Anyone ever made a grab rail?
- Has thanked: 2552 times
- Been thanked: 6262 times
Re: Anyone ever made a grab rail?
Grab rails are probably pretty strong anyway - they're not gonna be made from really thin section steel 'cause that's actually harder to bend and weld, and it's not like they're gonna be commissioning custom pipe designs from the steel mills.
P.S. my plastic fuel pipe connectors aged and broke 15 years before Priest's
- Has thanked: 6200 times
- Been thanked: 5090 times
It's likely that 'the item' in total costs about third of the price.mangocrazy wrote: ↑Thu Nov 17, 2022 12:47 pm raw materials probably won't be the major cost item. Getting the parts welded/plated/powder coated will probably be the main cost component.
- Has thanked: 2408 times
- Been thanked: 3637 times
A couple of years ago I 'made' a set of bars for my KTM Duke 690, as I couldn't get on with the OE items. I bought the steel tube, cut them to the correct size/shape on the horizontal bandsaw and drilled the required holes on my pillar drill. I then took the pieces to my friendly local welders who turned a bunch of funny shaped tubes into a set of bars. This cost me a couple of nice bottles of wine. To finish them off I got them powder coated. Total cost (not including my time and kit) was around £70.
The OE bars were aluminium and went from 28mm (1 1/8") at the bar clamps to 22mm (7/8") at the bar ends where the controls mounted. I couldn't match that kind of sorcery so had to use two different tube thicknesses and went with steel as it was cheaper, stronger and more readily available in the sizes I needed. It was also heavier of course, but not to any significant degree.
So it can be done, you just have to work out ways of achieving the end result using different methods to the manufacturers.
- Has thanked: 4365 times
- Been thanked: 2853 times
Yup that's what I would have said, but I think LGF is a bit top box- aphobic. Only taken a pillion 3 times in a few years but each time they held on to the rails.mangocrazy wrote: ↑Thu Nov 17, 2022 11:26 am Not sure if this has been suggested, but have you thought about a Givi rack for your bike? I realise this takes you firmly into the realm of Topbox Terrys, but from what my pillion passengers have said, the mounting hardware that Givi use can make for a useful grabrail. Alternatively look at the fixing points on the subframe that the various manufacturers use and try to adapt their creations to your needs.
- Been thanked: 4125 times
I "made" the pursuit handlebar extensions which Wiggo and co used in Rio 2016 - I did nearly the whole frame actually, but the bars are the only bit which were bits of metal tube. I of course did absolutely no making myself, I just commissioned the various machine wizards who did their bits. They were aluminium tubes anodised black, lovely lovely bits of kit. Think they were about £100 a set all in, but there was probably a significant "flagship advertising" discount involved!mangocrazy wrote: ↑Thu Nov 17, 2022 1:12 pm A couple of years ago I 'made' a set of bars for my KTM Duke 690, as I couldn't get on with the OE items. I bought the steel tube, cut them to the correct size/shape on the horizontal bandsaw and drilled the required holes on my pillar drill. I then took the pieces to my friendly local welders who turned a bunch of funny shaped tubes into a set of bars. This cost me a couple of nice bottles of wine. To finish them off I got them powder coated. Total cost (not including my time and kit) was around £70.
BTW, Wiggins was the only rider who had a 'double bend' like that in his bars. He's a proper Prima Donna who has to be made to feel special.
Nice one.... Don't understand what benefit the 'double bend' confers, but if it made him feel 'special' then I guess it did its job.Mr. Dazzle wrote: ↑Thu Nov 17, 2022 2:23 pmI "made" the pursuit handlebar extensions which Wiggo and co used in Rio 2016 - I did nearly the whole frame actually, but the bars are the only bit which were bits of metal tube. I of course did absolutely no making myself, I just commissioned the various machine wizards who did their bits. They were aluminium tubes anodised black, lovely lovely bits of kit. Think they were about £100 a set all in, but there was probably a significant "flagship advertising" discount involved!mangocrazy wrote: ↑Thu Nov 17, 2022 1:12 pm A couple of years ago I 'made' a set of bars for my KTM Duke 690, as I couldn't get on with the OE items. I bought the steel tube, cut them to the correct size/shape on the horizontal bandsaw and drilled the required holes on my pillar drill. I then took the pieces to my friendly local welders who turned a bunch of funny shaped tubes into a set of bars. This cost me a couple of nice bottles of wine. To finish them off I got them powder coated. Total cost (not including my time and kit) was around £70.
These are the (far more prosaic) bars I 'made' compared to the OE ones. These are actually the Mk 1 version, the Mk 2 were similar, but with various angles subtly adjusted.
And fitted to the bike:
- ChrisW
- Has thanked: 2919 times
- Been thanked: 2061 times
Was there any reason for the double bend other than ego? I can't immediately see any advantage.Mr. Dazzle wrote: ↑Thu Nov 17, 2022 2:23 pm the only rider who had a 'double bend' like that in his bars.
- Has thanked: 7821 times
- Been thanked: 2531 times
It depends on whether or not Renntex want to simply make and sell cheap tat, or gain a reputation as a manufacturer of a decent, long-lasting, realiable product.Horse wrote: ↑Thu Nov 17, 2022 12:51 pmi.e. the minimum needed?
Potentially it could be thicker-walled tube, wax-filled, anti-rust coated (or stainless). At higher cost. But is any of that actually required?
How strong does it need to be to qualify as 'safe' or 'safer'?
If you compare that with things like Priest's plastic fuel pipe connectors, aging and breaking ...
There's an argument that hugging the bottom of the forearm is lower drag.ChrisW wrote: ↑Thu Nov 17, 2022 3:14 pmWas there any reason for the double bend other than ego? I can't immediately see any advantage.Mr. Dazzle wrote: ↑Thu Nov 17, 2022 2:23 pm the only rider who had a 'double bend' like that in his bars.
Those bars were made at half past the 11th hour before Rio though, so it wasn't feasible to closely form fit every rider.
Did you look at trying the Tommaselli 'Jota' adjustables? You've ended up with something that looks very similar.mangocrazy wrote: ↑Thu Nov 17, 2022 3:06 pmNice one.... Don't understand what benefit the 'double bend' confers, but if it made him feel 'special' then I guess it did its job.Mr. Dazzle wrote: ↑Thu Nov 17, 2022 2:23 pmI "made" the pursuit handlebar extensions which Wiggo and co used in Rio 2016 - I did nearly the whole frame actually, but the bars are the only bit which were bits of metal tube. I of course did absolutely no making myself, I just commissioned the various machine wizards who did their bits. They were aluminium tubes anodised black, lovely lovely bits of kit. Think they were about £100 a set all in, but there was probably a significant "flagship advertising" discount involved!mangocrazy wrote: ↑Thu Nov 17, 2022 1:12 pm A couple of years ago I 'made' a set of bars for my KTM Duke 690, as I couldn't get on with the OE items. I bought the steel tube, cut them to the correct size/shape on the horizontal bandsaw and drilled the required holes on my pillar drill. I then took the pieces to my friendly local welders who turned a bunch of funny shaped tubes into a set of bars. This cost me a couple of nice bottles of wine. To finish them off I got them powder coated. Total cost (not including my time and kit) was around £70.
- Has thanked: 2636 times
- Been thanked: 1523 times
A buddy of mine bent some metal conduit (about 2/3 inch diameter, for wiring) into the right shape. Some pipe clips secured it to the frame. Carried passengers, luggage... was still on the bike when I sold it as a non-runner at 85k plus.
Not quite in the Wiggo class
Yes, agreed, and those bars (and the old 'Ace' bars from the 50s/60s/70s) were very much in my thinking when coming up with 'my' bars. The only problem with the Tommaselli bars were a) I'd given a set away to an ex-workmate and b) the centre (clamped) piece was a lot wider on the Tommasellis and I wanted slimmer. Also the KTM bars have that larger 28mm section where it's clamped to the yoke and from memory the Tommasellis are 22mm there.Rockburner wrote: ↑Thu Nov 17, 2022 3:27 pm Did you look at trying the Tommaselli 'Jota' adjustables? You've ended up with something that looks very similar.
But you're right - I've come up with a set of non-adjustable Tommasellis...
You can buy 28mm to 22mm converters or just have fitted different clampsmangocrazy wrote: ↑Thu Nov 17, 2022 4:32 pmYes, agreed, and those bars (and the old 'Ace' bars from the 50s/60s/70s) were very much in my thinking when coming up with 'my' bars. The only problem with the Tommaselli bars were a) I'd given a set away to an ex-workmate and b) the centre (clamped) piece was a lot wider on the Tommasellis and I wanted slimmer. Also the KTM bars have that larger 28mm section where it's clamped to the yoke and from memory the Tommasellis are 22mm there.Rockburner wrote: ↑Thu Nov 17, 2022 3:27 pm Did you look at trying the Tommaselli 'Jota' adjustables? You've ended up with something that looks very similar.
Yeah, guess so, but it was easier to make them from scratch and to be honest I simply couldn't find anything on the market that fitted the bill. I also needed to reduce the overall width of the bars so I can get the bike down the alley way in the row of terraces I live in, and that influenced my decision to roll my own. I'm very happy with the final result and they're all day comfortable.Le_Fromage_Grande wrote: ↑Thu Nov 17, 2022 4:52 pmYou can buy 28mm to 22mm converters or just have fitted different clampsmangocrazy wrote: ↑Thu Nov 17, 2022 4:32 pmYes, agreed, and those bars (and the old 'Ace' bars from the 50s/60s/70s) were very much in my thinking when coming up with 'my' bars. The only problem with the Tommaselli bars were a) I'd given a set away to an ex-workmate and b) the centre (clamped) piece was a lot wider on the Tommasellis and I wanted slimmer. Also the KTM bars have that larger 28mm section where it's clamped to the yoke and from memory the Tommasellis are 22mm there.Rockburner wrote: ↑Thu Nov 17, 2022 3:27 pm Did you look at trying the Tommaselli 'Jota' adjustables? You've ended up with something that looks very similar.
- Cousin Jack
- Has thanked: 2559 times
- Been thanked: 2290 times
Nor am I, but............Le_Fromage_Grande wrote: ↑Thu Nov 17, 2022 2:04 pm I'm not a pizza delivery rider
Givi topbox fittings often offer very good handholds.
and
Topboxes are incrediy usefull
Sadly, motorcyclists have a grim record for accepting tat. And the companies providing it continuing on.Rockburner wrote: ↑Thu Nov 17, 2022 3:23 pm It depends on whether or not Renntex want to simply make and sell cheap tat, or gain a reputation as a manufacturer of a decent, long-lasting, realiable product.
Waterproofs that are not, or not for any length of time. RiDE magazine did a group test where most jackets kept the water out but the pockets leaked. The exception was the one which leaked but had waterproof pockets.
Or protective gear that isn't. Look how many very expensive suits are AA or even A rated. Think back to when gear had to be CE to be sold as offering protection. Most manufacturers simply altered their advertising to sell on style.
Look at the recent activities by trading standards, shutting down stands at shows.
- Has thanked: 310 times
- Been thanked: 568 times
+1 @Cousin Jack
Once you get over the fashion victim bit, top boxes increase the capability of your motorcycle like no other modification. Even a single helmet box gives you a secure (within limits) dry spot to leave your lid when you get off, lets you bring your daughter's lid if you are picking her up, lets you carry stuff and know it'll be dry when you arrive without rubbing your bodywork or seat like side bags, adds a backrest, means you never need to carry a rucksack again, you can keep your warm gloves and overtrousers in there, your driving documents... Etc etc etc.
You just have to stop worrying what people think.
+1 for the top boxes here too, on my daily commuter at least
It came with the bike, but I wouldn't give it up now.
Bloody hell, I've been the catalyst for the formation of the Top Box Fan Club
