Steering head bearings
- Has thanked: 253 times
- Been thanked: 328 times
Any hints or tips on changing the steering head bearings? Bike's a Honda Transalp 650, if you're interested (and even if you're not it's still a Honda Transalp )
Are taper roller bearings the way to go? And if so, how does that effect the stated torque figures when doing stuff up again?
Ta in advance.
Ta in advance.
- Has thanked: 605 times
- Been thanked: 4100 times
Re: Steering head bearings
Fit tapers, torque them to the recomended torque, which will feel a bit tight initially
- Has thanked: 532 times
- Been thanked: 7408 times
I put tapers in Fireblade. iirc the most difficult part was getting the bottom race off the stem, for the others Honda provided nice little cuttaways in the frame to allow you to get a drift on them.
Some bikes have a little cut away on the bottom yoke you can use to separate the race from the yokeKungFooBob wrote: ↑Fri Sep 18, 2020 9:32 am I put tapers in Fireblade. iirc the most difficult part was getting the bottom race off the stem, for the others Honda provided nice little cuttaways in the frame to allow you to get a drift on them.
- GuzziPaul
- Has thanked: 59 times
- Been thanked: 195 times
Taper bearings.
Drift the top outer race out from the bottom and visa versa, use a socket handle. The inner race which will be attached to the stem, maybe use a bit of heat. The bottom one will be a pain in the arse as you can't get under it to drift it. I would suggest usinga Dremel with a cutting disk and cut through the majority of it top to bottom, then stick a big flat blade screwdriver in it and twist. It should crack and then easily slide off.
To install. Stick the outer races in the freezer ( I currently have the big bearing for the bevel drive for the Le mans in the freezer). Get a length of threaded bar and a suitable sized socket, nuts, washers and a flat bit of bar or strong wood with a hole. Take one of the outer races from the freezer and place on top of the socket. Put the threaded bar through the steering stem, then the wood washer and nut on the opposite side of the stem and tighten to pull the outer race in. Repeat for the other end.
Inner race. Stick the stem in the freezer Get a bit of tube that just fits over the stem and is longer. Warm the bottom inner race with a hot air gun. Take the stem out the freeezer and drift the warmed bottom race down. Stick the bottom bearing on the stem and insert into the frame, drop the top bearing in and drift the warmed inner bearing into the stem and tighten down the nut, maybe with a couple of additional washer initially to push the inner race all the way down.
Using heating and cooling works in so many applications it ain't funny. An old oven in the garage works wonders for popping bearings out of engine casings and seals out of fork legs.
