Oxford Hinterland kit
Has thanked: 2578 times
Been thanked: 2308 times
As some of you may recall my previous waterproof kit wasn't. After much research and comparing I finally lashed out on some Oxford Hinterland kit, their top of the range stuff that got some good, almost rave, reviews in the bike press. After a few jaunts out in the kit here is a brief note of what's good and what's not.
Good things.
It is waterproof. and reasonably warm. Haven't tried its venting features yet, but the zips are waterproof.
It is fairly reasonable in price, not by any means cheap, but not the most expensive.
All the pockets are waterproof too, but see below.
It is comfortable.
Bad things.
The jacket has several inside pockets (good) but only 2 fairly small outside pockets and no big poachers pocket at the back
The trousers have 2 waterproof pockets, but they are sited so that you can't access them easily unless you are standing up. No nice convenient cargo pockets on the thighs.
The jacket liner zips in, but doesn't close separately, so you need to make sure it is snug as you do up the main zip.
The main jacket zip is a weedy thing, and fiddly to get started. A big chunky one would be much better
The trouser liners seem to ride up over the top of my boots.
The ankle closure is velcro rather than zip. Works ok, but on a naked bike it is sitting in all the shit. Time will tell.
Anyone else have this stuff?
Has thanked: 4385 times
Been thanked: 2867 times
Re: Oxford Hinterland kit
Not got the Hinterland, I've got the Mondial in Black
https://www.sportsbikeshop.co.uk/motorc ... rod/433519
I really like it as a jacket, comfy, looks good, lots of pockets including ones the Hinterland is missing on the outside and back, really good/effective vents on the arms and chest, with 2 big exhaust vents on the back. The chest ones fold back so you get lots of air flow. I only paid £200 so seems a bit of a bargain now.
Bad points: It's only A rated which is all that was available at the time in textile jackets when I bought it. I have considered swapping for the Hinterland to get AA but I prefer the look of the Mondial so considering upgraded armour which might help?? The back protector pocket is a bit short and only fits the Oxford back protector, would prefer to use my longer D30 from my Furygan leather jacket. Cuffs are also pretty tight so really difficult to get my Spring/Autumn gloves under the cuff if you want to wear them that way, summer gloves are fine though.
Overall if it was AA it'd be perfect for the price IMO. I believe they are waterproof too, but I don't do wet stuff. I did go for it on the basis that if I was caught out I wouldn't get wet though so hopefully it is. Prior to the Mondial I'd never considered Oxford stuff, but the press seem to really rate it, reviews of punters are good and I like it.
Supermofo wrote: Fri Feb 17, 2023 2:28 pm Prior to the Mondial I'd never considered Oxford stuff, but the press seem to really rate it, reviews of punters are good and I like it.
I always wrote off Oxford as cheap and cheerful, but it seems to have improved it's range. Last suit I bought was superb in hot dry weather, with lots of vents. Unfortunately it was a zip-out liner thing, and when you are touring the last thing you want is liners. In they make it hot and sweaty, out and your waterproofness is near zero. Getting them in or out requires getting all your kit off, and about 20 mins of struggling to get it all hitched up. Not to be attempted at the roadside. That is when I discovered my oversuit was also pants and leaked like the proverbial sieve!
I
Has thanked: 2259 times
Been thanked: 1245 times
I had 2 of the Mondial jackets from SBS, both leaked and went back. Ended up with an Alpinestars Andes V3 which has been spot-on.
v8-powered wrote: Fri Feb 17, 2023 4:25 pm I had 2 of the Mondial jackets from SBS, both leaked and went back. Ended up with an Alpinestars Andes V3 which has been spot-on.
That's reassuring! I'll stick to riding in the dry as much as possible then.
Supermofo wrote: Fri Feb 17, 2023 6:03 pm
Maybe I was unlucky x2 but wasn't a good experience despite the reviews, perhaps a FWB jacket?
Has thanked: 1765 times
Been thanked: 2107 times
I've never owned anything that will pass the wet motorway test. ☹
Dodgy69 wrote: Fri Feb 17, 2023 10:53 pm I've never owned anything that will pass the wet motorway test. ☹
I had a Hein Gericke Goretex 2-piece that was the dogs nuts, prior to that a Frank Thomas jacket from the retro years
Tbh, I had been looking at the Oxford mondial that mofo mentions recently as I'm fancying a laminate jobby. My current textile has the separate waterproof zip in liner which i never really trust and usually chuck on a cheap waterproof overjacket, after ive already got soaked obviously.
So, my query is, are laminated better than goretex type jackets with waterproof layer. 🤷‍♂️
Has thanked: 6416 times
Been thanked: 4798 times
Dodgy69 wrote: Sat Feb 18, 2023 1:01 pm
Between us, me and Mrs Pillion have had 3 laminated suits and they have been superb. No leaks at all. (With pop in the thermal liners as needed).
The real beauty is that they don't 'wet out' on the surface so, when you put them on the next day after being out in the rain they don't feel ugh. More or less shake dry. After a ride down to the LeMans area in the rain, out of a group of 20ish only 4 of us went out riding the next day and we all had laminated kit. The others couldn't bring themselves to put their gear on as it hadn't dried.
The other thing is if your gear does wet out while riding it chills you as the wind evaporates the water in the surface layer.
Wouldn't buy anything else for riding in colder, wetter weather. Worth every £. :thumbup:
Yep, I've got an alpine star goretex and once it's wet, weighs about the same as the bike. 👎
Has thanked: 6245 times
Been thanked: 5120 times
Count Steer wrote: Sat Feb 18, 2023 1:11 pm The other thing is if your gear does wet out while riding it chills you as the wind evaporates the water in the surface layer.
BMW used to sell an unlined oversuit to keep your heavy duty waterproof suit dry :wtf: :lol:
Horse wrote: Sat Feb 18, 2023 1:52 pm
I had a 1-piece BMW oversuit for the spring/summer to put on over the airflow kit. It was fine, if a little bulky to pack. Loaned it to someone for a big trip.....
My first laminated suit was BMW branded...it err shrank. :lol:
The worst bit of kit had a removable 'goretex' liner. You didn't actually get wet, but it felt like you were. 'Orrible. + the outer used to get soggy.
Has thanked: 541 times
Been thanked: 7597 times
Got an email from SBS, it mentioned Hinterland, reminded me of this thread. It's on sale!
https://www.sportsbikeshop.co.uk/motorc ... %3D.SK2Xaf
As long as you like blue.
KungFooBob wrote: Sat Feb 25, 2023 8:47 pm Got an email from SBS, it mentioned Hinterland, reminded me of this thread. It's on sale!
I bought a blue one a little while ago - at full price! Fucksticks! :angry-cussingblack:
Cousin Jack wrote: Thu Mar 02, 2023 8:42 pm
:( hate that so bloody annoying
Ssray
Has thanked: 117 times
Been thanked: 123 times
Post by Ssray »
I've had the hinterland jacket for a while,
eBay is quite often a source of these quite cheap, the person I bought mine from had loads of Oxford stuff for sale, mine was about half the new price
So far I really like it, it seems far too thin at first, but it's only really cold days that I need more than a thin fleece underneath it.
I would prefer a bit more collar room or a storm type collar
Hot_Air
Has thanked: 1380 times
Been thanked: 253 times
Post by Hot_Air »
Ssray wrote: Sat Apr 01, 2023 10:35 am I've had the hinterland jacket for a while,
+1 for eBay for motorcycle clobber. I’ve bought all manner of high-quality gear for low prices, thanks to a little patience and using eBay alerts for what I’m after.
Has thanked: 9912 times
Been thanked: 10216 times
Me neither,unless you put a cheap plastic waterproof over it all.
It ain't a thing for me now,but it's pretty shit when you spend good money to buy waterproof gear and it never is. Some things never change with bike gear.
Skub wrote: Wed Apr 12, 2023 8:54 pm
Let's be fair, 300 miles on a wet motorway is a VERY severe test. I doubt any fabric made can be completely waterproof for that, add in some seams and a bit of wear..... An oversuit takes the worst, it leaks a little, and the real kit takes care of the leaks.
