LED Light Strings
Has thanked: 499 times
Been thanked: 1447 times
LED Light Strings
Wife wants then round the Livingroom picture rail. I have two boxes of 10m but one is not enough and two is to much. They are mains powered but 31v. Am i right in thinking i can cut a few meters off for a neater fit and just tape the ends up? Rather tape them into one adapter but they would probably end up being to dull.
Yambo
Has thanked: 600 times
Been thanked: 1647 times
Re: LED Light Strings
Post by Yambo »
I have a few strips of 12 V strips. Theycome in 5 metre lengths and I cut off what I need.
The ones I get show on the strip where to cut them, which is across the middle of the exposed copper contacts. If you need to you can just solder a couple of wires on at that point.
Has thanked: 6413 times
Been thanked: 4797 times
Yambo wrote: Tue Dec 20, 2022 11:07 am I have a few strips of 12 V strips. Theycome in 5 metre lengths and I cut off what I need.
You can also get connectors to join lengths of them (or, if you're neat you can solder wire connectors on). However, it's not clear from the OP if they're strips or wire - like tree lights. I suspect they're wired.
Count Steer wrote: Tue Dec 20, 2022 11:11 am You can also get connectors to join lengths of them (or, if you're neat you can solder wire connectors on). However, it's not clear from the OP if they're strips or wire - like tree lights. I suspect they're wired.
Wire. I know you can with the strips and cant see why not with the wire but just wanting to know for sure if anyone has done it.
