DefTrap
Has thanked: 2265 times
Been thanked: 2193 times
Post by DefTrap »
cheb wrote: Wed Jan 18, 2023 8:47 pm I'm sure I've read of an American production bike having a combined brake disc and sprocket. American production bike, kind of limits it to Harley or Indian then.
Plenty enough of them in BackStreetHeroes over the years - I dunno if they're much use in practice for all the obvious reasons - but then who really uses the rear brake anyway? ;)
RolandSandsDesign, amongst others, do parts, demo'd here on their Softtail Bomber (well you can glimpse it anyway) at about a minute in.
As it's RSD they make it look mega cool with all the lifestyle shenanigans, and in a desert with priddy gurls, and now of course I want all of these beautiful, expensive and really unpractical bikes.
Has thanked: 10271 times
Been thanked: 6887 times
This just came up on FB.
Make your own jokes up :obscene-birdiedoublered:
Been thanked: 7536 times
Pirahna wrote: Wed Jan 18, 2023 10:18 pm
Taipan wrote: Wed Jan 18, 2023 10:02 pm
Belt cog, or pulley, would be too wide.
Would I be right to be concerned about heat transfer to the 'rubber' belt?
KungFooBob wrote: Fri Jan 20, 2023 5:15 pm
And the discs may deform on full braking force.
Yorick wrote: Fri Jan 20, 2023 5:53 pm
And the caliper bolts need tightening ;)
Has thanked: 6198 times
Been thanked: 5088 times
Pirahna wrote: Wed Jan 18, 2023 10:18 pm Image
Wouldn't there be a cog thing between them to resist that?
Ant
Has thanked: 39 times
Been thanked: 227 times
Post by Ant »
I'm not surprised that disappeared!
Has thanked: 2552 times
Been thanked: 6257 times
Horse wrote: Fri Jan 20, 2023 9:33 pm
It'd be perfectly possibleb to put something between those discs (the belt teeth like you say), but something also tells me they weren't exactly going for the last word in performance :D
Check out how fat F1 brakes are for an idea of what is possible, you just need "insides" to your discs.
Has thanked: 15964 times
Been thanked: 10249 times
Cars have had vented discs for decades. Trouble with bikes is the close proximity of the disc to the wheel. Start fitting wider discs and you'll have problems with calipers hitting the spokes etc. They fittted vented discs to some gp bikes iirc, but they looked ridiculous when I saw them?
Been thanked: 2618 times
Twin close coupled discs were a thing briefly. Two discs, one caliper and 3 pads, the centre pad being double sided.
In my memory they came out at about the same time, or maybe a bit later, as rim mounted discs but were even less successful. Has anyone but Buell used rim mounted discs?
Berringer (sic) was it not? They were supposed to be the next big thing at one point ISTR.
WRT vented discs...AIUI there's still not universal agreement on which way the air flows through them! Yeah they work but people aren't 100% on why.
Edit: yeah that's them...
I think it was on a moto gp bike, huge great things sticking out past the forks. Probably worked well as brakes, but must have messed the aerodynamics up! Plus it looked hideous!
The primary point of ventilated discs is to keep them cooler. MotoGP uses carbon/ceramic discs which can run way hotter by default. Maybe they just found the extra cooling capability wasn't needed?
F1 and aircraft etc are another step up in braking requirements, so they have both combined...ventilated and Carbon.
Maybe.
I'm starting to think i'm imaginig it, but I'm sure one of the moto gp bikes had a set of discs outside the forks?
You're not thinking of disc covers are you?
Has thanked: 9835 times
Been thanked: 10148 times
Taipan wrote: Sat Jan 21, 2023 10:36 am
Boudica chariot style?
The eco thing has got out of hand,even the seats now have cats.
Has thanked: 6381 times
Been thanked: 4761 times
Skub wrote: Sun Jan 22, 2023 4:19 pm The eco thing has got out of hand,even the seats now have cats.
Caption: Ha! Those punk Biker Mice from Mars won't know what's hit 'em...when we've finished having a snooze.
Has thanked: 485 times
Been thanked: 1428 times
