Seized Trolleyjack..
Has thanked: 10266 times
Been thanked: 6887 times
Bloody things jammed. Only had it 35 years :obscene-birdiedoublered:
I can afford another one, but like tinkering sometimes.
Are there any serviceable parts?
All the lifting bits seem free. Just the pin that the handle pushes is seized.
Tips?
Re: Seized Trolleyjack..
Don't leave it outside to turn into a rusty pile of scrap, I've got the same trolley jack and it still works fine and looks a lot better than that.
Last edited by Le_Fromage_Grande on Tue Jan 17, 2023 4:40 pm, edited 1 time in total.
DefTrap
Has thanked: 2265 times
Been thanked: 2193 times
Post by DefTrap »
Warm it up a bit with the blowlamp and then try again?
Has thanked: 9833 times
Been thanked: 10147 times
Give it a diesel bath.
Has thanked: 484 times
Been thanked: 1427 times
DefTrap wrote: Tue Jan 17, 2023 4:39 pm Warm it up a bit with the blowlamp and then try again?
Is there not a rubber seal behind that lowering pin?
Ditchfinder
Has thanked: 621 times
Been thanked: 692 times
Post by Ditchfinder »
I can't see any signs whatsoever of that pin being persuaded with a Birmingham screwdriver
It might need the big one but still, give it a tap
Ditchfinder wrote: Tue Jan 17, 2023 5:30 pm I can't see any signs whatsoever of that pin being persuaded with a Birmingham screwdriver
We always called it a Manchester Screwdriver :obscene-birdiedoublered:
Got the special big one out. Yup. That moved the bugger :)
But it won't come back up ;)
Undid the big nut and thread thing. Oil everywhere. Even with it in the vice, it's buggered.
Time for a new one. Always nice to buy new tools.
Has thanked: 15960 times
Been thanked: 10248 times
Does it pump with pressure? Has it got oil in it?
Taipan wrote: Tue Jan 17, 2023 6:52 pm Does it pump with pressure? Has it got oil in it?
It's seized solid and not much oil in it now :D
Post it to screwd for an overhaul! :thumbup:
Has thanked: 2407 times
Been thanked: 3635 times
That's fucked, mate. I realise that this is tantamount to treason for a Yorkie, but you're gonna have to splash some cash for a new 'un... :D
mel
Has thanked: 13 times
Been thanked: 36 times
Post by mel »
Look up ac 50
-11 quid on Amazon , multiply uses on bikes and machines , little dab will do you last for ages but keep away from brakes and discs , apart from that always worth having some on shelf
Think it was designed for aircraft use, to prevent rusting in inclosed spaces as it creeps when applied , also good for sticky bolts ect ect lot of people used it on bikes over winter , but works on lawnmowers push bikes, off road bikes ect ect
Finally got me arse in gear and went to buy a new one.
Oh decisions. Trolley jack or bottle jack.
Bottle is lighter, smaller and cheaper. Are they any good ?
Has thanked: 218 times
Been thanked: 689 times
Yorick, I have one you can have for £20 plus postage......
Has thanked: 2913 times
Been thanked: 2053 times
Bottlejacks are fine, plus they can come in handy for jobs other than just lifting vehicles.
Been thanked: 2618 times
Have you the clearance under your vehicle if it has a flat tyre for a bottle jack?
cheb wrote: Fri Feb 10, 2023 7:33 pm Have you the clearance under your vehicle if it has a flat tyre for a bottle jack?
Thanks, I forgot to check, but the Mighty Duster does have mega ground clearance :)
Yozzer, you need my little red trolley jack...£15 + postage?
DefTrap
Post by DefTrap »
If I had the choice I'd have a trolley jack.
Mainly because bottle jacks seem to be used by
- people from the 1950s
- third world blaggers
