A ton's worth of stupidity
- Been thanked: 2618 times
While checking which battery I need for the TDR I managed to knock it over. That's one clutch cover that's not quite up to its job anymore.
- Has thanked: 15959 times
- Been thanked: 10248 times
Re: A ton's worth of stupidity
Pah! I bet plenty on here can top that! Not me though. Oh no. You'll need witnesses to verify it. I've said too much!
- Has thanked: 9829 times
- Been thanked: 10145 times
Top ruse man.
I wonder if I accidentally scratch my stock wheels, could I get Mrs.Skub to believe a set of carbon wheels is the only sound option?
I've found a replacement for about £40. And they only want £39.99 to deliver it to me. Time to start phoning round to see who'll take the job of posting it on to me. My usual accomplices are either away on holiday or recovering from an operation.
- Has thanked: 1346 times
- Been thanked: 1722 times
Aye, that would suit. I'm in no rush for it, if I collect I'll likely get a free cup of tea.
- Has thanked: 10266 times
- Been thanked: 6886 times
HTF ?
In 8 years racing and 40 crashes, I never knackered a clutch cover.
Top bombing
Top bombing
- Has thanked: 2636 times
- Been thanked: 1523 times
The rest of the bike was f*cked but you saved the clutch cover... :impressed:
I did my bestThe Spin Doctor wrote: ↑Tue Feb 07, 2023 10:15 pmThe rest of the bike was f*cked but you saved the clutch cover... :impressed:
The brake lever poked into it hard enough to crack it. I'll post a pic later when I've taken the thing apart.
Gasket face looks good, it looks like its been down the road on its side and been scabbled then smoothed off a bit but I can't see any evidence of it being cracked and it looks to me like it'll paint over just fine and most importantly, hold oil.
Clutch arm is a bit rusty but perfectly servicable, a wire brush would sort it.
It's possible I've missed something but it all looks fine to me.
Earl Grey or English Breakfast?
English breakfast please. The clutch arm etc on mine is all good so it can be swapped over.
And thanks
And thanks
- Has thanked: 6378 times
- Been thanked: 4756 times
Will there be biscuits?
Chocolate Hobnobs! I'm on my way!demographic wrote: ↑Thu Feb 09, 2023 9:27 pmMaybe, play yer cards right and it'll be Chocolate Hobnobs.
And possibly a bit more than a ton. The right hand foot peg snapped too, it fell off today when I moved the bike.
2YK-27421-00. This part is no longer available. Arse. It's not just bash on an aftermarket one as it has to fold and lock when you use the kickstart.
I saw those shortly after I posted. Mine look nothing like those, they are longer, have rubber tops and the nodule that hits the road first.
Some investigation is in order, the bikes been modded so there might be other Yamahas with suitable pegs.
Sounds like soemones just fitted generic fold backpegs to the mounts. Have they been filed down or owt?
The ones in the diagram look the same as the ebay listing and no x-ref to other models?
https://www.fowlersparts.co.uk/parts/view/2YK-27421-00
