Fancy doing a test?
- Has thanked: 16210 times
- Been thanked: 3925 times
Re: Fancy doing a test?
44/50
Got my countries wrong on the roundabout question
Second guessed myself on the hazard signs
Got ABS and TCS confused
Didn't read the which lane question properly
Have no idea what the different levels of test mean
CPR must have changed, but anything is better than nothing!!
TBF, 44/50 is way more than I'd hoped for
- Has thanked: 6376 times
- Been thanked: 4753 times
And you would signal a right turn without taking your hand of the throttle exactly how? Pointing to the right, over your head with the left hand perhaps?mangocrazy wrote: ↑Sun Jan 08, 2023 2:18 pmI got the answer to the same Q wrong - except that now I know what I'm supposed to do I will carry on doing the same as I've always done and use my left arm for the signal, because it makes absolute sense to do so. Dolloping along on a closed throttle (especially on a big V-twin) would make the plot borderline unstable. It's a silly idea and it can fuck right off.Hot_Air wrote: ↑Sun Jan 08, 2023 1:22 pmWhy does the right arm make the slowing down signal? It means taking your hand off the throttle to signal — meaning you could slow more rapidly than the following vehicle expects.
But if the left arm makes the slowing down signal, it gives considerably more (throttle) control over the rate of slowing, increasing safety. And as it’s movement that attracts attention, the left arm’s as conspicuous as the right.
I wonder if the arm signals originated with cyclists, not motorcyclists riding a large-capacity twin cylinder.
- Has thanked: 2405 times
- Been thanked: 3630 times
I'd use my right indicator...Count Steer wrote: ↑Sun Jan 08, 2023 5:19 pmAnd you would signal a right turn without taking your hand of the throttle exactly how? Pointing to the right, over your head with the left hand perhaps?mangocrazy wrote: ↑Sun Jan 08, 2023 2:18 pmI got the answer to the same Q wrong - except that now I know what I'm supposed to do I will carry on doing the same as I've always done and use my left arm for the signal, because it makes absolute sense to do so. Dolloping along on a closed throttle (especially on a big V-twin) would make the plot borderline unstable. It's a silly idea and it can fuck right off.Hot_Air wrote: ↑Sun Jan 08, 2023 1:22 pm
I thought you used your left arm but made it circle (horizontally ish!) - of is that something else?Count Steer wrote: ↑Sun Jan 08, 2023 5:19 pmAnd you would signal a right turn without taking your hand of the throttle exactly how? Pointing to the right, over your head with the left hand perhaps?mangocrazy wrote: ↑Sun Jan 08, 2023 2:18 pmI got the answer to the same Q wrong - except that now I know what I'm supposed to do I will carry on doing the same as I've always done and use my left arm for the signal, because it makes absolute sense to do so. Dolloping along on a closed throttle (especially on a big V-twin) would make the plot borderline unstable. It's a silly idea and it can fuck right off.Hot_Air wrote: ↑Sun Jan 08, 2023 1:22 pm
On my test, way back in the mists of time, the only criticism was I didn't stick my right arm out enough to signal a right turn. He said 'sit up straight and make the signal clear enough so there is no ambiguity!'
Passed me though.
Yeah, I never had to do hand signals on a test!! But I'm sure my Dad said that left was making circles with your left arm out to the sideCount Steer wrote: ↑Sun Jan 08, 2023 6:02 pmOn my test, way back in the mists of time, the only criticism was I didn't stick my right arm out enough to signal a right turn. He said 'sit up straight and make the signal clear enough so there is no ambiguity!'
Passed me though.
- Has thanked: 459 times
- Been thanked: 235 times
That's start your engines. Have you been watching too much Umericun tv?Noggin wrote: ↑Sun Jan 08, 2023 5:57 pmI thought you used your left arm but made it circle (horizontally ish!) - of is that something else?Count Steer wrote: ↑Sun Jan 08, 2023 5:19 pmAnd you would signal a right turn without taking your hand of the throttle exactly how? Pointing to the right, over your head with the left hand perhaps?mangocrazy wrote: ↑Sun Jan 08, 2023 2:18 pm
Err...in a car in the UK you can't stick your left arm out (unless your arms are like Twizzle ) so you'd do the circular thing with the right arm to go left. On a bike you stick your left arm out to go left, your right arm out to go right. If feeling flamboyant you can waft the right arm up and down to indicate that your brake light is broken and you are grinding to a halt.Noggin wrote: ↑Sun Jan 08, 2023 6:09 pmYeah, I never had to do hand signals on a test!! But I'm sure my Dad said that left was making circles with your left arm out to the sideCount Steer wrote: ↑Sun Jan 08, 2023 6:02 pmOn my test, way back in the mists of time, the only criticism was I didn't stick my right arm out enough to signal a right turn. He said 'sit up straight and make the signal clear enough so there is no ambiguity!'
Passed me though.
- Has thanked: 2636 times
- Been thanked: 1523 times
Blimey, I answered this one for Bike Breaker 20 years ago - pull the clutch in if you want to continue rolling.Hot_Air wrote: ↑Sun Jan 08, 2023 1:22 pmWhy does the right arm make the slowing down signal? It means taking your hand off the throttle to signal — meaning you could slow more rapidly than the following vehicle expects.
OK, not so easy on a DCT or e-bike with engine braking dialled up but for the time being it'll work with most bikes!
I'd guess it's the right arm because bikes used to ride 1 yard from the kerb - that was the official guidance as late at the mid-70s when I was starting out on two wheels... so the left arm would have been on the 'wrong' side from a following driver.
Presumably you reverse that if you're driving a left-hand drive carCount Steer wrote: ↑Sun Jan 08, 2023 7:06 pmErr...in a car in the UK you can't stick your left arm out (unless your arms are like Twizzle ) so you'd do the circular thing with the right arm to go left. On a bike you stick your left arm out to go left, your right arm out to go right. If feeling flamboyant you can waft the right arm up and down to indicate that your brake light is broken and you are grinding to a halt.Noggin wrote: ↑Sun Jan 08, 2023 6:09 pmYeah, I never had to do hand signals on a test!! But I'm sure my Dad said that left was making circles with your left arm out to the sideCount Steer wrote: ↑Sun Jan 08, 2023 6:02 pm
Passed me though.
There are certain circumstances I use a 'slowing down' signal to reinforce the brake light... for example, where I'm slowing where someone might expect me not to slow down, or where the arm signal is likely to be more visible than a brake light - low sun ahead of me, for example.
- Has thanked: 6191 times
- Been thanked: 5087 times
AKA the 'dying swan'Count Steer wrote: ↑Sun Jan 08, 2023 7:06 pm . If feeling flamboyant you can waft the right arm up and down to indicate that your brake light is broken and you are grinding to a halt.
If you want added complications, there's also 'short' arm signals It comes from police advanced training, early experiences from riding behind big fairings being that if you stick your arm out straight at speed then either it's instant shoulder dislocation or the rider is corkscrewed into the seat
- Has thanked: 1746 times
- Been thanked: 2085 times
What I sometimes do just to attract attention is, left arm out briefly for turning off left, right arm out briefly for turning off right, but left arm up and down if slowing or stopping to pull up on side of road. Bike indicators aren't always that obvious to many of today's drivers.
- Has thanked: 1373 times
- Been thanked: 253 times
Interesting, thanks. That must explain it. But I wonder which arm cyclists use as the hand signal for slowing down?The Spin Doctor wrote: ↑Sun Jan 08, 2023 7:14 pm I'd guess it's the right arm because bikes used to ride 1 yard from the kerb - that was the official guidance as late at the mid-70s when I was starting out on two wheels... so the left arm would have been on the 'wrong' side from a following driver.
But, but, on a bike you'd be encouraged not to let go of the accelerator to indicate right?Count Steer wrote: ↑Sun Jan 08, 2023 7:06 pmErr...in a car in the UK you can't stick your left arm out (unless your arms are like Twizzle ) so you'd do the circular thing with the right arm to go left. On a bike you stick your left arm out to go left, your right arm out to go right. If feeling flamboyant you can waft the right arm up and down to indicate that your brake light is broken and you are grinding to a halt.Noggin wrote: ↑Sun Jan 08, 2023 6:09 pmYeah, I never had to do hand signals on a test!! But I'm sure my Dad said that left was making circles with your left arm out to the sideCount Steer wrote: ↑Sun Jan 08, 2023 6:02 pm
Passed me though.
I dunno - but I know I was told left arm for something! Maybe it was the slowing down thing - but that wouldn't work in a car either. Maybe he was talking about bikes!!
As I said yesterday about using the right arm: "pull the clutch in if you want to continue rolling"Noggin wrote: ↑Mon Jan 09, 2023 9:23 pm But, but, on a bike you'd be encouraged not to let go of the accelerator to indicate right?
- Has thanked: 1507 times
- Been thanked: 1412 times
The (multiple choice) written test here has 30 or 35 questions (iirc) from a group of 100. One of them is "why do motorcyclists wear gloves?. The CA DMV thinks it's to give you a better grip on the bars, it's not for protection.
I missed two questions when I took the test. Turns out that there are three questions among the 100 that have no correct answer (WTF??) & I got two of them on my written. You'd think they would give you a pass on those three instead of a fail. The fuckers.
The Spin Doctor wrote: ↑Tue Jan 10, 2023 12:03 amAs I said yesterday about using the right arm: "pull the clutch in if you want to continue rolling"Noggin wrote: ↑Mon Jan 09, 2023 9:23 pm But, but, on a bike you'd be encouraged not to let go of the accelerator to indicate right?
Your probably right, but then you have no control of the bike. If you have a hand on the power, you could keep it rolling or accelerate, depending on circumstance. Each to their own in the real world I suppose.
I've seen people without either hand on the bars who've had more control than some with both
For my riding test I tweaked the throttle so it had some friction on it (not too difficult on an old Lambretta) so approaching the only right turn where the examiner could see me...throttle to 'cruise', arm out like a railway signal, back brake to slow a bit.
(The test circuit actually went around my school and I had to bunk off for the day to do it ).
