Indoor covers
- dern
- Has thanked: 1017 times
- Been thanked: 1782 times
Indoor covers
I've been pretty dismissive of indoor covers in the past but space is getting tight so are they worth it for protecting against the odd knock or should I just get some thick double blankets from the cupboard?
- Has thanked: 4365 times
- Been thanked: 2853 times
Re: Indoor covers
I cover my bike in winter in the garage but to stop it getting dusty/dirty, mine would do sweet FA against a knock. On that basis I went for a cheap amazon special
- Has thanked: 5455 times
- Been thanked: 13102 times
- dern
- DefTrap
- Has thanked: 2267 times
- Been thanked: 2193 times
Re: Indoor covers
My bikes have to live in the same workshop space as my tools, building stuff and loads of other clutter - dust and potential for things falling or being knocked are almost inevitable over time, so for me old blankets works best. If my bike space was setup more like a dedicated motoGP pit then I'd probably have proper lightweight covers.
- wull
- Has thanked: 881 times
- Been thanked: 1552 times
Re: Indoor covers
Buy a dedicated indoor cover or even a rain cover which can be used indoors as well, you get decent ones for £15 from
https://www.sportsbikeshop.co.uk/motorc ... rod/101233
- Has thanked: 2408 times
- Been thanked: 3637 times
Re: Indoor covers
The only point I'd make is that air does need to be able to circulate around and underneath the bike as much as possible when it's covered, especially if the area it's being stored in is anything other than bone dry.
I stored an old CB77 Honda up against the wall of a supposedly dry garage with a heavy blanket thrown over it for a decade or so and when I came to remove the blanket there was substantial rust down the side of the bike that was nearest the wall. OK, so that side had been undisturbed for a long time but I'd checked the 'front' side of the bike from time to time and it had looked OK. The side where air was less able to circulate had suffered disproportionately.
- Has thanked: 9839 times
- Been thanked: 10151 times
Re: Indoor covers
A cover won't protect much against anything bumping or dropping on the bike,unless you use a high tog duvet as well.
- Has thanked: 1055 times
- Been thanked: 861 times
Re: Indoor covers
My KTM dealer used to save the covers that new bikes were delivered to them with. They were excellent dust covers, and importantly they let air through so didn't trap moisture.
For protecting from bumps, they were useless. I preferred duvets to blankets though.
- Has thanked: 10277 times
- Been thanked: 6891 times
- Been thanked: 7539 times
Re: Indoor covers
I've sealed my garage to make it completely airtight, then filled it with formaldehyde.
- dern
Re: Indoor covers
A blanket seems easier to be honest.KungFooBob wrote: ↑Thu Nov 03, 2022 7:44 pm I've sealed my garage to make it completely airtight, then filled it with formaldehyde.
- Has thanked: 2636 times
- Been thanked: 1523 times
Re: Indoor covers
That's more info on your elasticated sheets than we really need to know.
- Has thanked: 1751 times
- Been thanked: 2086 times
Re: Indoor covers
Just cover the tank with something thickish. bubblewrap, door mat. etc
