Find me a van then...
Has thanked: 5451 times
Been thanked: 13087 times
Re: Find me a van then...
Rockburner wrote: Fri Jan 13, 2023 8:31 am Tenner says theres a muddy footprint on the carpetting within a month.
I'd expect there'll be lots of mud in the next few months, but i'm not looking to move in, it's an MTB van at the end of the day, just made a little bit nicer for the times we're sitting in it.
Has thanked: 6376 times
Been thanked: 4753 times
That looks pretty freshened up. :thumbup:
Q? What're the holes/wiring above the wheel arches about?
Count Steer wrote: Fri Jan 13, 2023 8:38 am That looks pretty freshened up. :thumbup:
Tie down brackets. Not wiring.
weeksy wrote: Fri Jan 13, 2023 8:39 am
*puts specs on* Ah. So they are. :D
so then.... it's going to be bloody cold this weekend.
Sat we're out at an uplift all day, but i'm not riding so likely to be somewhat chilly.
thoughts ?
Has thanked: 15955 times
Been thanked: 10248 times
In a test they came about 3rd place for motorhomes, the little oil filled radiator was better. That said my F-i-L has one of these to take the chill of his caravan and loves it.
the #1 rated one does terribly in reviews lol
i'll be running it off a 1200w gennie by the way for any relevance.
weeksy wrote: Tue Jan 17, 2023 8:22 am
Typical. Well as I say my F-i-L really rates the halogen one. For me there is a slight concern about fire. I do imagine the oil fired rad would take a while to achieve the same warmth though which may be a thing when you're ina nd out of the van where as in a camper you just leave it on?
Probably spot on as you'll be primarily interested in heating yourself* rather taking the chill off the whole of the van area (which the oil filled type would do).
* or parts thereof, like hands!
Would it make more sense to just sit in the cab and fire the van up for 10 mins every now and again.
I wonder what would be more effective in terms of both fuel use and actual warmth, a 1200w gennie or a van engine.
Been thanked: 2617 times
It takes a long time to warm the cab using the engine, and if it's cold the cab cools down very quickly. With a small genny I'd go for the halogen heater, most of the oil filled rads I've seen have been about 2KW.
cheb wrote: Tue Jan 17, 2023 8:35 am It takes a long time to warm the cab using the engine, and if it's cold the cab cools down very quickly. With a small genny I'd go for the halogen heater, most of the oil filled rads I've seen have been about 2KW.
Then do it in the front cab or the back cabin ?
I don't much mind where i sit, both will have a seating area thing going on
Has thanked: 7817 times
Been thanked: 2528 times
weeksy wrote: Tue Jan 17, 2023 8:32 am Would it make more sense to just sit in the cab and fire the van up for 10 mins every now and again.
My gut says the gennie and heater will be better.
The van engine will be powering a few other things as well, unnecessarily.
Has thanked: 10265 times
Been thanked: 6886 times
weeksy wrote: Tue Jan 17, 2023 8:01 am so then.... it's going to be bloody cold this weekend.
thoughts ?
They are rubbish. There's no real heat, just radiation.
When you turn then off, all the heat goes.
Hot fan much better as they heat the air.
Has thanked: 836 times
Been thanked: 1238 times
weeksy wrote: Tue Jan 17, 2023 8:40 am
The cabin will be more comfy, better insulated and a smaller place to heat.
As for the type of heater, I'd get a fan heater as the exterior doesn't get as hot, if you knock it off the seat you won't burn yourself trying to pick it up before it sets fire to whatever fell off with it.
Has thanked: 1816 times
Been thanked: 1164 times
What's wrong with doing a proper job and fitting a diesel heater?
Pirahna wrote: Tue Jan 17, 2023 9:59 am What's wrong with doing a proper job and fitting a diesel heater?
Dunno really... not given it that much thought yet. I know nothing about that side of things.
Chinese Eberspacher copies are a damn good bang for yer buck. Very popular with motorhome people.
https://www.ebay.co.uk/itm/374465230308 ... R_yjjvW3YQ
636mick
Has thanked: 1079 times
Been thanked: 720 times
Post by 636mick »
I’ve got a Dyson heat and cool which warms the caravan very fast, it’s great when it’s hot to cool it too. Not that cheap but mine is about 9 years old and never missed a beat.
My campervan had a log burner installed, never used it but it’s a thought.
Mick
