A ton's worth of stupidity
Been thanked: 2618 times
Re: A ton's worth of stupidity
Nice, I'll have a snout about once I get back from the big island next week ish, today will be spend tidying, packing, laundrying, etceteraing for tomorrow I join the prop set and swan about airports looking all glamorous and exotic.
Has thanked: 15960 times
Been thanked: 10248 times
Cheaper and you can put an offer in, but if you did fancy a punt, they'll need a fair bit of cleaning up!
https://www.ebay.co.uk/itm/125670791097 ... R_yVgtvKYQ
Has thanked: 7818 times
Been thanked: 2529 times
cheb wrote: Wed Feb 15, 2023 6:49 am Nice, I'll have a snout about once I get back from the big island next week ish, today will be spend tidying, packing, laundrying, etceteraing for tomorrow I join the prop set and swan about airports looking all glamorous and exotic.
You'll need a hat for that, I do hope you've got a good one.
I have a hat, striking enough to distract from the rest of the shambles.
This doesn't look cheap aftermarket to me. The rubber inset is quite soft and the whole thing doesn't feel cheap. The steel looks Japanese OEM too, at least to my eye.
The usual bad photos:
It looks close to a few Yamaha footpegs I've looked at except for the spring peg, that should be easy enough to sort.
Has thanked: 2406 times
Been thanked: 3635 times
You could have a look on cmsnl.com (Dutch). Once you've got the part number you can use the 'what other bikes does this part fit' function.
Has thanked: 2552 times
Been thanked: 6250 times
cheb wrote: Thu Feb 16, 2023 6:20 am The steel looks Japanese OEM too
Didn't know Hattori Hanzo made footpegs.
I'm back home and have the bits I need so: viewtopic.php?t=242
