Energy bills
Ant
Has thanked: 39 times
Been thanked: 227 times
Re: Energy bills
Post by Ant »
Count Steer wrote: Fri Dec 30, 2022 3:07 pm
Ant wrote: Fri Dec 30, 2022 3:00 pm
Count Steer wrote: Fri Dec 30, 2022 2:57 pm
Are you saying that the 'functional' covers are actually 'decorative' only, so they only say they're functional but aren't really? :hmmm:
They function as a cover, to cover the gubbins and electrical connections of course.
So this (as quoted ^^^ by Potter) is simply not true in your view....
Integral casing: Many appliances have cases, which in addition to being decorative, function as a part of the combustion circuit and form an important seal around the gas carrying components e.g. burner, combustion chamber, gas valve etc. If removing the case involves undoing a number of screws, this normally means it is a functional case and it should not be removed by the consumer or a person who is not Gas Safe registered.
In my view?
Are you recreating my view to suit? Let's not twist things now.
Ant
Re: Energy bills
Post by Ant »
Kneerly Down wrote: Fri Dec 30, 2022 3:03 pm
Bowman wrote: Fri Dec 30, 2022 1:11 pm And there's the nub of it. Even taking the case off a lot of balanced flued boilers is classed as working on the gas side. The case forms an important part of the sealing to the room andvis classed as gas work.
No-one is doubting anyone's technical ability but if something happens then the hse and insurance companies will not be impressed.
From my experience pretty much all that goes wrong with the water side, other than the expansion vessel, is accessible with the drop down for the control panel taken off rather than having to do anything with the case around the burner chamber, let alone the chamber itself.
Fiddly, but accessible.
It does annoy me how crap they seem to make the water pumps on gas combi boilers but then they are built to a price and the maxim of "you'd be better off just getting a new boiler installed"
Exactly that.
Has thanked: 6381 times
Been thanked: 4761 times
Re: Energy bills
Ant wrote: Fri Dec 30, 2022 3:09 pm
In my view?
OK. You are saying that functional casings are purely decorative. Which is clearly wrong.
Ant
Re: Energy bills
Post by Ant »
Count Steer wrote: Fri Dec 30, 2022 3:11 pm
In my view?
Purely? No, I didn't say that.
Come on, you can troll better than that!
Bowman
Has thanked: 161 times
Been thanked: 108 times
Re: Energy bills
Post by Bowman »
Ant wrote: Fri Dec 30, 2022 2:49 pm
Bowman wrote: Fri Dec 30, 2022 2:46 pm
Ant wrote: Fri Dec 30, 2022 2:26 pm
What's a guy like me? Someone who showed you that what you said was wrong?
You still have no idea what you're talking about. Go and have another look at the diagrams and try and comprehend them. The case that you remove forms part of the inner combustion chamber.
I did and google images. Both showed the combustion chamber as sealed with the main cosmetic cover off. I said that was the case (pardon the pun) for the Vailant which you suggested I look at, you then said look at a Greenstar, so I did that also.
Jesus wept. With the cover off you're looking at the combustion chamber through a 2 foot square hole where the front cover was. Tell me you can see this.
Re: Energy bills
Ant wrote: Fri Dec 30, 2022 3:12 pm
In my view?
You referred to a functional cover as 'the main cosmetic' cover. Cosmetic/decorative. Whatever.
Ant
Re: Energy bills
Post by Ant »
Bowman wrote: Fri Dec 30, 2022 3:15 pm
Yep, we're looking at a sealed chamber which we will not be opening.
Ant
Re: Energy bills
Post by Ant »
Potter wrote: Fri Dec 30, 2022 3:23 pm
Ant wrote: Fri Dec 30, 2022 3:17 pm
Did you remove any screws to get that main cover off?
Something being screwed down, that you need tools to remove, is the indicator that only a competent person should take it off.
Wait a min, are you saying that I'm incompetent?!! :cry:
No sir, the person who fitted the boiler perhaps forgot to pop the little screws in? :think:
Has thanked: 2407 times
Been thanked: 3635 times
Re: Energy bills
Ant
Re: Energy bills
Post by Ant »
Potter wrote: Fri Dec 30, 2022 3:31 pm
Ant wrote: Fri Dec 30, 2022 3:24 pm
Yeah give that a try, when the HSE prosecute you then you can lie to them, bet that's never happened before.
See how you go :thumbup:
What would I be lying about? Why would the HSE get involved if I need to say, re wire the house and change the cable which powers the boiler controls?
Has thanked: 2552 times
Been thanked: 6257 times
Re: Energy bills
I was almost killed by an incorrectly serviced/fitted/whatever boiler...it had a recent safety certificate granted by the previous home owner (who was also a gas bod) too.
If I'd been up in the loft 1 or 2 minutes longer that'd have been me done. Got away with a bought of mild euphoria and a headache, but fuck me I didn't realise how easy it was to get this ---> <--- close to carking it from something so innocuous.
Fun times!
Ant
Re: Energy bills
Post by Ant »
Potter wrote: Fri Dec 30, 2022 3:40 pm Have you got a Part P to rewire the house? Or an Approved Electrician with a C&G2391 and NICEIC membership?
Separate conversation. But no one has part P, it's simply a building regulation to comply with.
So, what's going to go wrong? You've got me interested now. Perhaps you know of something which happened? Let's stick to what we were talking about before, we can then get into the electrical qualifications high horse later.
So, something may go wrong? Enlighten me, if you will.
Re: Energy bills
So far your only declared qualification is owning a screwdriver. :lol:
Ant
Re: Energy bills
Post by Ant »
Count Steer wrote: Fri Dec 30, 2022 3:46 pm
For now. As I said, we can move onto that later. We're not done yet with the mystical explosion from touching the water.....
crust
Has thanked: 606 times
Been thanked: 515 times
Re: Energy bills
Post by crust »
C'mon lets leave Screwd out of this.
Bowman
Re: Energy bills
Post by Bowman »
Excellent 😆
Has thanked: 599 times
Been thanked: 2448 times
Re: Energy bills
Ant
Re: Energy bills
Post by Ant »
Potter wrote: Fri Dec 30, 2022 4:07 pm
Ant wrote: Fri Dec 30, 2022 3:44 pm
No.
You can't identify a cover with screws missing, you don't understand the guidance from the GasSafe Register, you don't have the necessary qualifications, you're unwilling to learn anything from skilled people and you're unconsciously incompetent. The only thing I do with people like you if I get to hear about them is to pass down a message to dismiss them because they're a liability.
In the trades you're what is known as an unskilled and unqualified cowboy.
Plenty of you get done every year, like this clown - https://press.hse.gov.uk/2022/08/10/unr ... inspector/ and here is another just jailed https://press.hse.gov.uk/2022/12/02/eng ... -gas-work/
There's a lot of assumptions there which are all false.
But you said something will go wrong, I've asked many times, you can't tell me. So did you make that all up?
Ant
Re: Energy bills
Post by Ant »
Potter wrote: Fri Dec 30, 2022 4:15 pm
Ant wrote: Fri Dec 30, 2022 4:09 pm
You don't have the qualifications to work on gas boilers and wire houses.
Don't I?
Potter wrote: Fri Dec 30, 2022 4:15 pm The boiler will blow up, kill you, your family, and a dog that has wandered into your garden by mistake.
Prove it won't, tell me exactly how you will prevent the explosion.
I shall prevent that explosion by not touching the gas.
I'll ask again, how will a boiler explode from touching only water? Do you have any examples?
Are you suggesting that all boilers are so poorly designed, that they will just explode? In that case, any boiler will do that from not even being touched.
Ant
Re: Energy bills
Post by Ant »
Potter wrote: Fri Dec 30, 2022 4:21 pm
Ant wrote: Fri Dec 30, 2022 4:18 pm
You'll make a mistake because you don't have the proper skills or qualifications.
It will take 12 days, four minutes and nine seconds to blow up because of the mistake.
Tell me how will you prevent it?
I won't make any mistake.
I'll prevent it by not touching the gas.
By the way, this isn't an argument, it's a technical conversation.
