
How does one use Clubcard points for a Chunnel crossing? I'm intrigued...
mangocrazy wrote: Fri Feb 17, 2023 10:09 pm
https://secure.tesco.com/clubcard/vouch ... 003223.prd
Every £5 of clubcard points can be exchanged for £15 worth of Chunnel vouchers.
Nice one, KFB... :thumbup:
Has thanked: 609 times
Been thanked: 4131 times
My idea of fully loaded for touring is a spare pair of pants and a credit card.
Has thanked: 2559 times
Been thanked: 6270 times
Count Steer wrote: Fri Feb 17, 2023 7:53 pm
It has two (I think) places mid crossing where they can "change tubes". It means they can switch off bits of tunnel for maintenance access etc. Maybe said bump was going through the points, which would also explain why only some people experience it.
Re: Clubcard vouchers, its always worth checking the rewards offers, generally get three times face value on all sorts of things!
