A ton's worth of stupidity
- Been thanked: 2608 times
Re: A ton's worth of stupidity
Nice, I'll have a snout about once I get back from the big island next week ish, today will be spend tidying, packing, laundrying, etceteraing for tomorrow I join the prop set and swan about airports looking all glamorous and exotic.
- Has thanked: 15843 times
- Been thanked: 10189 times
Cheaper and you can put an offer in, but if you did fancy a punt, they'll need a fair bit of cleaning up!
https://www.ebay.co.uk/itm/125670791097 ... R_yVgtvKYQ
- Has thanked: 7749 times
- Been thanked: 2502 times
You'll need a hat for that, I do hope you've got a good one.
I have a hat, striking enough to distract from the rest of the shambles.
This doesn't look cheap aftermarket to me. The rubber inset is quite soft and the whole thing doesn't feel cheap. The steel looks Japanese OEM too, at least to my eye.
The usual bad photos:
It looks close to a few Yamaha footpegs I've looked at except for the spring peg, that should be easy enough to sort.
- Has thanked: 2392 times
- Been thanked: 3587 times
You could have a look on cmsnl.com (Dutch). Once you've got the part number you can use the 'what other bikes does this part fit' function.
- Has thanked: 2546 times
- Been thanked: 6213 times
