Been thanked: 2501 times
I'm sure I've read of an American production bike having a combined brake disc and sprocket. American production bike, kind of limits it to Harley or Indian then.
Has thanked: 10117 times
Been thanked: 6649 times
cheb wrote: Wed Jan 18, 2023 8:47 pm I'm sure I've read of an American production bike having a combined brake disc and sprocket. American production bike, kind of limits it to Harley or Indian then.
I think I saw a shaft drive bike with a brake on the shaft.
Has thanked: 2611 times
Been thanked: 6016 times
Probably a belt, given KFB's observation?
I feel like I've seen combined brake/pulley setups in industry but I could be imagining that.
There's been bikes with brake discs on the gearbox output shaft too, ATK IIRC.
And proper lLandrovers has a drum transmission* brake.
*There's got to be a woke joke in there.
Has thanked: 15614 times
Been thanked: 9854 times
Mr. Dazzle wrote: Wed Jan 18, 2023 9:27 pm
Belt cog, or pulley, would be too wide.
Has thanked: 465 times
Been thanked: 1373 times
Wag going to try my hand at making some but this seems a whole lot easier :lol:
Has thanked: 1775 times
Been thanked: 1109 times
Taipan wrote: Wed Jan 18, 2023 10:02 pm
Mid calliper spacers, @mangocrazy is that you?
cheb wrote: Wed Jan 18, 2023 9:55 pm There's been bikes with brake discs on the gearbox output shaft too, ATK IIRC.
The classic Jaguar back axle had inboard discs, did it not? They must have made thousands of those.
Yambo
Has thanked: 614 times
Been thanked: 1632 times
Post by Yambo »
Mr. Dazzle wrote: Thu Jan 19, 2023 8:39 am
Mine (well, it was actually a Daimler Sovereign ;) ) certainly did and that was back in the 1970s.
How do you change the pads? Presumably you get in through those 'windows' in teh black subframe?
Has thanked: 2729 times
Been thanked: 1919 times
The XJS had that set-up too, as well as the Sovereign.
Has thanked: 216 times
Been thanked: 668 times
Mr. Dazzle wrote: Thu Jan 19, 2023 8:45 am How do you change the pads? Presumably you get in through those 'windows' in teh black subframe?
No...you drop the whole assembly ( or lift the back seat and cut a hole in the floor).
Rover 2000's were similar but easier to service.
Oh right, it's just as daft as it looks then :D
Reason number 75 they don't do it that way much.
DefTrap
Has thanked: 2269 times
Been thanked: 2088 times
Post by DefTrap »
Plenty enough of them in BackStreetHeroes over the years - I dunno if they're much use in practice for all the obvious reasons - but then who really uses the rear brake anyway? ;)
RolandSandsDesign, amongst others, do parts, demo'd here on their Softtail Bomber (well you can glimpse it anyway) at about a minute in.
As it's RSD they make it look mega cool with all the lifestyle shenanigans, and in a desert with priddy gurls, and now of course I want all of these beautiful, expensive and really unpractical bikes.
This just came up on FB.
Make your own jokes up :obscene-birdiedoublered:
Has thanked: 532 times
Been thanked: 7241 times
Pirahna wrote: Wed Jan 18, 2023 10:18 pm
Would I be right to be concerned about heat transfer to the 'rubber' belt?
KungFooBob wrote: Fri Jan 20, 2023 5:15 pm
And the discs may deform on full braking force.
Yorick wrote: Fri Jan 20, 2023 5:53 pm
And the caliper bolts need tightening ;)
