Wouldn't there be a cog thing between them to resist that?
- Has thanked: 5945 times
- Been thanked: 4933 times
- Has thanked: 2611 times
- Been thanked: 6016 times
It'd be perfectly possibleb to put something between those discs (the belt teeth like you say), but something also tells me they weren't exactly going for the last word in performance
Check out how fat F1 brakes are for an idea of what is possible, you just need "insides" to your discs.
- Has thanked: 15614 times
- Been thanked: 9854 times
Cars have had vented discs for decades. Trouble with bikes is the close proximity of the disc to the wheel. Start fitting wider discs and you'll have problems with calipers hitting the spokes etc. They fittted vented discs to some gp bikes iirc, but they looked ridiculous when I saw them?
- Been thanked: 2501 times
Twin close coupled discs were a thing briefly. Two discs, one caliper and 3 pads, the centre pad being double sided.
In my memory they came out at about the same time, or maybe a bit later, as rim mounted discs but were even less successful. Has anyone but Buell used rim mounted discs?
Berringer (sic) was it not? They were supposed to be the next big thing at one point ISTR.
WRT vented discs...AIUI there's still not universal agreement on which way the air flows through them! Yeah they work but people aren't 100% on why.
Edit: yeah that's them...
I think it was on a moto gp bike, huge great things sticking out past the forks. Probably worked well as brakes, but must have messed the aerodynamics up! Plus it looked hideous!
The primary point of ventilated discs is to keep them cooler. MotoGP uses carbon/ceramic discs which can run way hotter by default. Maybe they just found the extra cooling capability wasn't needed?
F1 and aircraft etc are another step up in braking requirements, so they have both combined...ventilated and Carbon.
Maybe.
Maybe.
I'm starting to think i'm imaginig it, but I'm sure one of the moto gp bikes had a set of discs outside the forks?
- Has thanked: 9691 times
- Been thanked: 9705 times
The eco thing has got out of hand,even the seats now have cats.
- Has thanked: 6264 times
- Been thanked: 4614 times
Caption: Ha! Those punk Biker Mice from Mars won't know what's hit 'em...when we've finished having a snooze.
- Has thanked: 465 times
- Been thanked: 1373 times
- gremlin
- Has thanked: 776 times
- Been thanked: 4515 times
- Has thanked: 10117 times
- Been thanked: 6649 times
Just had a stroll down to beach to watch the high tide peak. I love this view.
Then saw some typical Canarian parking
- gremlin
