Yup! He doesn't have much of a profile though and most of the scammers don't when you look into it ...mangocrazy wrote: ↑Fri Nov 18, 2022 12:53 pmYeah, I'd forgotten about that. Tricky one. I guess this is FB marketplace, not ebay?Taipan wrote: ↑Fri Nov 18, 2022 12:49 pmIt is very tempting, but I'm still licking the wounds of the X-ADV loss and don't fancy risking £450 to someone I don't know?mangocrazy wrote: ↑Fri Nov 18, 2022 12:10 pm
If you haven't already I'd bite the seller's arm off. For the money, that's pretty much as good as you will get.
Daydreaming thread. How much does a suspension upgrade cost?
- Has thanked: 15982 times
- Been thanked: 10259 times
Re: Daydreaming thread. How much does a suspension upgrade cost?
- Been thanked: 4125 times
There is, he gave me a massive discount on the YSS shock for my Suzuki, and it works lovely.KungFooBob wrote: ↑Fri Nov 18, 2022 12:08 pm Isn't there a forum 'trader' who does us good deals on YSS stuff?
I've known Darren at MCT for over 35 years, he's a good bloke, but is very busy, book well in advance.
- Has thanked: 5455 times
- Been thanked: 13102 times
I was messing about. I'm probably twice that! Would it suit my lard arse then?Demannu wrote: ↑Fri Nov 18, 2022 12:56 pmThat's a 10.18kg/mm spring, bit stiff for a 10st bottyTaipan wrote: ↑Fri Nov 18, 2022 12:48 pmI can't see that happening as I love the bike, but if riding it daily causes my knee problems, then it might not be my decision anyway.Skub wrote: ↑Fri Nov 18, 2022 12:12 pm I love good suspenders on a bike. I'll try to get what I want with the stock items,but the middle ground always seems to be missing. On My 10R the rear shock was rubbish,but the forks didn't take much to be right. On the current Zed,it came with an Ohlins,which is ok,even though it's at the cheap end of the line,but I couldn't get the forks right at all,so money was spent there.
Potter has it pretty nailed,if you budget 2k for both ends,you'll not be far off.
Mined ewe,if you chop your bike in every couple of months,I wouldn't bother.Some folk baulk at the though of spending money on suspension,yet have no issue with spunking bigger amounts on snorty cans and bolt on gee-gaws,whatever blows your skirt up. I don't mind the cost,because I usually keep mine long term.
I don't think i'd drop £2k into it, as it is only a commuter after all. But I have resprung bikes for my weight before and its been much better for it. I can get a k-tech shock for about £450 new and I suppose a £100 for springs? Then whatever someone charges to fit it and set the sag for my weight etc. I think I might risk that?
Just seen this on ebay but not sure if that spring suits y 10 stone or not!
https://www.ebay.co.uk/itm/255735686822 ... 0667.m2042
pretty damn close.Taipan wrote: ↑Fri Nov 18, 2022 2:06 pmI was messing about. I'm probably twice that! Would it suit my lard arse then?Demannu wrote: ↑Fri Nov 18, 2022 12:56 pmThat's a 10.18kg/mm spring, bit stiff for a 10st bottyTaipan wrote: ↑Fri Nov 18, 2022 12:48 pm
Cheers Bud. Seems a lot of the MT09 people replace the rear shock,so I might have a punt at that?
It's decent value and give or take £20 you could fit it, hate it and sell it next week. It's pretty much a no brainer.
- Has thanked: 10277 times
- Been thanked: 6891 times
Many folk bugger up spring calculations.
If a bike is set up for 100 kgs rider but you are 110 some think you need a 10% stronger spring. Wrong.
100 kgs rider plus sprung weight of bike is 300 kgs.
110 kgs rider plus sprung weight of bike is 310 kgs.
So need 3% stronger spring.
- Has thanked: 65 times
- Been thanked: 1235 times
https://racetech.com/VehicleSearch
Stick your vital statistics in there, and it will give you a spring rate f+r.
FWIW, as a svelte 89kg, I run 0.9kgmm front springs, and whatever the ohlins came with....I checked and it was on the compliant side of ideal
Bought it. He wouldn't drop below £325 but I went with that. I can get K-tech linear spings for £89 delivered. Theres a local guy who has a workshop but he's also an amateur racer, or used to be, and he does suspension set ups. So I'll probably get him to fit it all and set the sag etc.
- Has thanked: 2408 times
- Been thanked: 3637 times
Nice one. That should do the job very well. Decent suspension is the single best thing you can do to a bike.
- Has thanked: 6382 times
- Been thanked: 4764 times
Is it usual to have to arrange collection? Why can't he send it and you pay the cost? Wouldn't that be the standard way of doing things? Seems a bit odd but I've not bought things that way.
- Has thanked: 326 times
- Been thanked: 2173 times
That's a good price, I've got a trade account for YSS that shows a shock for £270 not that you need it now
I bought an Ohlins for one of my GSXRs for about £850.
Had it on various new bikes for about 10 years. Sold it for £600
One of my all-time bargains was an Ohlins that I put on the Falco that was originally for an RSV Mille, that I got off eBay for £230 around 12-13 years ago. Not only was it in absolutely mint condition, it was the aftermarket model with hydraulic preload adjuster.
