Screen mounted wide screen mirror thingies?
Has thanked: 15981 times
Been thanked: 10258 times
Anyone used one of these? I think they'd be more popular if they were any good?
Has thanked: 10276 times
Been thanked: 6891 times
Re: Screen mounted wide screen mirror thingies?
WTF?
Bigyin
Has thanked: 1412 times
Been thanked: 2680 times
Post by Bigyin »
Seen one on the bike of a bloke who was about 80 years of age as he had problems turning his head far enough to check his blindspots while riding so used one of these and was quite happy with it
Yorick wrote: Mon Feb 06, 2023 6:46 pmWTF?
Has thanked: 599 times
Been thanked: 2451 times
Bigyin wrote: Mon Feb 06, 2023 6:49 pm Seen one on the bike of a bloke who was about 80 years of age as he had problems turning his head far enough to check his blindspots while riding so used one of these and was quite happy with it
Wonder if it'd give me enough vision to ditch the sticky out mirrors on the Tmax? Under £11 delivered, so wont be an expensive mistake I suppose, or it could even work out. :think:
Has thanked: 2552 times
Been thanked: 6260 times
Years ago at the NEC show I tried a helmet which had a rear view mirror built in. There was a strip of mirror across the (inside) top of the "visor hole" connected to a sort of periscope setup that looked out the back of the helmet. It was way less clunky than I'm making it sound.
The view was pretty much what you'd get from a car rear view mirror.
I've never seen the like since!
Taff
Has thanked: 255 times
Been thanked: 885 times
Post by Taff »
Taipan wrote: Mon Feb 06, 2023 6:45 pm Anyone used one of these? I think they'd be more popular if they were any good?
The person that parks next to me in work has got one, it looks fookin daft. I'm not normally worried about how things look as long as they do the job but this is a daft idea too far for me. Surely the old blind spot mirrors would do the job without getting distracted by your own good looks every time you look down ☺️
Not too bothered what it looks like tbh. The mirrors on my bike stick out too far and makes filtering awkward. I can shove them forward out of the way but still want some rear vision, particularly for the blind spot, this might offer that?
Has thanked: 2636 times
Been thanked: 1523 times
Mr. Dazzle wrote: Mon Feb 06, 2023 7:40 pm Years ago at the NEC show I tried a helmet which had a rear view mirror built in. There was a strip of mirror across the (inside) top of the "visor hole" connected to a sort of periscope setup that looked out the back of the helmet. It was way less clunky than I'm making it sound.
Still around...
The thing I never quite got is if you look left, your 'rear view' will be to the right. And vice versa.
https://www.worldofreevu.com/
Has thanked: 6199 times
Been thanked: 5090 times
The Spin Doctor wrote: Tue Feb 07, 2023 12:27 am
If you're looking right, then you're not looking behind. Similar with mirrors, if you're looking ahead, you're not looking over your shoulder.
It would mean mentally retraining yourself to consciously use the built-in mirror.
My first R-RT had the little stuck on wedge things on the mirrors. I never consciously used them.
Everything in your car rear view mirrors (or indeed, bike mirrors) is 'backwards' innit - but you brain calibrates it out.
Has thanked: 1829 times
Been thanked: 1469 times
I guess they make you look thinner...
I had stickers:
"Everything in the rear view mirror is faster than it appears"
Mr. Dazzle wrote: Tue Feb 07, 2023 9:21 am Everything in your car rear view mirrors (or indeed, bike mirrors) is 'backwards' innit - but you brain calibrates it out.
But not upside down
Horse wrote: Tue Feb 07, 2023 9:57 am
But not upside down
Yeah I wasn't going to mention that. It's a proper melon scratcher, a great example of a really simple question that requires some thought to answer.
Has thanked: 9836 times
Been thanked: 10149 times
Sir may require a rear view camera.
https://www.ebay.co.uk/itm/264089065828 ... WwQAvD_BwE
Skub wrote: Tue Feb 07, 2023 11:14 am Sir may require a rear view camera.
No idea whether this works in realtime, but any camera system needs it.
Honda's little leccy car has cameras instead of mirrors. The Aston Martin Valkyrie does too. In both cases I'm guessing it's for aerodynamic reasons.
Has thanked: 2919 times
Been thanked: 2061 times
Mr. Dazzle wrote: Tue Feb 07, 2023 12:50 pm Honda's little leccy car has cameras instead of mirrors. The Aston Martin Valkyrie does too. In both cases I'm guessing it's for aerodynamic reasons.
I think I might miss the physical door mirrors - sometimes use them like cat's whiskers, knowing that they're the widest point.
